Bon, voila les résultats :
# aptitude -s safe-upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Reading extended state information
Initializing package states... Done
Reading task descriptions... Done
open: 23; closed: 4997; defer: 6678; conflict: 7 oThe following packages have unmet dependencies:
libc6: Depends: libc-bin (= 2.13-38) but 2.11.2-2 is installed and it is kept back.
[code]# aptitude -s full-upgrade
Reading package lists… Done
Reading state information… Done
Initializing package states… Done
Reading task descriptions… Done
The following packages are BROKEN:
libc6 libept0 libxcb1
The following NEW packages will be installed:
apache2.2-bin{a} apt-xapian-index{a} dash{a} diffutils{a} dmsetup{a} geoip-database{a} gnupg-curl{a} insserv{a} install-info{a} isc-dhcp-client{a} isc-dhcp-common{a} iso-codes{a}
libaprutil1-dbd-sqlite3{a} libaprutil1-ldap{a} libavahi-core7{a} libbind9-60{a} libboost-iostreams1.42.0{a} libbsd0{a} libcap-ng0{a} libcurl3-gnutls{a} libdns69{a} libept1{a}
libfile-copy-recursive-perl{a} libgeoip1{a} libisc62{a} libisccc60{a} libisccfg62{a} liblwres60{a} libnfnetlink0{a} libonig2{a} libparted0debian1{a} libpci3{a} libpython2.6{a} libqdbm14{a}
libudev0{a} libxapian22{a} lsb-release{a} pciutils{a} php5-suhosin{a} python-apt{a} python-apt-common{a} python-central{a} python-chardet{a} python-debian{a} python-support{a} python-xapian{a}
python2.6{a} python2.6-minimal{a} sensible-utils{a} usbutils{a}
The following packages will be upgraded:
adduser apache2 apache2-mpm-prefork apache2-utils apache2.2-common apt apt-utils aptitude avahi-autoipd avahi-daemon avahi-utils base-files base-passwd bash bind9-host binutils bsdmainutils
bsdutils bzip2 ca-certificates coreutils cpio cracklib-runtime cron curl dbus dbus-x11 debconf debconf-i18n debian-archive-keyring debianutils dhcp3-client dhcp3-common dictionaries-common diff
dnsutils dosfstools dpkg e2fslibs e2fsprogs ed ethtool ffmpeg file findutils gcc-4.3-base gcc-4.4-base gdb gdbserver gnupg gpgv grep groff-base gzip hostname ifplugd ifupdown info initscripts
iproute iptables iputils-ping libacl1 libapache2-mod-php5 libapr1 libaprutil1 libasound2 libattr1 libavahi-client3 libavahi-common-data libavahi-common3 libavcodec-dev libavcodec52 libavdevice52
libavfilter0 libavformat-dev libavformat52 libavutil-dev libavutil49 libblkid1 libbz2-1.0 libc-bin libcap2 libcomerr2 libconsole libcrack2 libcups2 libcurl3 libcwidget3 libdaemon0 libdb4.6
libdb4.8 libdbus-1-3 libdc1394-22 libdevmapper1.02.1 libdirectfb-1.2-9 libedit2 libexpat1 libfaad2 libfontenc1 libfreetype6 libgcc1 libgdbm3 libgomp1 libgssapi-krb5-2 libgssglue1 libk5crypto3
libkeyutils1 libkrb5-3 libkrb53 libkrb5support0 libldap-2.4-2 liblocale-gettext-perl liblockfile1 liblzma2 libmagic1 libncurses5 libncursesw5 libnewt0.52 libnfsidmap2 libnss-mdns libogg0
libopenjpeg2 liborc-0.4-0 libpam-modules libpam-runtime libpam0g libparted0 libpng12-0 libpostproc51 libpq5 libraw1394-11 libreadline5 libreadline6 librpcsecgss3 libsasl2-2 libsdl1.2debian
libsdl1.2debian-oss libselinux1 libsepol1 libsigc+±2.0-0c2a libslang2 libsqlite0 libss2 libssh2-1 libssl0.9.8 libstdc++6 libswscale0 libsysfs2 libtasn1-3 libtext-charwidth-perl
libtext-iconv-perl libtext-wrapi18n-perl libtheora0 libupnp3 libusb-0.1-4 libusb-1.0-0 libuuid1 libvorbis0a libvorbisenc2 libwrap0 libx11-6 libx11-data libxau6 libxdmcp6 libxext6 libxml2
libxmuu1 libxslt1.1 lockfile-progs login logrotate lsb-base lsof mac-fdisk makedev man-db manpages mawk mdadm mktemp module-init-tools mount mysql-common nano ncurses-base ncurses-bin net-tools
netbase nfs-common ntpdate openssh-client openssh-server openssl openvpn parted passwd perl perl-base perl-modules php-apc php5 php5-cli php5-common php5-curl php5-sqlite portmap powerpc-utils
procps psmisc python python-minimal python2.5 python2.5-minimal readline-common rsync rsyslog sed sgml-base smartmontools sudo sysv-rc sysvinit sysvinit-utils tar tasksel tasksel-data tcpd
traceroute tzdata ucf udev unzip update-inetd util-linux vim-common vim-tiny vsftpd wfinnish wget whiptail x11-common xauth xfsprogs xml-core xmlstarlet xz-utils yaboot zlib1g
The following partially installed packages will be configured:
libc6-ppc64 locales
The following packages are RECOMMENDED but will NOT be installed:
aptitude-doc-cs aptitude-doc-en aptitude-doc-es aptitude-doc-fi aptitude-doc-fr aptitude-doc-ja bash-completion bsd-mailx citadel-mta courier-mta dma esmtp-run exim4 exim4-daemon-heavy
exim4-daemon-light heirloom-mailx hfsutils laptop-detect libatm1 libfribidi0 libgpm2 libparse-debianchangelog-perl libsasl2-modules mailutils masqmail msmtp-mta nullmailer postfix sendmail-bin
ssl-cert ssmtp uuid-runtime xmail
250 packages upgraded, 50 newly installed, 0 to remove and 0 not upgraded.
Need to get 119MB/123MB of archives. After unpacking 82.3MB will be used.
libxcb1: Breaks: libxcb-xlib0 but 1.1-1.2 is installed.
libept0: Depends: libapt-pkg-libc6.7-6-4.6 which is a virtual package.
libc6: Depends: libc-bin (= 2.13-38) but 2.11.3-4 is to be installed.
The following actions will resolve these dependencies:
Remove the following packages:
libc6-ppc64
libept0
libxcb-xlib0
locales
Install the following packages:
libsasl2-modules [2.1.23.dfsg1-7 (oldstable)]
Downgrade the following packages:
libc6 [2.13-38 (now) -> 2.11.3-4 (oldstable)][/code]
Ensuite, il m’offre tout plein de propositions avec un score. Il représente quoi ce score ? oO
# dpkg -l | grep libc-bin
ii libc-bin 2.11.2-2 Embedded GNU C Library: Binaries
[code]# aptitude -s remove --purge libc-bin
libc6
The following packages will be REMOVED:
libc-bin
libc6-ppc64 locales
0 packages upgraded, 0 newly installed, 1 to remove and 249 not upgraded.
Need to get 0B of archives. After unpacking 1679kB will be freed.
libc6: Depends: libc-bin (= 2.13-38) but it is not installable
libc6-ppc64
locales
Upgrade the following packages:
libc-bin [2.11.2-2 (now) -> 2.11.3-4 (oldstable)]
Score is -9770
Accept this solution? [Y/n/q/?] [/code]
Là je perds tout plein de points, dans mon score ^^’
