Bonjour, j’ai récemment installe en dual boot debian / Windows 8 tout se passe bien. Le seul problème est que lorsque je veut installer les drivers amd pour pouvoir utiliser deux écrans en étendu et l’accélération matérielle, il me met :
One or more tools required for installation cannot be found on the system. Install the required tools before installing the fglrx driver.
Optionally, run the installer with --force option to install without the tools.
Forcing install will disable AMD hardware acceleration and may make your system unstable. Not recommended.
et dans le termial :
[code]root@debian:/home/alexandre# sudo sh '/home/alexandre/amd-driver-installer-catalyst-13-4-x86.x86_64.run’
Created directory fglrx-install.WUv2aD
Verifying archive integrity… All good.
Uncompressing AMD Catalyst™ Proprietary Driver-12.104…
AMD Catalyst™ Proprietary Driver Installer/Packager
Detected configuration:
Architecture: x86_64 (64-bit)
X Server: X.Org 6.9 or later 64-bit
loki_setup: directory: (null)
Removing temporary directory: fglrx-install.WUv2aD
J’ai mit aptitude install loki il l’a installé mais rien.
Je suis allé voir sur les autres forums, angalis notament, mais rien, je n’y arrive pas. (J’utilise un pc portable HP pavilion G6-2143sf)
Voici ma config :
[ul]Linux debian 3.2.0-4-amd64 #1 SMP Debian 3.2.41-2+deb7u2 x86_64 GNU/Linux[/ul]
00:00.0 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Root Complex
00:01.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Trinity [Radeon HD 7520G]
00:01.1 Audio device: Advanced Micro Devices [AMD] nee ATI Trinity HDMI Audio Controller
00:02.0 PCI bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Root Port
00:04.0 PCI bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Root Port
00:10.0 USB controller: Advanced Micro Devices [AMD] FCH USB XHCI Controller (rev 03)
00:10.1 USB controller: Advanced Micro Devices [AMD] FCH USB XHCI Controller (rev 03)
00:11.0 SATA controller: Advanced Micro Devices [AMD] FCH SATA Controller [AHCI mode]
00:12.0 USB controller: Advanced Micro Devices [AMD] FCH USB OHCI Controller (rev 11)
00:12.2 USB controller: Advanced Micro Devices [AMD] FCH USB EHCI Controller (rev 11)
00:13.0 USB controller: Advanced Micro Devices [AMD] FCH USB OHCI Controller (rev 11)
00:13.2 USB controller: Advanced Micro Devices [AMD] FCH USB EHCI Controller (rev 11)
00:14.0 SMBus: Advanced Micro Devices [AMD] FCH SMBus Controller (rev 14)
00:14.2 Audio device: Advanced Micro Devices [AMD] FCH Azalia Controller (rev 01)
00:14.3 ISA bridge: Advanced Micro Devices [AMD] FCH LPC Bridge (rev 11)
00:14.4 PCI bridge: Advanced Micro Devices [AMD] FCH PCI Bridge (rev 40)
00:15.0 PCI bridge: Advanced Micro Devices [AMD] Hudson PCI to PCI bridge (PCIE port 0)
00:15.1 PCI bridge: Advanced Micro Devices [AMD] Hudson PCI to PCI bridge (PCIE port 1)
00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 0
00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 3
00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 4
00:18.5 Host bridge: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) Processor Function 5
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Thames XT/GL [Radeon HD 7600M Series]
02:00.0 Network controller: Atheros Communications Inc. AR9485 Wireless Network Adapter (rev 01)
04:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 05)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 003: ID 04f2:b2f4 Chicony Electronics Co., Ltd
Bus 007 Device 002: ID 0451:2046 Texas Instruments, Inc. TUSB2046 Hub
Bus 007 Device 003: ID 04f9:0249 Brother Industries, Ltd
Bus 007 Device 004: ID 046d:c025 Logitech, Inc. MX500 Optical Mouse
Bus 007 Device 005: ID 0603:00f2 Novatek Microelectronics Corp.
