Aprés avoir désactivé le dri de la carte , je me retrouve toujours avec
une mauvaise configuration de mon ATI.
more /var/log/Xorg.0.log | grep WW
(WW) RADEON(0): Failed to detect secondary monitor, MergedFB/Clone mode disabled
(WW) RADEON(0): Enabling DRM support
(WW) RADEON(0): Direct rendering disabled
more .xsessions-errors
xset: bad font path element (#68), possible causes are:
Directory does not exist or has wrong permissions
Directory missing fonts.dir
Incorrect font server address or syntax
startkde: Starting up…
kbuildsycoca running…
kdecore (KLibLoader): WARNING: KLibrary: /usr/lib/kde3/kcm_keyboard.so: undefine
d symbol: init_keyboard_layout
kdecore (KLibLoader): WARNING: KLibrary: /usr/lib/kde3/kcm_kdnssd.so: undefined
symbol: init_kdnssd
ALSA lib timer_hw.c:269:(snd_timer_hw_open) extended read is not supported (SNDR
V_TIMER_IOCTL_TREAD)
X Error: BadWindow (invalid Window parameter) 3
Major opcode: 20
Minor opcode: 0
Resource id: 0xa00022
Suite à l’accumulation de ces BadWindow errors, la machine freeze.
Voila mon Xorg.conf
Section "Files"
FontPath “unix/:7100” # local font server
# if the local font server has problems, we can fall back on these
FontPath “/usr/lib/X11/fonts/misc”
#FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath “/usr/lib/X11/fonts/Type1”
#FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section “Module”
#Load “bitmap”
#Load “dbe”
#Load “ddc”
#Load “dri”
#Load “extmod”
#Load “freetype”
#Load “glx”
#Load “int10”
#Load “record”
#Load “type1”
#Load “vbe”
#Load "dbe"
Load "extmod"
Load “glx”
#Load “record”
#Load "xtrap"
Load "freetype"
Load “type1”
#Load “drm”
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
Option “ZAxisMapping” "4 5"
EndSection
Section "Device"
Identifier "ATI Technologies, Inc. RV350 [Mobility Radeon 9600 M10]"
Driver “radeon”
#Option “UseFBDev” “true”
#Option "AGPMode" "4"
#Option "EnablePageFlip" "on"
#Option "RenderAccel" "on"
# enable (partial) PowerPlay features
#Option "DynamicClocks" "on"
# use bios hot keys on thinkpad (aka fn+f7)
#Option "BIOSHotkeys" "on"
# enable radeon specific xinerama
#Option "MergedFB" "true"
#Option "CRT2Position" "RightOf"
#Option "CRT2Hsync" "50-75"
#Option "CRT2VRefresh" "30-82"
EndSection
Section "Monitor"
Identifier “Generic Monitor”
#Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies, Inc. RV350 [Mobility Radeon 9600 M10]"
Monitor "Generic Monitor"
DefaultDepth 16
SubSection "Display"
Depth 16
Modes "1024x768"
ViewPort 0 0 # initial origin if mode is smaller than desktop
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
#Section “DRI”
#Mode 0666
#EndSection
Pourquoi le serveur X essaie t-il de detecter le second moniteur alors meme que je ne l’ai pas configuré pour?
Je ne sais pas encore très exactement la raison qui est à l’orgine du freeze.
Voyez vous le problème?
