[Asus M51Tr] Problème d'USB => super lent
Je continue avec l’usb.
Lorsque je connecte mon DD externe celui-ci met un temps fou à être reconnu et lorsqu’il veut bien l’être, j’ai l’impression d’être revenu à l’âge de pierre avec un debit proche du néant (40mn pour copier 700Mo…).
# dmesg
[ 4887.308053] usb 5-4: new high speed USB device using ehci_hcd and address 9
[ 4902.456053] usb 5-4: device descriptor read/64, error -110
[ 4917.708079] usb 5-4: device descriptor read/64, error -110
[ 4917.924058] usb 5-4: new high speed USB device using ehci_hcd and address 10
[ 4933.072115] usb 5-4: device descriptor read/64, error -110
[ 4948.324085] usb 5-4: device descriptor read/64, error -110
[ 4948.540071] usb 5-4: new high speed USB device using ehci_hcd and address 11
[ 4958.972039] usb 5-4: device not accepting address 11, error -110
[ 4959.084083] usb 5-4: new high speed USB device using ehci_hcd and address 12
[ 4969.516038] usb 5-4: device not accepting address 12, error -110
[ 4969.516088] hub 5-0:1.0: unable to enumerate USB device on port 4
[ 4969.852062] usb 2-1: new full speed USB device using ohci_hcd and address 4
[ 4970.008053] usb 2-1: not running at top speed; connect to a high speed hub
[ 4970.020145] usb 2-1: configuration #1 chosen from 1 choice
[ 4970.028258] scsi6 : SCSI emulation for USB Mass Storage devices
[ 4970.028390] usb-storage: device found at 4
[ 4970.028395] usb-storage: waiting for device to settle before scanning
[ 4970.028411] usb 2-1: New USB device found, idVendor=1058, idProduct=1100
[ 4970.028501] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4970.028501] usb 2-1: Product: My Book
[ 4970.028501] usb 2-1: Manufacturer: Western Digital
[ 4970.028501] usb 2-1: SerialNumber: 57442D574341535532313734343039
[ 4975.028069] usb-storage: device scan complete
[ 4975.032080] scsi 6:0:0:0: Direct-Access     WD       5000AAV External 1.65 PQ: 0 ANSI: 4
[ 4975.043966] sd 6:0:0:0: [sdb] 976773168 512-byte hardware sectors (500108 MB)
[ 4975.053945] sd 6:0:0:0: [sdb] Write Protect is off
[ 4975.053953] sd 6:0:0:0: [sdb] Mode Sense: 21 00 00 00
[ 4975.053957] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 4975.063910] sd 6:0:0:0: [sdb] 976773168 512-byte hardware sectors (500108 MB)
[ 4975.073895] sd 6:0:0:0: [sdb] Write Protect is off
[ 4975.073903] sd 6:0:0:0: [sdb] Mode Sense: 21 00 00 00
[ 4975.073905] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 4975.073910]  sdb: sdb1
[ 4975.528258] sd 6:0:0:0: [sdb] Attached SCSI disk
[ 4975.528341] sd 6:0:0:0: Attached scsi generic sg2 type 0
# fdisk -l:
Disk /dev/sdb: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
Disk identifier: 0x44fdfe06
   Device Boot      Start         End      Blocks   Id  System
/dev/sdb1               1       60801   488384001    7  HPFS/NTFS
# lsusb:
Bus 002 Device 004: ID 1058:1100 Western Digital Technologies, Inc.
Si une idée vous passe par la tête…
Quel que sit le port usb sur lequel tu te branche ?
Tu as des options à tatonner dans ton bios, concernant l’USB ?
Oui, quelque soit le port usb.
Au niveau du bios, y’a pas grand chose et rien à propos de l’usb, mis à part le fait que je puisse booter sur de l’usb…
Ca me dit quelquechose, mais je ne retrouve pas…
Re,
désolé pour le temps de réponse, j’ai eu un problème avec mon pc, j’ai fait un truc que j’aurais pas du faire et mon installation de debian à foiré, donc obligé de réinstaller ect…
Bref, tout ça pour dire qu’avec cette nouvelle installation, plus de problème d’usb, le disque est reconnu en l’espace de quelques secondes et le taux de transfert est plus qu’acceptable :mrgreen:
Je cherche pas trop à comprendre, mais je crois que je vais faire une image illico de cette install qui m’a tout l’air de marcher du feu de dieux (excepté toujours le son -> je vais tester ce que tu m’as dit sur l’autre post).
@ pluch.