[code]dmidecode 2.11
SMBIOS 2.7 present.
34 structures occupying 1871 bytes.
Table at 0x000E4800.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: Insyde
Version: F.27
Release Date: 04/12/2013
ROM Size: 4096 kB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
Japanese floppy for NEC 9800 1.2 MB is supported (int 13h)
Japanese floppy for Toshiba 1.2 MB is supported (int 13h)
5.25"/360 kB floppy services are supported (int 13h)
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 15.39
Firmware Revision: 57.53
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: Hewlett-Packard
Product Name: HP Pavilion g6 Notebook PC
Version: 0796100000205110000620100
Serial Number: 5CD2252FHL
UUID: 32444335-3532-4632-484C-A0B3CC6C9B1E
Wake-up Type: Power Switch
SKU Number: B3T42EA#ABF
Family: 103C_5335KV G=N L=CON B=HP S=PAV
Handle 0x0002, DMI type 2, 16 bytes
Base Board Information
Product Name: 184A
Version: 57.35
Serial Number: PCTXB012C1R4LS
Asset Tag: Base Board Asset Tag
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Base Board Chassis Location
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 23 bytes
Chassis Information
Type: Notebook
Lock: Not Present
Version: Chassis Version
Serial Number: Chassis Serial Number
Asset Tag: Not Specified
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000151
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
SKU Number: Not Specified
Handle 0x0004, DMI type 9, 17 bytes
System Slot Information
Designation: PCI Express Slot 1
Type: x16 PCI Express x16
Current Usage: Available
Length: Long
Characteristics:
3.3 V is provided
PME signal is supported
Bus Address: 0000:00:02.0
Handle 0x0005, DMI type 9, 17 bytes
Designation: PCI Express Slot 2
Type: x1 PCI Express x1
Length: Short
Characteristics:
3.3 V is provided
Hot-plug devices are supported
Bus Address: 0000:00:04.0
Handle 0x0006, DMI type 9, 17 bytes
Designation: PCI Express Slot 3
Length: Short
Characteristics:
3.3 V is provided
Bus Address: 0000:00:05.0
Handle 0x0007, DMI type 11, 5 bytes
OEM Strings
String 1: $HP$
String 2: LOC#ABF
String 3: ABS 70/71 78 79 7A 7B
String 4: CNB1 0796100000205110000620100
String 5: HP_Mute_LED_0_A
String 6: String6 for Original Equipment Manufacturer
String 7: String7 for Original Equipment Manufacturer
String 8: String8 for Original Equipment Manufacturer
Handle 0x0009, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 4
en|US|iso8859-1
fr|CA|iso8859-1
es|ES|iso8859-1
zh|TW|unicode
Currently Installed Language: fr|CA|iso8859-1
Handle 0x000C, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x000E, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: CN5
Internal Connector Type: None
External Reference Designator: USB
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x000F, DMI type 8, 9 bytes
Internal Reference Designator: CN21
Port Type: USB
Handle 0x0010, DMI type 8, 9 bytes
Internal Reference Designator: CN22
Port Type: USB
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: CN20
External Reference Designator: Network
External Connector Type: RJ-45
Port Type: Network Port
Handle 0x0012, DMI type 8, 9 bytes
Internal Reference Designator: CN14
External Reference Designator: CRT
External Connector Type: DB-15 female
Port Type: Video Port
Handle 0x0013, DMI type 8, 9 bytes
Internal Reference Designator: CN19
External Reference Designator: HDMI
External Connector Type: Other
Handle 0x0014, DMI type 8, 9 bytes
Internal Reference Designator: CN23
External Reference Designator: Microphone In
External Connector Type: Mini Jack (headphones)
Port Type: Audio Port
Handle 0x0015, DMI type 8, 9 bytes
Internal Reference Designator: CN24
External Reference Designator: Headphones Out
