J’ai essayé la mise à jour avec apt-get (kernel-image-2.6.5-1-686). Comme il fallait s’y attendre, ça ne marche pas. J’ai droit à un plantage de X après la mise à jour !
Extrait du log de XFree :
code Configured Mouse: Core Pointer
() Option “Device” “/dev/psaux”
(EE) xf86OpenSerial: Cannot open device /dev/psaux
No such device.
(EE) Configured Mouse: cannot open input device
(EE) PreInit failed for input device “Configured Mouse”
(II) UnloadModule: “mouse”
() Option “Protocol” “ImPS/2”
() Generic Mouse: Protocol: “ImPS/2”
() Option “SendCoreEvents” “true”
() Generic Mouse: always reports core events
() Option “Device” “/dev/input/mice”
(EE) xf86OpenSerial: Cannot open device /dev/input/mice
No such device.
(EE) Generic Mouse: cannot open input device
(EE) PreInit failed for input device “Generic Mouse”
(WW) No core pointer registered
No core pointer
Fatal server error:
failed to initialize core devices[/code]
Voici le contenu de /var/log/dmsg :
Linux version 2.6.5-1-686 (herbert@gondolin) (gcc version 3.3.3 (Debian 20040401)) #5 Fri Apr 30 20:26:13 EST 2004
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000000fff0000 (usable)
BIOS-e820: 000000000fff0000 - 000000000fff3000 (ACPI NVS)
BIOS-e820: 000000000fff3000 - 0000000010000000 (ACPI data)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
255MB LOWMEM available.
On node 0 totalpages: 65520
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 61424 pages, LIFO batch:14
HighMem zone: 0 pages, LIFO batch:1
DMI 2.0 present.
ACPI disabled because your bios is from 00 and too old
You can enable it with acpi=force
Built 1 zonelists
Kernel command line: BOOT_IMAGE=Linux(hdb3) ro root=343 hdc=ide-scsi hdd=ide-scsi
Local APIC disabled by BIOS -- reenabling.
Found and enabled local APIC!
Initializing CPU#0
PID hash table entries: 1024 (order 10: 8192 bytes)
Detected 600.102 MHz processor.
Using tsc for high-res timesource
Console: colour VGA+ 80x25
Memory: 251664k/262080k available (1521k kernel code, 9680k reserved, 633k data, 144k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay loop... 1179.64 BogoMIPS
Security Scaffold v1.0.0 initialized
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
checking if image is initramfs...it isn't (ungzip failed); looks like an initrd
Freeing initrd memory: 4556k freed
CPU: After generic identify, caps: 0387fbff 00000000 00000000 00000000
CPU: After vendor identify, caps: 0387fbff 00000000 00000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 256K
CPU serial number disabled.
CPU: After all inits, caps: 0383fbff 00000000 00000000 00000040
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: Intel Pentium III (Coppermine) stepping 01
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
enabled ExtINT on CPU#0
ESR value before enabling vector: 00000000
ESR value after enabling vector: 00000000
Using local APIC timer interrupts.
calibrating APIC timer ...
..... CPU clock speed is 599.0708 MHz.
..... host bus clock speed is 133.0268 MHz.
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xfb0e0, last bus=1
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20040326
ACPI: Interpreter disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
PnPBIOS: Scanning system for PnP BIOS support...
PnPBIOS: Found PnP BIOS installation structure at 0xc00fbd10
PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0xbd38, dseg 0xf0000
PnPBIOS: 15 nodes reported by PnP BIOS; 15 recorded by driver
ACPI: ACPI tables contain no PCI IRQ routing entries
PCI: Invalid ACPI-PCI IRQ routing table
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
PCI: Using IRQ router VIA [1106/0596] at 0000:00:07.0
VFS: Disk quotas dquot_6.5.1
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x0
Initializing Cryptographic API
Activating ISA DMA hang workarounds.
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 48 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
input: AT Translated Set 2 keyboard on isa0060/serio0
NET: Registered protocol family 2
IP: routing cache hash table of 2048 buckets, 16Kbytes
TCP: Hash tables configured (established 16384 bind 32768)
NET: Registered protocol family 8
NET: Registered protocol family 20
RAMDISK: cramfs filesystem found at block 0
RAMDISK: Loading 4556 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|done.
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 144k freed
SCSI subsystem initialized
libata version 1.02 loaded.
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:07.1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt82c596b (rev 12) IDE UDMA66 controller on pci0000:00:07.1
ide0: BM-DMA at 0xe000-0xe007, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xe008-0xe00f, BIOS settings: hdc:DMA, hdd:DMA
hda: Maxtor 6Y080L0, ATA DISK drive
hdb: QUANTUM FIREBALLlct08 17, ATA DISK drive
Using anticipatory io scheduler
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hdc: _NEC DV-5500A, ATAPI CD/DVD-ROM drive
hdd: SAMSUNG CD-R/RW SW-408B, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 160086528 sectors (81964 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(66)
/dev/ide/host0/bus0/target0/lun0: p1 p2 < p5 p6 p7 p8 p9 p10 >
hdb: max request size: 128KiB
hdb: 33906432 sectors (17360 MB) w/418KiB Cache, CHS=33637/16/63
/dev/ide/host0/bus0/target1/lun0: p1 p2 p3
p2: <bsd: p5 p6 p7 p8 p9 >
VFS: Can't find ext3 filesystem on dev hdb3.
VFS: Can't find ext2 filesystem on dev hdb3.
FAT: bogus number of reserved sectors
VFS: Can't find a valid FAT filesystem on dev hdb3.
Unable to identify CD-ROM format.
found reiserfs format "3.6" with standard journal
Reiserfs journal params: device hdb3, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
reiserfs: checking transaction log (hdb3) for (hdb3)
Using r5 hash to sort names
Adding 522072k swap on /dev/hda5. Priority:-1 extents:1
Real Time Clock Driver v1.12
drivers/usb/core/usb.c: registered new driver usbfs
drivers/usb/core/usb.c: registered new driver hub
drivers/usb/core/usb.c: registered new driver usbkbd
drivers/usb/input/usbkbd.c: :USB HID Boot Protocol keyboard driver
Linux agpgart interface v0.100 (c) Dave Jones
ide-scsi is deprecated for cd burning! Use ide-cd and give dev=/dev/hdX as device
scsi0 : SCSI host adapter emulation for IDE ATAPI devices
Vendor: _NEC Model: DV-5500A Rev: 1.42
Type: CD-ROM ANSI SCSI revision: 02
scsi1 : SCSI host adapter emulation for IDE ATAPI devices
Vendor: SAMSUNG Model: CD-R/RW SW-408B Rev: BS02
es1371: version v0.32 time 00:42:54 Apr 28 2004
PCI: Found IRQ 10 for device 0000:00:10.0
es1371: found chip, vendor id 0x1274 device id 0x1371 revision 0x06
es1371: found es1371 rev 6 at io 0xec00 irq 10 joystick 0x0
ac97_codec: AC97 Audio codec, id: 0x8384:0x7609 (SigmaTel STAC9721/23)
Capability LSM initialized
device-mapper: 4.1.0-ioctl (2003-12-10) initialised: dm@uk.sistina.com
NET: Registered protocol family 17
