Voila le cat /usr/sbin/update-rc.d
[code]#! /usr/bin/perl
update-rc.d Update the links in /etc/rc[0-9S].d/
use strict;
use warnings;
my $initd = “/etc/init.d”;
my $etcd = “/etc/rc”;
my $notreally = 0;
Print usage message and die.
sub usage {
print STDERR "update-rc.d: error: @\n" if ($# >= 0);
print STDERR <<EOF;
usage: update-rc.d [-n] [-f] remove
update-rc.d [-n] defaults [NN | SS KK]
update-rc.d [-n] start|stop NN runlvl [runlvl] […] .
update-rc.d [-n] disable|enable [S|2|3|4|5]
-n: not really
-f: force
The disable|enable API is not stable and might change in the future.
EOF
exit (1);
Dependency based boot sequencing is the default, but upgraded
systems might keep the legacy ordering until the sysadm choose to
migrate to the new ordering method.
if ( ! -f “/etc/init.d/.legacy-bootordering” ) {
info(“using dependency based boot sequencing”);
exit insserv_updatercd(@ARGV);
Check out options.
my $force;
my @orig_argv = @ARGV;
while($#ARGV >= 0 && ($_ = $ARGV[0]) =~ /^-/) {
shift @ARGV;
if (/^-n$/) { $notreally++; next }
if (/^-f$/) { $force++; next }
if (/^-h|–help$/) { &usage; }
&usage(“unknown option”);
sub save_last_action {
# No-op (archive removed)
sub remove_last_action {
Action.
&usage() if ($#ARGV < 1);
my $bn = shift @ARGV;
unless ($bn =~ m/[a-zA-Z0-9+.-]+/) {
print STDERR “update-rc.d: illegal character in name ‘$bn’\n”;
exit (1);
if ($ARGV[0] ne ‘remove’) {
if (! -f “$initd/$bn”) {
print STDERR “update-rc.d: $initd/$bn: file does not exist\n”;
exit (1);
&parse_lsb_header("$initd/$bn");
&cmp_args_with_defaults($bn, $ARGV[0], @ARGV);
} elsif (-f “$initd/$bn”) {
if (!$force) {
printf STDERR “update-rc.d: $initd/$bn exists during rc.d purge (use -f to force)\n”;
exit (1);
my @startlinks;
my @stoplinks;
$_ = $ARGV[0];
if (/^remove$/) { &checklinks (“remove”); remove_last_action($bn); }
elsif (/^defaults$/) { &defaults (@ARGV); &makelinks; save_last_action($bn, @orig_argv); }
elsif (/^(start|stop)$/) { &startstop (@ARGV); &makelinks; save_last_action($bn, @orig_argv); }
elsif (/^(dis|en)able$/) { &toggle (@ARGV); &makelinks; save_last_action($bn, @orig_argv); }
else { &usage; }
exit (0);
sub info {
print STDOUT “update-rc.d: @_\n”;
sub warning {
print STDERR “update-rc.d: warning: @_\n”;
sub error {
print STDERR “update-rc.d: error: @_\n”;
exit (1);
sub error_code {
my $rc = shift;
exit ($rc);
Check if there are links in /etc/rc[0-9S].d/
Remove if the first argument is “remove” and the links
point to $bn.
