bash' ne fait des calculs que sur des entiers.bc’, appelé avec l’option `-l’ dispose de ces fonctions (voir man bc / MATH LIBRARY), mais pas Pi (il faut le calculer, une formule est donnée dans le man).
root@localhost:../..# man bc | grep -i pi
to ibase will result in a value of 2 or 16. Input numbers may contain the characters 0-9 and A-F. (Note: They must be capitals. Lower
These statements are not statements in the traditional sense. They are not executed statements. Their function is performed at "compile"
In /bin/sh, the following will assign the value of "pi" to the shell variable pi.
pi=$(echo "scale=10; 4*a(1)" | bc -l)
GNU bc can be compiled (via a configure option) to use the GNU readline input editor library or the BSD libedit library. This allows the
would typically contain function definitions for functions the user wants defined every time bc is run.
If any file on the command line can not be opened, bc will report that the file is unavailable and terminate. Also, there are compile and
Et pour la trigonométrie :
s (x) The sine of x, x is in radians.
c (x) The cosine of x, x is in radians.
a (x) The arctangent of x, arctangent returns radians.
e (x) The exponential function of raising e to the value x.
