Alerte sur les 2 disques SSD interne: Hard Disk Health Warning
Je ne retrouve pas mon message précédent sur ce sujet.
les 2 SSD supportent le même groupe de volume LVM.
This message was generated by the smartd daemon running on:
   host name:  Leopard
   DNS domain: Coucy
The following warning/error was logged by the smartd daemon:
Device: /dev/nvme1, number of Error Log entries increased from 2380 to 2381
Device info:
CT4000P3PSSD8, S/N:2331E86580C6, FW:P9CR40A
For details see host's SYSLOG.
You can also use the smartctl utility for further investigation.
The original message about this issue was sent at Sat May 31 09:20:03 2025 CEST
Another message will be sent in 24 hours if the problem persists.
Message analogue sur l’autre SSD:
   host name:  Leopard
   DNS domain: Coucy
Device: /dev/nvme0, number of Error Log entries increased from 2382 to 2383
Device info:
CT4000P3PSSD8, S/N:2331E86580DB, FW:P9CR40A
Le syslog est bourré de lignes rouges.
voici le log depuis 17h:
syslogDepuis1h.txt (810,9 Ko)
PS
j’ai lancé smartctl comme suggéré par le message:
#smartctl -a /dev/nvme1
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.0-37-amd64] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number:                       CT4000P3PSSD8
Serial Number:                      2331E86580C6
Firmware Version:                   P9CR40A
PCI Vendor/Subsystem ID:            0xc0a9
IEEE OUI Identifier:                0x00a075
Controller ID:                      1
NVMe Version:                       1.4
Number of Namespaces:               1
Namespace 1 Size/Capacity:          4 000 787 030 016 [4,00 TB]
Namespace 1 Formatted LBA Size:     512
Namespace 1 IEEE EUI-64:            6479a7 7f6000005d
Local Time is:                      Tue Jul  8 17:27:50 2025 CEST
Firmware Updates (0x12):            1 Slot, no Reset required
Optional Admin Commands (0x0017):   Security Format Frmw_DL Self_Test
Optional NVM Commands (0x005e):     Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp
Log Page Attributes (0x06):         Cmd_Eff_Lg Ext_Get_Lg
Maximum Data Transfer Size:         64 Pages
Warning  Comp. Temp. Threshold:     85 Celsius
Critical Comp. Temp. Threshold:     95 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     6.00W  0.0000W       -    0  0  0  0        0       0
 1 +     3.00W  0.0000W       -    0  0  0  0        0       0
 2 +     1.50W  0.0000W       -    0  0  0  0        0       0
 3 -   0.0250W  0.0000W       -    3  3  3  3     5000    1900
 4 -   0.0030W       -        -    4  4  4  4    13000  100000
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         1
 1 -    4096       0         0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        33 Celsius
Available Spare:                    100%
Available Spare Threshold:          5%
Percentage Used:                    1%
Data Units Read:                    7 543 910 [3,86 TB]
Data Units Written:                 16 938 534 [8,67 TB]
Host Read Commands:                 19 856 500
Host Write Commands:                100 378 167
Controller Busy Time:               806
Power Cycles:                       208
Power On Hours:                     12 641
Unsafe Shutdowns:                   78
Media and Data Integrity Errors:    0
Error Information Log Entries:      2 382
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 1:               33 Celsius
Temperature Sensor 2:               32 Celsius
Temperature Sensor 8:               33 Celsius
Error Information (NVMe Log 0x01, 16 of 16 entries)
Num   ErrCount  SQId   CmdId  Status  PELoc          LBA  NSID    VS
  0       2382     0  0x700a  0x4005  0x028            0     0     -
— sur l’autre SSD:
#smartctl -x /dev/nvme0
Serial Number:                      2331E86580DB
Controller ID:                      1
NVMe Version:                       1.4
Namespace 1 IEEE EUI-64:            6479a7 7f60000050
Local Time is:                      Tue Jul  8 17:30:36 2025 CEST
 0 +     512       0         1
 1 -    4096       0         0
Temperature:                        31 Celsius
Percentage Used:                    1%
Data Units Read:                    58 704 626 [30,0 TB]
Data Units Written:                 22 431 932 [11,4 TB]
Host Read Commands:                 279 293 106
Host Write Commands:                339 747 512
Controller Busy Time:               2 992
Power Cycles:                       208
Power On Hours:                     12 632
Error Information Log Entries:      2 383
Temperature Sensor 1:               31 Celsius
Temperature Sensor 2:               35 Celsius
Temperature Sensor 8:               31 Celsius
  0       2383     0  0x8001  0x4005  0x028            0     0     -
