Apache qui démarre plus
Bonjour a tous
sur mon serveur j’ai voulu suivre ce tuto http://www.it-connect.fr/configurer-postfix-pour-envoyer-des-mails-avec-gmail/pour créer un serveur mail via gmail
Après reboot le serveur apache2 ne démarre plus et en console j’ai ce message
Restarting apache2 (via systemctl): apache2.serviceJob for apache2.service failed. See 'systemctl status apache2.service' and 'journalctl -xn' for details. failed!
J’ai aussi trouvé ceci
[code]root@debiansvr2:/home/philox47# systemctl status apache2.service
● apache2.service - LSB: Apache2 web server
Loaded: loaded (/etc/init.d/apache2)
Active: failed (Result: exit-code) since sam 2015-05-23 17:07:23 CEST; 1min 8s ago
Process: 2096 ExecStart=/etc/init.d/apache2 start (code=exited, status=1/FAILURE)
mai 23 17:07:23 debiansvr2 apache2[2096]: Starting web server: apache2 failed!
mai 23 17:07:23 debiansvr2 apache2[2096]: The apache2 configtest failed. …
mai 23 17:07:23 debiansvr2 apache2[2096]: Output of config test was:
mai 23 17:07:23 debiansvr2 apache2[2096]: apache2: Syntax error on line 216 …y
mai 23 17:07:23 debiansvr2 apache2[2096]: Action ‘configtest’ failed.
mai 23 17:07:23 debiansvr2 apache2[2096]: The Apache error log may have more…
mai 23 17:07:23 debiansvr2 systemd[1]: apache2.service: control process exi…=1
mai 23 17:07:23 debiansvr2 systemd[1]: Failed to start LSB: Apache2 web server.
mai 23 17:07:23 debiansvr2 systemd[1]: Unit apache2.service entered failed …e.
Hint: Some lines were ellipsized, use -l to show in full.
UNIT LOAD ACTIVE SUB DESCRIPTION proc-sys-fs-binfmt_misc.automount loaded active waiting Arbitrary Executable File Formats sys-devices-pci0000:00-0000:00:1c.0-0000:02:00.0-net-eth0.device loaded active plugged NetXtreme BCM5751 Gigabit Etherne sys-devices-pci0000:00-0000:00:1e.2-sound-card0.device loaded active plugged 82801G (ICH7 Family) AC'97 Audio sys-devices-pci0000:00-0000:00:1f.1-ata1-host0-target0:0:0-0:0:0:0-block-sr0.device loaded active plugged SONY_CD-RW_DVD-ROM_CRX310EE sys-devices-pci0000:00-0000:00:1f.2-ata3-host2-target2:0:0-2:0:0:0-block-sda-sda1.device loaded active plugged WDC_WD5000AAKX-22ERMA0 1 sys-devices-pci0000:00-0000:00:1f.2-ata3-host2-target2:0:0-2:0:0:0-block-sda-sda2.device loaded active plugged WDC_WD5000AAKX-22ERMA0 2 sys-devices-pci0000:00-0000:00:1f.2-ata3-host2-target2:0:0-2:0:0:0-block-sda.device loaded active plugged WDC_WD5000AAKX-22ERMA0 sys-devices-platform-floppy.0-block-fd0.device loaded active plugged /sys/devices/platform/floppy.0/bl sys-devices-platform-serial8250-tty-ttyS1.device loaded active plugged /sys/devices/platform/serial8250/ sys-devices-platform-serial8250-tty-ttyS2.device loaded active plugged /sys/devices/platform/serial8250/ sys-devices-platform-serial8250-tty-ttyS3.device loaded active plugged /sys/devices/platform/serial8250/ sys-devices-pnp0-00:03-printer-lp0.device loaded active plugged /sys/devices/pnp0/00:03/printer/l sys-devices-pnp0-00:04-tty-ttyS0.device loaded active plugged /sys/devices/pnp0/00:04/tty/ttyS0 sys-subsystem-net-devices-eth0.device loaded active plugged NetXtreme BCM5751 Gigabit Etherne -.mount loaded active mounted / dev-hugepages.mount loaded active mounted Huge Pages File System dev-mqueue.mount loaded active mounted POSIX Message Queue File System run-rpc_pipefs.mount loaded active mounted /run/rpc_pipefs run-user-0.mount loaded active mounted /run/user/0 sys-kernel-debug.mount loaded active mounted Debug File System acpid.path loaded active running ACPI Events Check cups.path loaded active waiting CUPS Printer Service Spool systemd-ask-password-console.path loaded active waiting Dispatch Password Requests to Con systemd-ask-password-wall.path loaded active waiting Forward Password Requests to Wall session-1.scope loaded active running Session 1 of user root acpid.service loaded active running ACPI event daemon ● apache2.service loaded failed failed LSB: Apache2 web server atd.service loaded active running Deferred execution scheduler avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack console-setup.service loaded active exited LSB: Set console font and keymap cron.service loaded active running Regular background program proces cups-browsed.service loaded active running Make remote CUPS printers availab cups.service loaded active running CUPS Printing Service dbus.service loaded active running D-Bus System Message Bus exim4.service loaded active exited LSB: exim Mail Transport Agent fail2ban.service loaded active exited LSB: Start/stop fail2ban getty@tty1.service loaded active running Getty on tty1 ifup@eth0.service loaded active exited ifup for eth0 kbd.service loaded active exited LSB: Prepare console
Quelqu’un a une idée ???
J’ai trouvé
en fait mes fichiers virtualhost dans site avaiable crée sous squeeze il y a pas mal de temps n’était plus bon sous jeesie le fichier est plus simplifié il suffit juste d’écrire le port et le répertoire vers ou il doit diriger c’est tout
Voila