sub is_link () {
my ($op, $fn, $bn) = @_;
if (! -l $fn) {
warning “$fn is not a symbolic link\n”;
return 0;
} else {
my $linkdst = readlink ($fn);
if (! defined $linkdst) {
die (“update-rc.d: error reading symbolic link: $!\n”);
if (($linkdst ne “…/init.d/$bn”) && ($linkdst ne “$initd/$bn”)) {
warning “$fn is not a link to …/init.d/$bn or $initd/$bn\n”;
return 0;
return 1;
sub checklinks {
my ($i, $found, $fn, $islnk);
print " Removing any system startup links for $initd/$bn ...\n"
if (defined $_[0] && $_[0] eq 'remove');
$found = 0;
foreach $i (0..9, 'S') {
unless (chdir ("$etcd$i.d")) {
next if ($i =~ m/^[789S]$/);
die("update-rc.d: chdir $etcd$i.d: $!\n");
opendir(DIR, ".");
my $saveBN=$bn;
$saveBN =~ s/\+/\\+/g;
foreach $_ (readdir(DIR)) {
next unless (/^[SK]\d\d$saveBN$/);
$fn = "$etcd$i.d/$_";
$found = 1;
$islnk = &is_link ($_[0], $fn, $bn);
next unless (defined $_[0] and $_[0] eq 'remove');
if (! $islnk) {
print " $fn is not a link to ../init.d/$bn; not removing\n";
next;
print " $etcd$i.d/$_\n";
next if ($notreally);
unlink ("$etcd$i.d/$_") ||
die("update-rc.d: unlink: $!\n");
closedir(DIR);
$found;
sub parse_lsb_header {
my $initdscript = shift;
my %lsbinfo;
my $lsbheaders = “Provides|Required-Start|Required-Stop|Default-Start|Default-Stop”;
open(INIT, “<$initdscript”) || die “error: unable to read $initdscript”;
while () {
chomp;
$lsbinfo{‘found’} = 1 if (m/^### BEGIN INIT INFO\s*$/);
last if (m/### END INIT INFO\s*$/);
if (m/^# ($lsbheaders):\s*(\S?.*)$/i) {
$lsbinfo{lc($1)} = $2;
close(INIT);
# Check that all the required headers are present
if (!$lsbinfo{found}) {
printf STDERR "update-rc.d: warning: $initdscript missing LSB information\n";
printf STDERR "update-rc.d: see <http://wiki.debian.org/LSBInitScripts>\n";
} else {
for my $key (split(/\|/, lc($lsbheaders))) {
if (!exists $lsbinfo{$key}) {
warning "$initdscript missing LSB keyword '$key'\n";
Process the arguments after the “enable” or “disable” keyword.
sub toggle {
my @argv = @_;
my ($action, %lvls, @start, @stop, @xstartlinks);
if (!&checklinks) {
print " System start/stop links for $initd/$bn do not exist.\n";
exit (0);
$action = $argv[0];
if ($#argv > 1) {
while ($#argv > 0 && shift @argv) {
if ($argv[0] =~ /^[S2-5]$/) {
$lvls{$argv[0]}++;
} else {
&usage ("expected 'S' '2' '3' '4' or '5'");
} else {
$lvls{$_}++ for ('S', '2', '3', '4', '5');
push(@start, glob($etcd . '[2-5S].d/[KS][0-9][0-9]' . $bn));
foreach (@start) {
my $islink = &is_link (undef, $_, $bn);
next if !$islink;
next unless my ($lvl, $sk, $seq) = m/^$etcd([2-5S])\.d\/([SK])([0-9]{2})$bn$/;
$startlinks[$lvl] = $sk . $seq;
if ($action eq 'disable' and $sk eq 'S' and $lvls{$lvl}) {
$xstartlinks[$lvl] = 'K' . sprintf "%02d", (100 - $seq);
} elsif ($action eq 'enable' and $sk eq 'K' and $lvls{$lvl}) {
$xstartlinks[$lvl] = 'S' . sprintf "%02d", -($seq - 100);
} else {
$xstartlinks[$lvl] = $sk . $seq;
push(@stop, glob($etcd . '[016].d/[KS][0-9][0-9]' . $bn));
foreach (@stop) {
next if !$islink;
next unless my ($lvl, $sk, $seq) = m/^$etcd([016])\.d\/([SK])([0-9]{2})$bn$/;
$stoplinks[$lvl] = $sk . $seq;
if ($action eq 'disable') {
print " Disabling system startup links for $initd/$bn ...\n";
} elsif ($action eq 'enable') {
print " Enabling system startup links for $initd/$bn ...\n";
&checklinks ("remove");
@startlinks = @xstartlinks;
1;
Process the arguments after the “defaults” keyword.
sub defaults {
my @argv = @_;
my ($start, $stop) = (20, 20);
&usage ("defaults takes only one or two codenumbers") if ($#argv > 2);
$start = $stop = $argv[1] if ($#argv >= 1);
$stop = $argv[2] if ($#argv >= 2);
&usage ("codenumber must be a number between 0 and 99")
if ($start !~ /^\d\d?$/ || $stop !~ /^\d\d?$/);
$start = sprintf("%02d", $start);
$stop = sprintf("%02d", $stop);
$stoplinks[$_] = "K$stop" for (0, 1, 6);
$startlinks[$_] = "S$start" for (2, 3, 4, 5);
1;
Process the arguments after the start or stop keyword.