Handle 0x0016, DMI type 22, 26 bytes
Portable Battery
Manufacturer: 13-54
Chemistry: Lithium Ion
Design Capacity: 47520 mWh
Design Voltage: 10800 mV
SBDS Version: 3.1
Maximum Error: 1%
SBDS Serial Number: 0473
SBDS Manufacture Date: 2012-05-25
OEM-specific Information: 0x0000FFFF
Handle 0x0018, DMI type 41, 11 bytes
Onboard Device
Reference Designation: AMD TRINITY SCRAPPER MOBILE Graphics
Type: Video
Status: Enabled
Type Instance: 1
Bus Address: 0000:00:01.0
Handle 0x001A, DMI type 41, 11 bytes
Onboard Device
Reference Designation: AMD Radeon HD 7600M Series Graphics
Type: Video
Status: Enabled
Type Instance: 1
Bus Address: 0000:01:00.0
Handle 0x001B, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Atheros AR9485 802.11b/g/n WiFi Adapter
Type: Other
Status: Enabled
Type Instance: 1
Bus Address: 0000:02:00.0
Handle 0x001C, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Realtek PCIE CardReader
Type: Other
Status: Enabled
Type Instance: 1
Bus Address: 0000:04:00.0
Handle 0x001D, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Realtek PCIe FE Family Controller
Type: Ethernet
Status: Enabled
Type Instance: 1
Bus Address: 0000:05:00.0
Handle 0x001E, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 6 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x001F, DMI type 17, 34 bytes
Memory Device
Array Handle: 0x001E
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Bottom-Slot 1(top)
Bank Locator: CHANNEL A
Type: DDR3
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 1333 MHz
Manufacturer: Elpida
Serial Number: 13A730F0
Asset Tag: Asset Tag:
Part Number: EBJ20UF8BDU0-GN-F
Rank: 1
Configured Clock Speed: 667 MHz
Handle 0x0021, DMI type 20, 35 bytes
Memory Device Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x0017FFFFFFF
Range Size: 6 GB
Physical Device Handle: 0x001F
Memory Array Mapped Address Handle: 0x0025
Partition Row Position: 1
Handle 0x0022, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Bottom-Slot 2(under)
Bank Locator: CHANNEL B
Type: DDR3
Speed: 1333 MHz
Manufacturer: Micron Technology
Serial Number: 410628E9
Part Number: 16KTF51264HZ-1G6M1
Rank: 2
Handle 0x0024, DMI type 20, 35 bytes
Range Size: 6 GB
Physical Device Handle: 0x0022
Handle 0x0025, DMI type 19, 31 bytes
Range Size: 6 GB
Physical Array Handle: 0x001E
Partition Width: 255
Handle 0x0027, DMI type 4, 42 bytes
Processor Information
Socket Designation: Socket FT1
Type: Central Processor
Family: S-Series
Manufacturer: AMD processor
ID: 01 0F 61 00 FF FB 8B 17
Signature: Family 21, Model 16, Stepping 1
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
HTT (Multi-threading)
Version: AMD A6-4400M APU with Radeon™ HD Graphics
Voltage: 1.2 V
External Clock: 100 MHz
Max Speed: 2700 MHz
Current Speed: 2700 MHz
Status: Populated, Enabled
Upgrade: Socket FS1
L1 Cache Handle: 0x0028
L2 Cache Handle: 0x0029
L3 Cache Handle: Not Provided
Serial Number: NotSupport
Asset Tag: FFFF
Part Number: FFFF
Core Count: 2
Core Enabled: 2
Thread Count: 2
Characteristics:
64-bit capable
Handle 0x0028, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1 Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 96 kB
Maximum Size: 96 kB
Supported SRAM Types:
Pipeline Burst
Installed SRAM Type: Pipeline Burst
Speed: 1 ns
Error Correction Type: Multi-bit ECC
System Type: Unified
Associativity: 2-way Set-associative
Handle 0x0029, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2 Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 1024 kB
Maximum Size: 1024 kB
Pipeline Burst
Speed: 1 ns
Associativity: 16-way Set-associative
Handle 0x002A, DMI type 127, 4 bytes
End Of Table
Voilà j’espère que ce sera suffisant.
Merci d’avance de votre aide.
Cordialement
Loique
