ATI et erreur de chargement libGL
Salut à tous,
Je viens d’installer les nouveaux pilote ATI 8.41.7, et j’ai suivi la doc qui se trouve ici en changeant quelques petits paramètres, j’ai modifié mon fichier xorg.conf comme ceci :
[code]# xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Device"
Identifier "ATI Technologies Inc RV350 AP [Radeon 9600]"
Driver "fglrx"
Option “VideoOverlay” "on"
Option “OpenGLOverlay” "off"
BusID "PCI:1:0:0"
VideoRam 128000
Option “UseFBDev” "true"
EndSection
#pour section device add :
Option “VideoOverlay” “on”
Option “OpenGLOverlay” “off”
Section "Monitor"
Identifier "CM1770NSL"
Option "DPMS"
HorizSync 30-68
VertRefresh 50-85
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc RV350 AP [Radeon 9600]"
Monitor "CM1770NSL"
DefaultDepth 24
SubSection "Display"
Modes “1280x1024” “1152x864” “1024x768” “800x600” "640x480"
EndSubSection
EndSection
Section "ServerLayout"
Option “AIGLX” "false"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "Extensions"
Option “Composite” "disable"
EndSection[/code]
Ensuite un redémarrage je teste un petit fglrxinfo et je reçois ce message :
# fglrxinfo
fglrxinfo: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
Une personne connaitrais la solution à ce petit problème SVP ?
Merci beaucoup d’avance.
PS : je suis sous Debian Sid/lenny et dans le fichier /etc/modules j’ai rajouté le chargement de fglrx. pour ceux qui souhaitent les pilotes sont en téléchargement ici : a248.e.akamai.net/f/674/9206/0/ … x86_64.run
je viens de voir qu il me manque une librairie :
$ ldd `which fgl_glxgears`
        linux-gate.so.1 =>  (0xffffe000)
        libGL.so.1 => not found
        libX11.so.6 => /usr/lib/libX11.so.6 (0xb7eba000)
        libXext.so.6 => /usr/lib/libXext.so.6 (0xb7eac000)
        libm.so.6 => /lib/i686/cmov/libm.so.6 (0xb7e87000)
        libc.so.6 => /lib/i686/cmov/libc.so.6 (0xb7d3f000)
        libXau.so.6 => /usr/lib/libXau.so.6 (0xb7d3b000)
        libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0xb7d36000)
        libdl.so.2 => /lib/i686/cmov/libdl.so.2 (0xb7d32000)
        /lib/ld-linux.so.2 (0xb7fb9000)
arf les drivers proprios çay mal :laughing:
j’ai jamais réussi à avoir une accélération 3D fonctionnelle avec cette chiotte :imp:
je te conseille d’utiliser les pilotes fournis par Debian :wink:
1/ modifies ton fichier /etc/apt/sources.list pour y inclure les déports non-free (il y a un topic consacré aux sources.list dans pause café au cas où :wink: )
2/ apt-get update
3/ apt-get install fglrx-amdcccle fglrx-driver fglrx-kernel-src module-assistant
4/ m-a prepare
5/ m-a a-i fglrx
6/ aticonfig --initial
toutes ces commandes sont à taper en console en tant que “root”
sauvegardes quand même ton xorg.conf avant de faire les manip… le aticonfig --initial va modifier ce fichier pour activer l’accélération 3D
oki je vais essayer ça, Merci.
en tout cas chez moi ça fonctionne nickelavec ma radeon 9600pro, je frag comme un malade sur UT2k4 8)
Bon ben ca m’a l’air tout bon merci bien. Et j’espère que les devs vont pouvoir se régaler avec les pecs donnés par AMD. Merci bien barbak.
oki merci de l’information et j’ai également une 9600 pro
pas de quoi, content d’avoir pu t’aider :wink:
re salut,
il serait possible de me faire un copier coller de ton xorg.conf stp, j 'ai fait une réinstalle des pilotes et je trouve que les performances sont moins bonne que la premiere installation. J’ai peut être rajouté un paquet qu’il ne fallait pas.
Merci d’avance s’il est possible de me le copier.
Bonne journee.