sub startstop {
my @argv = @_;
my($letter, $NN, $level);
while ($#argv >= 0) {
if ($argv[0] eq 'start') { $letter = 'S'; }
elsif ($argv[0] eq 'stop') { $letter = 'K'; }
else {
&usage("expected start|stop");
if ($argv[1] !~ /^\d\d?$/) {
&usage("expected NN after $argv[0]");
$NN = sprintf("%02d", $argv[1]);
if ($argv[-1] ne '.') {
&usage("start|stop arguments not terminated by \".\"");
shift @argv; shift @argv;
$level = shift @argv;
do {
if ($level !~ m/^[0-9S]$/) {
&usage(
"expected runlevel [0-9S] (did you forget \".\" ?)");
if (! -d "$etcd$level.d") {
print STDERR
"update-rc.d: $etcd$level.d: no such directory\n";
exit(1);
$level = 99 if ($level eq 'S');
$startlinks[$level] = "$letter$NN" if ($letter eq 'S');
$stoplinks[$level] = "$letter$NN" if ($letter eq 'K');
} while (($level = shift @argv) ne '.');
1;
Create the links.
sub makelinks {
my($t, $i);
my @links;
if (&checklinks) {
print " System start/stop links for $initd/$bn already exist.\n";
return 0;
print " Adding system startup for $initd/$bn ...\n";
# nice unreadable perl mess :)
for($t = 0; $t < 2; $t++) {
@links = $t ? @startlinks : @stoplinks;
for($i = 0; $i <= $#links; $i++) {
my $lvl = $i;
$lvl = 'S' if ($i == 99);
next if (!defined $links[$i] or $links[$i] eq '');
print " $etcd$lvl.d/$links[$i]$bn -> ../init.d/$bn\n";
symlink("../init.d/$bn", "$etcd$lvl.d/$links[$i]$bn")
|| die("update-rc.d: symlink: $!\n");
1;
Dependency based
sub insserv_updatercd {
my @args = @_;
my @opts;
my $scriptname;
my $action;
my $notreally = 0;
my @orig_argv = @args;
while($#args >= 0 && ($_ = $args[0]) =~ /^-/) {
shift @args;
if (/^-n$/) { push(@opts, $_); $notreally++; next }
if (/^-f$/) { push(@opts, $_); next }
if (/^-h|--help$/) { &usage; }
usage("unknown option");
usage("not enough arguments") if ($#args < 1);
$scriptname = shift @args;
$action = shift @args;
if ("remove" eq $action) {
if ( -f "/etc/init.d/$scriptname" ) {
my $rc = system("/sbin/insserv", @opts, "-r", $scriptname) >> 8;
if (0 == $rc && !$notreally) {
remove_last_action($scriptname);
error_code($rc, "insserv rejected the script header") if $rc;
exit $rc;
} else {
# insserv removes all dangling symlinks, no need to tell it
# what to look for.
my $rc = system("insserv", @opts) >> 8;
exit $rc;
} elsif ("defaults" eq $action || "start" eq $action ||
"stop" eq $action) {
# All start/stop/defaults arguments are discarded so emit a
# message if arguments have been given and are in conflict
# with Default-Start/Default-Stop values of LSB comment.
cmp_args_with_defaults($scriptname, $action, @args);
my $rc = system("insserv", @opts, $scriptname) >> 8;
save_last_action($scriptname, @orig_argv);
exit $rc;
} else {
error("initscript does not exist: /etc/init.d/$scriptname");
} elsif ("disable" eq $action || "enable" eq $action) {
insserv_toggle($notreally, $action, $scriptname, @args);
# Call insserv to resequence modified links
exit $rc;
} else {
usage();
sub parse_def_start_stop {
my $script = shift;
my (%lsb, @def_start_lvls, @def_stop_lvls);
open my $fh, '<', $script or error("unable to read $script");
while (<$fh>) {
chomp;
if (m/^### BEGIN INIT INFO$/) {
$lsb{'begin'}++;
elsif (m/^### END INIT INFO$/) {
$lsb{'end'}++;
last;
elsif ($lsb{'begin'} and not $lsb{'end'}) {
if (m/^# Default-Start:\s*(\S?.*)$/) {
@def_start_lvls = split(' ', $1);
if (m/^# Default-Stop:\s*(\S?.*)$/) {
@def_stop_lvls = split(' ', $1);
close($fh);
return (\@def_start_lvls, \@def_stop_lvls);
sub lsb_header_for_script {
my $name = shift;
foreach my $file ("/etc/insserv/overrides/$name", "/etc/init.d/$name",
"/usr/share/insserv/overrides/$name") {
return $file if -s $file;
error("cannot find a LSB script for $name");
sub cmp_args_with_defaults {
my ($name, $act) = (shift, shift);
my ($lsb_start_ref, $lsb_stop_ref, $arg_str, $lsb_str);
my (@arg_start_lvls, @arg_stop_lvls, @lsb_start_lvls, @lsb_stop_lvls);
my $default_msg = ($act eq ‘defaults’) ? ‘default’ : ‘’;
($lsb_start_ref, $lsb_stop_ref) = parse_def_start_stop("/etc/init.d/$name");
@lsb_start_lvls = @$lsb_start_ref;
@lsb_stop_lvls = @$lsb_stop_ref;
return if (!@lsb_start_lvls and !@lsb_stop_lvls);
if ($act eq 'defaults') {
@arg_start_lvls = (2, 3, 4, 5);
@arg_stop_lvls = (0, 1, 6);
} elsif ($act eq 'start' or $act eq 'stop') {
my $start = $act eq 'start' ? 1 : 0;
my $stop = $act eq 'stop' ? 1 : 0;
