Yahallo,
J’ai ceci :
[b]● apache2.service - LSB: Apache2 web server
Loaded: loaded (/etc/init.d/apache2)
Active: failed (Result: exit-code) since sam. 2016-01-09 09:29:24 CET; 9min ago
janv. 09 09:29:04 vps234750.ovh.net apache2[2155]: Starting web server: apache2(98)Address already in use: AH00072: make_sock: could not bind to ad…[::]:443
janv. 09 09:29:04 vps234750.ovh.net apache2[2155]: (98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
janv. 09 09:29:24 vps234750.ovh.net apache2[2155]: failed!
janv. 09 09:29:24 vps234750.ovh.net apache2[2155]: The apache2 instance did not start within 20 seconds. Please read the log files to discover prob…arning).
janv. 09 09:29:24 vps234750.ovh.net systemd[1]: apache2.service: control process exited, code=exited status=1
janv. 09 09:29:24 vps234750.ovh.net systemd[1]: Failed to start LSB: Apache2 web server.
janv. 09 09:29:24 vps234750.ovh.net systemd[1]: Unit apache2.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
illoxx@vps234750:/etc$
[/b]
Je ne sais pas du tout comment régler cette erreur, sachant que je n’ai aucun autre programme sur le port 80…
Quelqu’un pour m’aider svp ?
