Je dispose d’un Debian 3.1 sur lequel tourne Apache 2 et PHP4 en module.
Je souhaite pouvoir faire tourner un CMS en PHP5 et par conséquent j’essaye d’installer php5-cgi pour pouvoir créer un dossier /var/www/php5 dans lequel je mettrais mes CMS PHP5.
Le problème survient lorsque je fais un apt-get install php5-cgi :
[code]xxxxxxx:/var/www# apt-get install php5-cgi
Reading Package Lists… Done
Building Dependency Tree… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
php5-cgi: Depends: libc6 (>= 2.3.6-6) but 2.3.2.ds1-22sarge3 is to be installed
Depends: libdb4.4 but it is not installable
Depends: libkrb53 (>= 1.4.2) but 1.3.6-2sarge2 is to be installed
Depends: libssl0.9.8 (>= 0.9.8c-1) but it is not installable
Depends: libxml2 (>= 2.6.27) but 2.6.16-7 is to be installed
E: Broken packages[/code]
Voici mon sources.list :
[code]deb http://packages.dotdeb.org stable all
deb-src http://packages.dotdeb.org stable all
deb http://ftp.oleane.net/debian sarge main
deb http://security.debian.org/ stable/updates main contrib non-free
Sauriez-vous me dire ce qui ne va pas ?
Merci d’avance !
