[quote]LMG:/home/langly# lspci | grep 14.4
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge[/quote]
Il n’y a pas ma carte graphique (Radeo 3200 HD intégrée à la carte mère)
00:00.0 Host bridge: Advanced Micro Devices [AMD] RS780 Host Bridge
00:01.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (int gfx)
00:0a.0 PCI bridge: Advanced Micro Devices [AMD] RS780 PCI to PCI bridge (PCIE port 5)
00:11.0 SATA controller: ATI Technologies Inc SB700/SB800 SATA Controller [IDE mode]
00:12.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller
00:12.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller
00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller
00:13.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller
00:13.1 USB Controller: ATI Technologies Inc SB700 USB OHCI1 Controller
00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 3a)
00:14.1 IDE interface: ATI Technologies Inc SB700/SB800 IDE Controller
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
00:14.3 ISA bridge: ATI Technologies Inc SB700/SB800 LPC host controller
00:14.5 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI2 Controller
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:05.0 VGA compatible controller: ATI Technologies Inc Radeon HD 3200 Graphics
01:05.1 Audio device: ATI Technologies Inc RS780 Azalia controller
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 02)
03:0e.0 FireWire (IEEE 1394): Texas Instruments TSB43AB23 IEEE-1394a-2000 Controller (PHY/Link)
Sinon j’ai modifié les miroirs Debian dans le source.list et j’ai celui des US. maintenant mon apt fonctionne. J’ai réussi à installé une appli. Par contre si je met celui de la Belgique ou de la France sa plante comme dans mon premier post.
Autre point, hier j’ai installé iceweasel tant que bien que mal, maintenant il me fait de nombreuses erreurs de segment seulement quand je clique sur certain lien (et toujours les même !!!). J’essaye de le désinstaller mais:
[quote]LMG:/home/langly# apt-get remove iceweasel
Erreur de segmentation
Vous pensez que cela vient de l’installation des drivers ATI
It is possible that the compressed file(s) have become corrupted.
You can use the -tvv option to test integrity of such files.
You can use the `bzip2recover’ program to attempt to recover
data from undamaged sections of corrupted files.
Err ftp.fr.debian.org sid/main Packages
Le sous-processus /bin/bzip2 a renvoyé un code d’erreur (2)
6 222ko réceptionnés en 5s (1 144ko/s)
W: Impossible de récupérer ftp.fr.debian.org/debian/dists/s … ckages.bz2 Le sous-processus /bin/bzip2 a renvoyé un code d’erreur (2)
E: Le téléchargement de quelques fichiers d’index a échoué, ils ont été ignorés, ou les anciens ont été utilisés à la place.
EDIT: je retire ce que j’ai dis. J’ai encore des segmentation false avec iceweasel avec le driver vesa.
La nouvelle erreur concernant l’apt-get update est apparu après avoir supprimé le paquet ia32-libs qui était nécessaire à l’installation des drivers proprio. J’ai toujours plein de problème avec cette lib.
Et pour les drivers concernant ma carte graphique, qu’est ce que je peux faire?
Il faut que je désinstalle les pilotes proprio et que j’installe les drivers Debian?
J’ai trouvé le problème.
C’est encore une fois ma RAM. J’avais des problèmes déjà avec pour l’installation de Debian… Je pensais que c’était réglé mais non
Bref apparement ma RAM est assez instable lorsqu’il y a deux barrettes. maintenant je tourne avec une seule barrette. Après plusieurs pass avec memtest86+, plus d’erreur de mémoire ni d’erreurs avec apt. J’ai installé les driver ATI et sa fonctionne à par un tout petit problème (j’ouvre un autre post pour celui là).
Donc me voila bon pour racheter de bonnes barrettes.
