bonjour,
j’essaye d’enregistrer la sortie audio de mon pc avec :
l’enregistrement est très très faible (comme un son lointain).
la je pige pas !
j’ai tester hw:0,1 etc … rien ou pareil
[code]arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC888 Analog [ALC888 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: ALC888 Digital [ALC888 Digital]
Subdevices: 1/1
card 0: Intel [HDA Intel], device 2: ALC888 Analog [ALC888 Analog]
Subdevices: 1/1
card 1: SAA7134 [SAA7134], device 0: SAA7134 PCM [SAA7134 PCM]
Subdevices: 1/1
arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=Intel
HDA Intel, ALC888 Analog
Default Audio Device
front:CARD=Intel,DEV=0
Front speakers
surround40:CARD=Intel,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Intel,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Intel,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Intel,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Intel,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Intel,DEV=0
HDA Intel, ALC888 Digital
IEC958 (S/PDIF) Digital Audio Output
default:CARD=SAA7134
SAA7134, SAA7134 PCM
en pièce jointe la capture de alsamixer
merci de votre aide
svp: je reste en ligne de commande, pas de GUI
