J’ai essayé le noyau debian, pas marcher.
C’était donc un soucis de cpu, dans le bios j’ai du mettre en “enable” les réglages concernant le cpu, je sais pas c’est lequel il y en a 4 faudra essayer un par un.
Je les avais désactiver pour que les fréquences ne soit pas diminué-augmenté automatiquement.
$ cpufreq-info
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
  driver: acpi-cpufreq
  CPUs which run at the same hardware frequency: 0
  CPUs which need to have their frequency coordinated by software: 0
  maximum transition latency: 10.0 us.
  hardware limits: 1.20 GHz - 2.66 GHz
  available frequency steps: 2.66 GHz, 2.53 GHz, 2.39 GHz, 2.26 GHz, 2.13 GHz, 2.00 GHz, 1.86 GHz, 1.73 GHz, 1.60 GHz, 1.46 GHz, 1.33 GHz, 1.20 GHz
  available cpufreq governors: userspace, powersave, ondemand, conservative, performance
  current policy: frequency should be within 1.20 GHz and 2.66 GHz.
                  The governor "performance" may decide which speed to use
                  within this range.
  current CPU frequency is 2.66 GHz.
  cpufreq stats: 2.66 GHz:100.00%, 2.53 GHz:0.00%, 2.39 GHz:0.00%, 2.26 GHz:0.00%, 2.13 GHz:0.00%, 2.00 GHz:0.00%, 1.86 GHz:0.00%, 1.73 GHz:0.00%, 1.60 GHz:0.00%, 1.46 GHz:0.00%, 1.33 GHz:0.00%, 1.20 GHz:0.00%
analyzing CPU 1:
  CPUs which run at the same hardware frequency: 1
  CPUs which need to have their frequency coordinated by software: 1
                  within this range.
analyzing CPU 2:
  CPUs which run at the same hardware frequency: 2
  CPUs which need to have their frequency coordinated by software: 2
                  within this range.
analyzing CPU 3:
  CPUs which run at the same hardware frequency: 3
  CPUs which need to have their frequency coordinated by software: 3
                  within this range.
La mauvaise nouvelle,  j’ai mon cpu en overclocking à 4.00 GHz, je me demande s’il va prendre en compte.
