voici ce que me renvoie la commande:
[ 15.066743] b43-phy0: Broadcom 4318 WLAN found
[ 31.272737] input: b43-phy0 as /class/input/input7
[ 31.356076] firmware: requesting b43/ucode5.fw
[ 31.582038] firmware: requesting b43/pcm5.fw
[ 31.606980] firmware: requesting b43/b0g0initvals5.fw
[ 31.628729] firmware: requesting b43/b0g0bsinitvals5.fw
[ 31.804057] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 33.060435] Registered led device: b43-phy0::radio
[ 34.881277] input: b43-phy0 as /class/input/input8
[ 35.084085] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 36.260377] Registered led device: b43-phy0::radio
[ 944.213319] input: b43-phy0 as /class/input/input9
[ 944.430424] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 945.440385] Registered led device: b43-phy0::radio
[ 945.901310] input: b43-phy0 as /class/input/input10
[ 946.104038] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 947.096383] Registered led device: b43-phy0::radio
[ 950.662804] b43-pci-bridge 0000:03:02.0: enabling device (0000 -> 0002)
[ 951.561305] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 957.508017] input: b43-phy0 as /class/input/input11
[ 957.708309] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 958.708420] Registered led device: b43-phy0::radio
[ 958.873209] input: b43-phy0 as /class/input/input12
[ 959.076043] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
[ 960.300414] Registered led device: b43-phy0::radio
Je ne sais pas s’il s’agit de la dernière version (2007… cela ne doit pas être le cas je suppose
Je me rappel avoir tenté de suivre la procédure sur le wiki mais ça n’a pas marché donc j’ai du suivre celle d’un autre tuto je sais plus trop ou…
En ce qui concerne la configuration de la connexion, j’ai eut des soucis avec le gestionnaire par défaut (ça se connectait jamais du premier coup). Du coup je suis passé à wicd avec lequel c’est plutôt stable malgré les chutes de débits (mais ce n’est pas de sa faute).
Version du noyau: 2.6.26-2-686
Lenny 5.0.3
