Oui oui j’ai réglé l’ordre de mes cartes dans alsabase.conf et ma carte usb est la carte par défaut lorsqu’elle est branché.
résultat de lsusb :
-laptop:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 0c45:63eb Microdia
Bus 006 Device 002: ID 0ccd:0077 TerraTec Electronic GmbH Aureon Dual USB
résultat de lsmod :
-laptop:~$ lsmod
Module Size Used by
aes_x86_64 7340 2
aes_generic 25714 1 aes_x86_64
acpi_cpufreq 5571 1
cpufreq_powersave 902 0
cpufreq_conservative 5162 0
cpufreq_stats 2659 0
cpufreq_userspace 1992 0
parport_pc 18855 0
ppdev 5030 0
lp 7462 0
parport 27954 3 parport_pc,ppdev,lp
sco 7209 2
bnep 9427 2
rfcomm 29597 0
l2cap 24736 6 bnep,rfcomm
bluetooth 41827 6 sco,bnep,rfcomm,l2cap
binfmt_misc 6431 1
uinput 6376 1
fuse 50625 1
coretemp 4325 0
loop 11799 0
dvb_usb_af9015 29443 0
dvb_usb 15108 1 dvb_usb_af9015
dvb_core 75042 1 dvb_usb
firewire_sbp2 11514 0
usblp 9571 0
snd_hda_codec_atihdmi 2251 1
snd_hda_codec_idt 42481 1
snd_hda_intel 20019 0
snd_usb_audio 64070 3
snd_hda_codec 54244 3 snd_hda_codec_atihdmi,snd_hda_codec_idt,snd_hda_intel
joydev 8459 0
arc4 1274 2
snd_usb_lib 13928 1 snd_usb_audio
snd_hwdep 5380 2 snd_usb_audio,snd_hda_codec
snd_pcm_oss 32591 0
snd_mixer_oss 12606 1 snd_pcm_oss
snd_pcm 60503 5 snd_hda_intel,snd_usb_audio,snd_hda_codec,snd_pcm_oss
snd_seq_midi 4400 0
ecb 1841 2
snd_rawmidi 15515 2 snd_usb_lib,snd_seq_midi
snd_seq_midi_event 4628 1 snd_seq_midi
snd_seq 42881 3 snd_seq_midi,snd_seq_midi_event
iwlagn 73123 0
uvcvideo 50727 0
snd_timer 15582 3 snd_pcm,snd_seq
snd_seq_device 4493 3 snd_seq_midi,snd_rawmidi,snd_seq
iwlcore 77810 1 iwlagn
mac80211 137340 2 iwlagn,iwlcore
snd 46446 17 snd_hda_codec_idt,snd_hda_intel,snd_usb_audio,snd_hda_codec,snd_hwdep,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
videodev 35692 1 uvcvideo
v4l1_compat 11442 2 uvcvideo,videodev
i2c_i801 7830 0
v4l2_compat_ioctl32 8817 1 videodev
snd_page_alloc 6249 2 snd_hda_intel,snd_pcm
soundcore 4598 1 snd
cfg80211 101496 3 iwlagn,iwlcore,mac80211
psmouse 49777 0
fglrx 2633974 150
dell_laptop 1985 0
rfkill 13044 5 bluetooth,cfg80211,dell_laptop
video 17445 0
i2c_core 15712 4 dvb_usb_af9015,dvb_usb,videodev,i2c_i801
output 1692 1 video
serio_raw 3752 0
dcdbas 5048 1 dell_laptop
evdev 7352 19
ac 2192 0
wmi 4323 0
battery 4998 0
button 4650 0
processor 29935 3 acpi_cpufreq
ext4 289033 2
mbcache 5050 1 ext4
jbd2 67015 1 ext4
crc16 1319 2 l2cap,ext4
usbhid 33292 0
hid 63225 1 usbhid
sg 18744 0
sr_mod 12602 1
cdrom 29415 1 sr_mod
sd_mod 29889 4
crc_t10dif 1276 1 sd_mod
uhci_hcd 18521 0
sdhci_pci 5581 0
sdhci 13966 1 sdhci_pci
thermal 11674 0
tg3 95663 0
ahci 32374 5
firewire_ohci 19676 0
mmc_core 45686 1 sdhci
ricoh_mmc 3069 0
libphy 14054 1 tg3
firewire_core 36848 2 firewire_sbp2,firewire_ohci
crc_itu_t 1307 1 firewire_core
thermal_sys 11942 3 video,processor,thermal
libata 133632 1 ahci
led_class 2433 2 iwlcore,sdhci
scsi_mod 122149 5 firewire_sbp2,sg,sr_mod,sd_mod,libata
ehci_hcd 31151 0
usbcore 122034 10 dvb_usb_af9015,dvb_usb,usblp,snd_usb_audio,snd_usb_lib,uvcvideo,usbhid,uhci_hcd,ehci_hcd
nls_base 6377 1 usbcore
Contenu de modprobe.d
[code]# autoloader aliases
install sound-slot-0 /sbin/modprobe snd-card-0
install sound-slot-1 /sbin/modprobe snd-card-1
install sound-slot-2 /sbin/modprobe snd-card-2
install sound-slot-3 /sbin/modprobe snd-card-3
install sound-slot-4 /sbin/modprobe snd-card-4
install sound-slot-5 /sbin/modprobe snd-card-5
install sound-slot-6 /sbin/modprobe snd-card-6
install sound-slot-7 /sbin/modprobe snd-card-7
Cause optional modules to be loaded above generic modules
install snd /sbin/modprobe --ignore-install snd && { /sbin/modprobe --quiet snd-ioctl32 ; /sbin/modprobe --quiet snd-seq ; }
install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi && { /sbin/modprobe --quiet snd-seq-midi ; : ; }
install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 && { /sbin/modprobe --quiet snd-emu10k1-synth ; : ; }
options snd cards_limit=2
Prevent abnormal drivers from grabbing index 0
#options bt87x index=-2
#options cx88_alsa index=-2
#options snd-atiixp-modem index=-2
#options snd-intel8x0m index=-2
#options snd-via82xx-modem index=-2
Keep snd-pcsp from beeing loaded as first soundcard
options snd-pcsp index=-2
Keep snd-usb-audio from beeing loaded as first soundcard
options snd-usb-audio index=-2
options snd-usb-audio index=0
options snd-hda-intel model=dell-m6 index=1,2
À noter que le problème est le même sous windows 7 (je m’en rends compte à l’instant puisque je ne l’utilise jamais à part pour le mettre à jour).
La carte est reconnue mais ne propose pas de régler le volume à part par le niveau du speaker…
Je vais continuer d’affiner mes réglages individuellememnt dans chaque application en prenant garde à ne pas mettre mon casque sur les oreilles avant de lancer de la musique ou une vidéo.
