Bacula problème de connexion serveur - client sous debian
Je cherche de l’aide, j’ai installer debian lenny avec les packet BACULA.
Mais cela ne fonctionne pas, je n’arrive pas connecter le serveur avec le client.
j’ai procéder comme cela:
apt-get update & upgrade
apt-get install bacula-director-mysql
apt-get install bacula-fd
apt-get install bacula-sd-mysql
apt-get install bacula-console
J’ai crée pour des tests une serveurs bacula 192.168.0.14 et un client bacula 192.168.0.15 sous Virtualbox.
bacula-dir.conf :
JobDefs {
  Name = "Job serveurclient"
  Type = Backup
  Level = Incremental
  Client = serveurclient-fd
  FileSet = "Full Set serveurclient"
  Schedule = "WeeklyCycle"
  Storage = File
  Messages = Standard
  Pool = Default
  Priority = 10
Job {
  Name = "serveurclient"
  Client = "serveurclient-fd"
  JobDefs = "DefaultJob"
  Write Bootstrap = "/var/lib/bacula/serveurclient.bsr"
FileSet {
  Name = "Full Set serveurclient"
  Include {
    Options {
      signature = MD5
    File = /backup
  Exclude {
    File = /proc
    File = /tmp
    File = /.journal
    File = /.fsck
Client {
  Name = serveurclient-fd
  Address = 192.168.0.15
  FDPort = 9102
  Catalog = MyCatalog
  Password = "4NXMDFbQwE34duq74Kv5Qg1KYF5sOI1QVi3AoOHR1msu"          # password for FileDaemon
  File Retention = 30 days            # 30 days
  Job Retention = 6 months            # six months
  AutoPrune = yes                     # Prune expired Jobs/Files
bconsole.conf :
# Bacula User Agent (or Console) Configuration File
Director {
  Name = localhost-dir
  DIRport = 9101
  address = localhost
  Password = "Cv70F6pf1t6pBopT4vQOnigDrR0v3L"
bacula-fd.conf :
# Default  Bacula File Daemon Configuration file
#  For Bacula release 5.0.2 (28 April 2010) -- debian squeeze/sid
# There is not much to change here except perhaps the
# File daemon Name to
# List Directors who are permitted to contact this File daemon
Director {
  Name = serveurclient-dir
#  Password = "JAci1Mf-XJSUjPvTqWcOiaLD8-_Su3GnT"
# Restricted Director, used by tray-monitor to get the
#   status of the file daemon
Director {
  Name = serveurclient-mon
  Password = "iiduAl1I7IiYXqw50UE8GqkL9jIhH2Mxj"
  Monitor = yes
# "Global" File daemon configuration specifications
FileDaemon {                          # this is me
  FDport = 9102                  # where we listen for the director
  WorkingDirectory = /var/lib/bacula
  Pid Directory = /var/run/bacula
  Maximum Concurrent Jobs = 20
  FDAddress = 127.0.0.1
# Send all messages except skipped files back to Director
Messages {
  Name = Standard
  director = serveurbacula-dir = all, !skipped, !restored
Puis sur le serveur bacule je tape sur le terminal
root@serveurbacula:~# bconsole
Connecting to Director localhost:9101
1000 OK: serveurbacula-dir Version: 5.0.2 (28 April 2010)
Enter a period to cancel a command.
*status client
The defined Client resources are:
1: serveurbacula-fd
2: serveurclient-fd
2
Connecting to Client serveurclient-fd at 192.168.0.15:9102
Failed to connect to Client serveurclient-fd.
You have messages.
je ne comprend pas d’où vient le problème de connexion.
Merci de votre aide
salut, test avec :
bconsole -c /etc/bacula/bconsole.conf
Merci de ton aide cela ne donne rien de concluent.
connexion a la console fonction mais ne peut toujours pas me connecter au client.
Que faire
je ne connais pas trop bacula, je l’ai utilisé une fois pour faire une restauration chez un client.
le port n’est pas bloqué ? pas de Firewall ?
Merci de ton aide
Mon pas firwall sur mes serveur.
Quant je tape iptables -L j’ai
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
voila
Peux tu nous fournir ton fichier bacula-fd.conf stp?
Et que dises les logs?
