salut dexmon,
j’ai regardé les logs, et bizarement, les ips de mes clients VPN n’apparaissent pas dans le error_log mais dans le access_log ! et pourtant ils ont ces erreurs et ne peuvent pas naviguer dans le site.
voici le tail (un peu modifié…) des 2 fichiers de log :
[quote]# tail /usr/local/apache2/logs/error_log
[Mon Jun 19 11:32:14 2006] [error] [client 10.0.0.x] (84)Invalid or incomplete multibyte or wide character: The requested report is unknown. [501, #200007]
[Mon Jun 19 11:33:36 2006] [error] [client 10.0.0.x] (84)Invalid or incomplete multibyte or wide character: The requested report is unknown. [501, #200007]
[Mon Jun 19 11:38:29 2006] [error] [client 10.0.0.y] Access denied: ‘login1’ CHECKOUT repository:/path/Debug.java
[Mon Jun 19 11:38:39 2006] [error] [client 10.0.0.y] Access denied: ‘login1’ CHECKOUT repository:/path/Debug.java
[Mon Jun 19 11:38:42 2006] [error] [client 10.0.0.y] Could not fetch resource information. [501, #0]
[Mon Jun 19 11:38:42 2006] [error] [client 10.0.0.y] (84)Invalid or incomplete multibyte or wide character: Multi-author commits not supported. [501, #0][/quote]
[quote]# tail /usr/local/apache2/logs/access_log
192.168.x.x - login1 [19/Jun/2006:13:26:56 +0200] “PROPFIND /reposiroty/default HTTP/1.1” 207 449
192.168.x.x - login1 [19/Jun/2006:13:27:02 +0200] “PROPFIND /repository/ HTTP/1.1” 207 653
192.168.x.x - login1 [19/Jun/2006:13:27:08 +0200] “PROPFIND /repository/ HTTP/1.1” 207 641
192.168.x.x - login1 [19/Jun/2006:13:27:14 +0200] “PROPFIND /repository/default HTTP/1.1” 207 449
192.168.x.x - login1 [19/Jun/2006:13:27:20 +0200] “PROPFIND /repository/ HTTP/1.1” 207 4580
10.0.0.x - login2 [19/Jun/2006:13:28:33 +0200] “GET /repository/ HTTP/1.1” 200 363
10.0.0.x - login2 [19/Jun/2006:13:28:36 +0200] “GET /repository/subversion/ HTTP/1.1” 200 391
10.0.0.x - login2 [19/Jun/2006:13:28:37 +0200] “GET /repository/subversion/branches/ HTTP/1.1” 200 459
10.0.0.x - login2 [19/Jun/2006:13:28:38 +0200] “GET /repository/subversion/branches/test/ HTTP/1.1” 200 776
192.168.x.x - login1 [19/Jun/2006:13:37:44 +0200] “PROPFIND /repository/ HTTP/1.1” 207 4580[/quote]
