Je dois sortir cet AM mais je vérifie tout ça dans la soirée.
J’ai coupé mon tel mobile hier et j’ai autant d’alertes aujourd’hui
Je commence à me poser des questions.
Voici la totalité des alertes de ce jour sur Logwatch, concernant Dovecot :
[code]Unmatched Entries
dovecot: imap-login: Warning: SSL alert: where=0x4004, ret=256: warning close notify [192.168.0.254]: 1 Time(s)
dovecot: imap-login: Warning: SSL alert: where=0x4008, ret=256: warning close notify [192.168.0.254]: 10 Time(s)
dovecot: imap-login: Warning: SSL alert: where=0x4008, ret=256: warning close notify [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL alert: where=0x4008, ret=256: warning close notify [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x10, ret=1: before/accept initialization [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x10, ret=1: before/accept initialization [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x10, ret=1: before/accept initialization [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x20, ret=1: SSL negotiation finished successfully [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x20, ret=1: SSL negotiation finished successfully [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x20, ret=1: SSL negotiation finished successfully [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 flush data [192.168.0.254]: 28 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 flush data [37.160.42.50]: 2 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 flush data [37.160.85.217]: 2 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read client hello A [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read client hello A [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read client hello A [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read client key exchange A [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read client key exchange A [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read client key exchange A [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read finished A [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read finished A [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read finished A [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write certificate A [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write certificate A [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write certificate A [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write change cipher spec A [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write change cipher spec A [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write change cipher spec A [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write finished A [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write finished A [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write finished A [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write key exchange A [192.168.0.254]: 13 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write server done A [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write server done A [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write server done A [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write server hello A [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write server hello A [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write server hello A [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write session ticket A [192.168.0.254]: 13 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: before/accept initialization [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: before/accept initialization [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2001, ret=1: before/accept initialization [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2002, ret=-1: SSLv3 read client certificate A [192.168.0.254]: 28 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2002, ret=-1: SSLv3 read client certificate A [37.160.42.50]: 2 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2002, ret=-1: SSLv3 read client certificate A [37.160.85.217]: 2 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2002, ret=-1: unknown state [192.168.0.254]: 10 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2002, ret=-1: unknown state [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2002, ret=-1: unknown state [37.160.85.217]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2002, ret=1: SSL negotiation finished successfully [192.168.0.254]: 14 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2002, ret=1: SSL negotiation finished successfully [37.160.42.50]: 1 Time(s)
dovecot: imap-login: Warning: SSL: where=0x2002, ret=1: SSL negotiation finished successfully [37.160.85.217]: 1 Time(s)
---------------------- Dovecot End ------------------------- [/code]
