Salut ,
J’ai un service apache2 qui tourne sur ma machine mais depuis ce matin je constate qu’il y a plusieurs instances qui tourne donc je décide de les killé les unes après les autres puis un start mais même problème.
:/# ps -ef |grep apache
root 3793 1 2 11:55 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 3800 3793 0 11:55 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 3801 3793 0 11:55 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 3802 3793 0 11:55 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 3803 3793 0 11:55 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 3804 3793 0 11:55 ? 00:00:00 /usr/sbin/apache2 -k start
root 3812 11532 0 11:55 pts/1 00:00:00 grep apache
J’ai regardé les logs errors.log j’obtiens ceci :
[Sun Nov 08 08:01:21 2009] [notice] Apache/2.2.9 (Debian) PHP/5.2.6-1+lenny3 with Suhosin-Patch configured -- resuming normal operations
[Sun Nov 08 11:13:07 2009] [warn] pid file /var/run/apache2.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Nov 08 11:13:07 2009] [notice] Apache/2.2.9 (Debian) PHP/5.2.6-1+lenny3 with Suhosin-Patch configured -- resuming normal operations
[Sun Nov 08 11:13:44 2009] [notice] caught SIGTERM, shutting down
[Sun Nov 08 11:24:47 2009] [notice] Apache/2.2.9 (Debian) PHP/5.2.6-1+lenny3 with Suhosin-Patch configured -- resuming normal operations
[Sun Nov 08 11:34:56 2009] [warn] pid file /var/run/apache2.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Nov 08 11:34:56 2009] [notice] Apache/2.2.9 (Debian) PHP/5.2.6-1+lenny3 with Suhosin-Patch configured -- resuming normal operations
[Sun Nov 08 11:36:49 2009] [notice] SIGHUP received. Attempting to restart
[Sun Nov 08 11:36:50 2009] [notice] Apache/2.2.9 (Debian) PHP/5.2.6-1+lenny3 with Suhosin-Patch configured -- resuming normal operations
[Sun Nov 08 11:51:35 2009] [notice] caught SIGTERM, shutting down
[Sun Nov 08 11:55:15 2009] [notice] Apache/2.2.9 (Debian) PHP/5.2.6-1+lenny3 with Suhosin-Patch configured -- resuming normal operations
Je ne comprends pas trop cette erreurs si vous avez une idée je la veux bien .