# The legacy part of this program passes arguments starting with
# "start|stop NN x y z ." but the insserv part gives argument list
# starting with sequence number (ie. strips off leading "start|stop")
# Start processing arguments immediately after the first seq number.
my $argi = $_[0] eq $act ? 2 : 1;
while (defined $_[$argi]) {
my $arg = $_[$argi];
# Runlevels 0 and 6 are always stop runlevels
if ($arg eq 0 or $arg eq 6) {
$start = 0; $stop = 1;
} elsif ($arg eq 'start') {
$start = 1; $stop = 0; $argi++; next;
} elsif ($arg eq 'stop') {
$start = 0; $stop = 1; $argi++; next;
} elsif ($arg eq '.') {
next;
push(@arg_start_lvls, $arg) if $start;
push(@arg_stop_lvls, $arg) if $stop;
} continue {
$argi++;
if ($#arg_start_lvls != $#lsb_start_lvls or
join("\0", sort @arg_start_lvls) ne join("\0", sort @lsb_start_lvls)) {
$arg_str = @arg_start_lvls ? "@arg_start_lvls" : "none";
$lsb_str = @lsb_start_lvls ? "@lsb_start_lvls" : "none";
warning "$default_msg start runlevel arguments ($arg_str) do not match",
"$name Default-Start values ($lsb_str)";
if ($#arg_stop_lvls != $#lsb_stop_lvls or
join("\0", sort @arg_stop_lvls) ne join("\0", sort @lsb_stop_lvls)) {
$arg_str = @arg_stop_lvls ? "@arg_stop_lvls" : "none";
$lsb_str = @lsb_stop_lvls ? "@lsb_stop_lvls" : "none";
warning "$default_msg stop runlevel arguments ($arg_str) do not match",
"$name Default-Stop values ($lsb_str)";
sub insserv_toggle {
my ($dryrun, $act, $name) = (shift, shift, shift);
my (@toggle_lvls, $start_lvls, $stop_lvls, @symlinks);
my $lsb_header = lsb_header_for_script($name);
# Extra arguments to disable|enable action are runlevels. If none
# given parse LSB info for Default-Start value.
if ($#_ >= 0) {
@toggle_lvls = @_;
} else {
($start_lvls, $stop_lvls) = parse_def_start_stop($lsb_header);
@toggle_lvls = @$start_lvls;
if ($#toggle_lvls < 0) {
error("$name Default-Start contains no runlevels, aborting.");
# Find symlinks in rc.d directories. Refuse to modify links in runlevels
# not used for normal system start sequence.
for my $lvl (@toggle_lvls) {
if ($lvl !~ /^[S2345]$/) {
warning("$act action will have no effect on runlevel $lvl");
next;
push(@symlinks, $_) for glob("/etc/rc$lvl.d/[SK][0-9][0-9]$name");
if (!@symlinks) {
error("no runlevel symlinks to modify, aborting!");
# Toggle S/K bit of script symlink.
for my $cur_lnk (@symlinks) {
my $sk;
my @new_lnk = split(//, $cur_lnk);
if ("disable" eq $act) {
$sk = rindex($cur_lnk, '/S') + 1;
next if $sk < 1;
$new_lnk[$sk] = 'K';
} else {
$sk = rindex($cur_lnk, '/K') + 1;
next if $sk < 1;
$new_lnk[$sk] = 'S';
if ($dryrun) {
printf("rename(%s, %s)\n", $cur_lnk, join('', @new_lnk));
next;
rename($cur_lnk, join('', @new_lnk)) or error($!);
}[/code]
Par contre le aptitude search ~c ne me retourne rien.
Et depuis trusty ubuntu j’avais installé aucun paquet à part gcc-multilib mais ça avait échoué. J’avais juste fait du apt-get update/upgrade.
