[Apache]Problème de visualisation du site
Mon problème se trouve au niveau de mon site web.
Quand je me rends sur son URL, cela m’affiche une page blanche alors que mon dossier www/monsite est bien remplie.
Le site fonctionnait très bien jusqu’a avoir installé postfix et Qqopper sur mon serveur (Vous me direz, aucun rapport et pourtant c’est bien depuis cette installation que le site ne fonctionne plus).
Voici mes logs d’erreur d’apache:
[Tue Feb 01 13:44:48 2011] [crit] [client 127.0.0.1] (13)Permission denied: /var/empty/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Tue Feb 01 13:49:48 2011] [crit] [client 127.0.0.1] (13)Permission denied: /var/empty/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Tue Feb 01 13:54:48 2011] [crit] [client 127.0.0.1] (13)Permission denied: /var/empty/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Tue Feb 01 13:59:48 2011] [crit] [client 127.0.0.1] (13)Permission denied: /var/empty/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Tue Feb 01 14:04:48 2011] [crit] [client 127.0.0.1] (13)Permission denied: /var/empty/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Tue Feb 01 14:09:48 2011] [crit] [client 127.0.0.1] (13)Permission denied: /var/empty/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Tue Feb 01 14:14:48 2011] [crit] [client 127.0.0.1] (13)Permission denied: /var/empty/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Tue Feb 01 14:19:48 2011] [crit] [client 127.0.0.1] (13)Permission denied: /var/empty/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Tue Feb 01 14:24:48 2011] [crit] [client 127.0.0.1] (13)Permission denied: /var/empty/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
[Tue Feb 01 14:29:48 2011] [crit] [client 127.0.0.1] (13)Permission denied: /var/empty/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
Auriez vous une idée sur cette erreur?
Merci d’avance pour vos réponses.
OS:
Linux Debian Lenny 2.6.26-2-amd64 x86_64 GNU/Linux
Sans hésiter un problème de droits…
Que donne:
[code]# vdir /var
vdir /var/empty[/code]
Voici les resultats de vdir /var et vdir /var/empty
vdir /var
drwxr-xr-x  2 root     root     4096 fév  1 06:25 backups
drwxr-xr-x 15 root     root     4096 jan 25 15:02 cache
drw-rw-r--  2 www-data www-data 4096 jan 25 13:32 empty
drwxr-xr-x 34 root     root     4096 jan 31 13:47 lib
drwxrwsr-x  2 root     staff    4096 jan 25  2010 local
drwxrwxrwt  3 root     root     4096 fév  1 06:25 lock
drwxr-xr-x 15 root     root     4096 fév  1 06:25 log
drwxrwsr-x  2 root     mail     4096 jan 31 06:25 mail
drwxr-xr-x  2 root     root     4096 mai 26  2010 opt
drwxr-xr-x 12 root     root     4096 jan 31 16:28 run
drwxr-xr-x 11 root     root     4096 jan 31 13:59 spool
drwxrwxrwt  3 root     root     4096 jan 27 13:27 tmp
drwx------  3 root     bin      4096 jan 25 12:06 webmin
drwxr-xr-x  4 root     root     4096 jan 30 15:00 www
vdir /var/empty
total 0
[quote=“arkax”]vdir /var/empty
total 0 [/quote]
/var/empty est… vide
Essaye d’y mettre un fichier .htaccess puisque c’est ce qu’il désire… :wink:
[code]# touch /var/empty/.htaccess
chown -R www-data:www-data /var/empty
apache2ctl restart[/code]
Alors j’ai appliqué ce que tu ma conseillé, après avoir relancer apache, j’obtient toujours la même erreur ><
[Thu Feb 03 00:54:26 2011] [notice] Apache/2.2.9 (Debian) PHP/5.2.6-1+lenny9 with Suhosin-Patch mod_ssl/2.2.9 OpenSSL/0.9.8g configured -- resuming normal operations [Thu Feb 03 00:54:48 2011] [crit] [client 127.0.0.1] (13)Permission denied: /var/empty/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable
Je ne trouve pas de solution malheureusement ><
À quoi correspond ce dossier “empty” ?
S’il se dit lui-même “vide”, pourquoi réclame-t-il un fichier ?
Je n’ai sur aucune de mes machines de tel dossier.
Je viens d’être confronter à cette situation, d’où cette résurrection … :033
[quote=“ricardo”]À quoi correspond ce dossier “empty” ?
Je n’ai sur aucune de mes machines de tel dossier.[/quote]
@Ricardo ceci devrait amplement te satisfaire … 8)
Bloquer les scans de dossier par dictionnaire sur votre serveur WEB
[quote=“lol”]Salut,
total 0 [/quote]
apache2ctl restart[/code][/quote]
Laurent … Merci :wink: !
Je ne connais pas vdir, mais est ce qu’il affiche les fichiers cachés (commençant par un .) ?
A vérifier avec ls -la
Autrement, il me semble que debian est paramétré par défaut pour ne pas afficher les erreurs PHP, d’ou éventuellement une page blanche en cas d’erreur. Voir le paramètre display_error (error_display ?) de php.ini et éventuellement error_reporting.
