Je dois intégrer un serveur BackupPC, sous Debian 6.0.4, dans un domaine Active Directory pour que les utilisateurs puisse gérer eux même leurs sauvegardes.
Le contrôleur de de domaine est un Windows Server 2003 R2.
Voici les fichier que j’ai modifier sur mon serveur backuppc :
Mon domaine est domaine.local
Mon contrôleur de domaine s’appelle dc
Mon serveur backuppc s’appel backuppc
/etc/krb5.conf
[quote][libdefaults]
default_realm = DOMAINE.LOCAL
krb4_config = /etc/krb.conf
krb4_realms = /etc/krb.realms
kdc_timesync = 1
ccache_type = 4
forwardable = true
proxiable = true
v4_instance_resolve = false
v4_name_convert = {
host = {
rcmd = host
ftp = ftp
plain = {
something = something-else
fcc-mit-ticketflags = true
[realms]
DOMAINE.LOCAL = {
kdc = dc.domaine.local
master_kdc = dc.domaine.local
admin_server = dc.domaine.local
default_domain = domaine.local
[domain_realm]
.domaine.local = DOMAINE.LOCAL
[login]
krb4_convert = true
krb4_get_tickets = false
/etc/samba/smb.conf
[quote][global]
workgroup = DOMAINE
netbios name = BACKUPPC
server string = %h server
dns proxy = no
log file = /var/log/samba/log.%m
max log size = 1000
syslog = 0
panic action = /usr/share/samba/panic-action %d
security = ADS
keytab method = dedicated keytab
dedicated keytab file = /etc/krb.keytab
encrypt passwords = true
password server = DC.domaine.local
passdb backend = tdbsam
obey pam restrictions = yes
unix password sync = yes
passwd program = /usr/bin/passwd %u
passwd chat = Enter\snew\s\spassword:* %n\n Retype\snew\s\spassword:* %n\n password\supdated\ssuccessfully .
pam password change = yes[/quote]
cat /etc/hosts
[quote]127.0.0.1 localhost
127.0.1.1 BACKUPPC.DOMAINE.LOCAL BACKUPPC
192.168.130.9 DC.DOMAINE.LOCAL DC
/etc/apache2/conf.d/backuppc.conf
[quote]Alias /backuppc /usr/share/backuppc/cgi-bin/
<Directory /usr/share/backuppc/cgi-bin/>
AllowOverride None
Allow from all
# Uncomment the line below to ensure that nobody can sniff importanti
# info from network traffic during editing of the BackupPC config or
# when browsing/restoring backups.
# Requires that you have your webserver set up for SSL (https) access.
#SSLRequireSSL
Options ExecCGI FollowSymlinks
AddHandler cgi-script .cgi
DirectoryIndex index.cgi
AuthType Kerberos
AuthName "Kerberos Login"
KrbAuthRealms DOMAINE.LOCAL
Krb5Keytab /etc/krb5.keytab
KrbMethodNegotiate On
KrbMethodK5Passwd Off
Krb5KeyTab /etc/krb5.keytab
AuthGroupFile /etc/backuppc/htgroup
AuthUserFile /etc/backuppc/htpasswd
AuthType basic
AuthName “BackupPC admin”
require valid-user[/quote]
J’ai créer un groupe de sécurité dans la foret pour l’administration, que j’ai renseigné dans la config de backuppc et ajouté mes utilisateurs dedans.
J’arrive a obtenir des jetons avec la commande kinit, j’ai réussi a intégrer le serveur dans la foret mais l’authentenfication dans apache ne fonctionne pas et me laisse le message dans les logs d’erreurs :
[quote][Fri May 04 12:10:36 2012] [error] [client 192.168.130.9] gss_acquire_cred() failed: An invalid name was supplied (, Cannot determine realm for numeric host address)
Ça fait une semaine que je bloque dessus, si quelqu’un a des suggestions sur ce qui pourrait bloquer, cela me rendrait un énorme service !
