ARM v7 (AML-8726) - debian
Oui,
[] Enable loadable module support —>
— Enable loadable module support
[ ] Forced module loading
] Module unloading
[ ] Forced module unloading
[] Module versioning support
] Source checksum for all modules
make modules_install
INSTALL drivers/amlogic/mali/mali.ko
INSTALL drivers/amlogic/ump/ump.ko
INSTALL drivers/amlogic/wifi/rtl8xxx_CU/8192cu.ko
INSTALL drivers/media/video/gspca/gspca_main.ko
INSTALL drivers/scsi/scsi_wait_scan.ko
DEPMOD 2.6.34
Merci. J’ai copié le repertoire 2.6.34 sur la SD dans /lib/modules
La fin de la trace :
[ 3.671000] cardblksd: cardblksd1
[ 3.775000] EXT2-fs (cardblksd1): warning: mounting unchecked fs, running e2fsck is recommended
[ 3.778000] VFS: Mounted root (ext2 filesystem) on device 253:1.
[ 3.784000] init_post.
[ 3.787000] Freeing init memory: 152K
[ 3.790000] run_init_process /init.
INIT: version 2.88 booting
Using makefile-style concurrent boot in runlevel S.
.udev/ already exists on the static /dev! … (warning).
Starting the hotplug events dispatcher: udevd.
Synthesizing the initial hotplug events…done.
Waiting for /dev to be fully populated…done.
Activating swap…done.
Cleaning up ifupdown…
Setting up networking…
Loading kernel modules…done.
Activating lvm and md swap…done.
Checking file systems…fsck from util-linux-ng 2.17.2
done.
Mounting local filesystems…done.
Activating swapfile swap…done.
Cleaning up temporary files…
Configuring network interfaces…[ 13.822000] netdev_open
Setting kernel variables …done.
INIT: Entering runlevel: 2
Using makefile-style concurrent boot in runlevel 2.
Debian GNU/Linux 6.0 serveur ttyS0
serveur login:
Ci-joint pour info, l’environnement U-boot et le .config qui ont fonctionné. Le kernel est bien entendu compilé avec (Linux version 2.6.34 (root@serveur) (gcc version 4.5.2 (Sourcery G++ Lite 2011.03-41) ) #7 PREEMPT Sat Jan 19 08:11:14 CET 2013)
env-uboot.txt (1.33 KB)
_.config.txt (62.5 KB)
Le modèle exacte de ton AML-8726-MX, c’est un M1, M3, ou M6 ?
Le MX est un double coeur. Le mien est un M1 seulement.
Si ton pb est résolu, merci de mettre la coche verte
Pour info j’ai fait un diff pour comparer ce .config avec le précédent que tu avais joint, et n’ai pas vu de différence susceptible d’expliquer pourquoi ça marche maintenant mais pas avant.
Pascal,
A ce moment là, pour aller plus loin dans ce sens, Si j’ai le temps ce soir, j’essayerai de poster deux différents fichiers .config pour les comparer. J’ai gardé quelques différents fichiers .config et noyaux correspondants, ceux qui fonctionnent ou pas.
Je peux aussi recompiler le noyau dans sa bonne config mais avec un compilateur plus récent pour voir s’il fonctionne.
J’aimerai bien savoir ce qui s’est passé vu le nombre d’heures que j’ai passé dessus.
As tu comparé tes variables uboot avant/après ?
Trop long…J’ai arrêté de chercher sur le problème du rootfs et la SD pour avancer sur l’installation des applications sur le device.
Je coche pour dire que le problème est résolu. J’ouvre un autre sujet pour squid
