J’ai installé il y a une quinzaine de jours les driver proprio ATI (version 8.28.8-1 récupérés sur le site ATI). tout allait bien sauf de temps en temps après sollicitation importante de la carte le système se bloque au deloging. symptome ecran noir plus rien ne réagit, plus de clavier…
Maintenant ça devient presque systématique !
J’utilise gnome, mais j’ai constaté le problème avec fluxbox et pekwm…
le :0.log me donne
X Window System Version 7.0.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 7.0
Build Operating System:Linux 2.6.12-1-686 i686
Current Operating System: Linux me-vega 2.6.16-2-686 #1 Fri Aug 18 19:01:49 UTC 2006 i686
Build Date: 16 March 2006
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Sep 4 13:05:48 2006
(==) Using config file: "/etc/X11/xorg.conf"
error opening security policy file /etc/X11/xserver/SecurityPolicy
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
> Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
Synaptics DeviceInit called
SynapticsCtrl called.
Synaptics DeviceOn called
Could not init font path element /usr/share/fonts/X11/100dpi/:unscaled, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/100dpi/:unscaled, removing from list!
Could not init font path element /usr/share/fonts/X11/75dpi/:unscaled, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/75dpi/:unscaled, removing from list!
Could not init font path element /usr/share/fonts/X11/TTF/, removing from list!
Could not init font path element /usr/share/fonts/X11/OTF, removing from list!
Could not init font path element /usr/share/fonts/X11/CID/, removing from list!
christophe@me-vega:~/.fluxbox/styles/osx$ cat /var/log/gdm/:0.log.2
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Sep 4 12:58:19 2006
ProcXCloseDevice to close or not ?
Je pense que cette dernière ligne est prblèmatique, mais je ne la comprends pas…
Quelqu’un aurait-il une idée ?
Précision j’utilise GDM…
Merci beaucoup
