Ati catalyst control center ne se lance pas
bonsoir
je viens installer les pilotes fourni par ati, la qualite de l’image et la resolution ont change en bien,
mais catalyst control center ne veut pas se lance
j’ai trouver divers infos sur le net, de rajouter à X11.conf
Section "Files"
    ModulePath   "/usr/lib/xorg/modules/extensions/fglrx"
    ModulePath   "/usr/lib/xorg/modules"
EndSection
et de lance depuis le terminal
amdcccle
resultat:
Session management error: Authentication Rejected, reason : None of the authentication protocols specified are supported and host-based authentication failed
X Error: BadRequest (invalid request code or no such operation) 1
  Extension:    144 (Uknown extension)
  Minor opcode: 19 (Unknown request)
  Resource id:  0x5a
amdcccle: ../../src/xcb_io.c:461: _XRead:  l'assertion « dpy->xcb->reply_data != 0 » a échoué.
Abandon
mais la je nage ou plutot je coule
merci pour votre aide
C’est étonnant, mon x11.conf n’a pas de “file”:
Section "Files"
EndSection
Section "Module"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver “fglrx”
#Do not remove this option or try a lower resolution cursor bug
Option “SWCursor” "true"
BusID "PCI:2:0:0"
EndSection
Dans la section Device, c’est bien les fglrx qui aparaissent?
si tu lance la commande fglrxinfo, ca te retourne quoi?
la commande fglrxinfo me retourne
X Error of failed request:  BadRequest (invalid request code or no such operation)
  Major opcode of failed request:  144 (GLX)
  Minor opcode of failed request:  19 (X_GLXQueryServerString)
  Serial number of failed request:  12
  Current serial number in output stream:  12
edition de Xorg.conf
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
	Identifier     "aticonfig Layout"
	Screen      0  "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Files"
EndSection
Section "Module"
EndSection
Section "InputDevice"
	Identifier  "Generic Keyboard"
	Driver      "kbd"
	Option	    "XkbRules" "xorg"
	Option	    "XkbModel" "pc105"
	Option	    "XkbLayout" "fr"
	Option	    "XkbVariant" "latin9"
EndSection
	Identifier  "Configured Mouse"
	Driver      "mouse"
EndSection
Section "Monitor"
	Identifier   "Configured Monitor"
EndSection
Section "Monitor"
	Identifier   "aticonfig-Monitor[0]-0"
	Option	    "VendorName" "ATI Proprietary Driver"
	Option	    "ModelName" "Generic Autodetecting Monitor"
	Option	    "DPMS" "true"
EndSection
Section "Device"
EndSection
Section "Device"
	Driver      "fglrx"
	BusID       "PCI:1:0:0"
EndSection
Section "Screen"
	Identifier "Default Screen"
	Monitor    "Configured Monitor"
EndSection
Section "Screen"
	Identifier "aticonfig-Screen[0]-0"
	Device     "aticonfig-Device[0]-0"
	Monitor    "aticonfig-Monitor[0]-0"
	DefaultDepth     24
	SubSection "Display"
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
et si j’enleve le contenu de Section “Files”, c’est la commande amdcccle qui ne repond plus
une idée ?
Roflll,
Oui, une idée, j’ai eu le meme probleme hier memes erreurs de fglrxinfo. La démarche que j’ai eu peut peut etre te laisser bloquer sans interface graphique… mais on ne sait jamais: pour moi, ca a marché
Télécharge les drivers depuis le site de ATI
laisse les dans tes document et ouvre une console su
puis suit le tuto ici: (imprime le avant pour la partie en console)
wiki.debian.org
Si jamais, au cours du tuto # modprobe fglrx renvoi une erreur, ne cherche pas a remettre les anciens drivers. A la place fais:
suit l’install puis un startx a la fin devrait fonctionner.
Je te conseil vivement, cependant de modifier le /etc/X11/xorg.conf en éditant la section Device ou fglrx aparait: ajoute la ligne
Option “SWCursor” “true” comme dans le mien afin d’eviter un bug de disparition du curseur de la souris au moment du changement de résolution.
merci pour l’idée, mais perte du bureau gdm erreur server X
une autre idée
