Salutations,
après m’être bien pris la tête pour installer Debian sur mon PC principal…
J’ai besoin de votre aide car je n’arrive pas à trouver la solution à ces erreurs dans mon “dmesg” :
[ 0.911362] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170531/psargs-364)
[ 0.911426] ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT4._GTF, AE_NOT_FOUND (20170531/psparse-550)
[ 0.911534] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170531/psargs-364)
[ 0.911593] ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT5._GTF, AE_NOT_FOUND (20170531/psparse-550)
[ 0.912620] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170531/psargs-364)
[ 0.912682] ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT0._GTF, AE_NOT_FOUND (20170531/psparse-550)
[ 0.913625] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170531/psargs-364)
[ 0.913687] ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT0._GTF, AE_NOT_FOUND (20170531/psparse-550)
[ 0.916002] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170531/psargs-364)
[ 0.916089] ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT1._GTF, AE_NOT_FOUND (20170531/psparse-550)
[ 0.918898] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170531/psargs-364)
[ 0.918961] ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT1._GTF, AE_NOT_FOUND (20170531/psparse-550)
[ 0.981484] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170531/psargs-364)
[ 0.981563] ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT4._GTF, AE_NOT_FOUND (20170531/psparse-550)
[ 0.984162] ACPI Error: [DSSP] Namespace lookup failure, AE_NOT_FOUND (20170531/psargs-364)
[ 0.984240] ACPI Error: Method parse/execution failed \_SB.PCI0.SAT0.SPT5._GTF, AE_NOT_FOUND (20170531/psparse-550)
Avez-vous déjà eu ça ?
Et/ou
Auriez-vous une piste pour m’aider à régler les problèmes ?
