J’essaie de compiler proftpd (pour avoir un module spécial).
Mais voila erreur :
voici mon journal de compilation :
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
[code]It was created by configure, which was
generated by GNU Autoconf 2.59. Invocation command line was
$ ./configure --with-modules=mod_ifsession:mod_xfer:mod_log
Platform.
hostname = sd-3074
uname -m = i686
uname -r = 2.6.21.1dedibox-r7
uname -s = Linux
uname -v = #1 Mon Apr 30 17:25:38 CEST 2007
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = i686
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: JAVA_HOME/bin
PATH: /usr/bin
PATH: /usr/sbin
PATH: /bin
PATH: /sbin
Core tests.
configure:1641: checking build system type
configure:1659: result: i686-pc-linux-gnulibc1
configure:1667: checking host system type
configure:1681: result: i686-pc-linux-gnulibc1
configure:1689: checking target system type
configure:1703: result: i686-pc-linux-gnulibc1
configure:1807: checking for gcc
configure:1823: found /usr/bin/gcc
configure:1833: result: gcc
configure:2077: checking for C compiler version
configure:2080: gcc --version </dev/null >&5
gcc (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
Copyright © 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:2083: $? = 0
configure:2085: gcc -v </dev/null >&5
Using built-in specs.
Target: i486-linux-gnu
Configured with: …/src/configure -v --enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr --enable-shared --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --program-suffix=-4.1 --enable-__cxa_atexit --enable-clocale=gnu --enable-libstdcxx-debug --enable-mpfr --with-tune=i686 --enable-checking=release i486-linux-gnu
Thread model: posix
gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
configure:2088: $? = 0
configure:2090: gcc -V </dev/null >&5
gcc: ‘-V’ option must have argument
configure:2093: $? = 1
configure:2116: checking for C compiler default output file name
configure:2119: gcc conftest.c >&5
/usr/bin/ld: crt1.o: No such file: No such file or directory
collect2: ld returned 1 exit status
configure:2122: $? = 1
configure: failed program was:
| /* confdefs.h. /
| #define PACKAGE_NAME “”
| #define PACKAGE_TARNAME “”
| #define PACKAGE_VERSION “”
| #define PACKAGE_STRING “”
| #define PACKAGE_BUGREPORT “”
| #define PR_BUILD_OPTS “–with-modules=mod_ifsession:mod_xfer:mod_log”
| #define PR_PLATFORM “LINUX”
| / end confdefs.h. */
| int
| main ()
| return 0;
configure:2161: error: C compiler cannot create executables
See `config.log’ for more details.
Cache variables.
ac_cv_build=i686-pc-linux-gnulibc1
ac_cv_build_alias=i686-pc-linux-gnulibc1
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=i686-pc-linux-gnulibc1
ac_cv_host_alias=i686-pc-linux-gnulibc1
ac_cv_prog_ac_ct_CC=gcc
ac_cv_target=i686-pc-linux-gnulibc1
ac_cv_target_alias=i686-pc-linux-gnulibc1
Output variables.
ADDL_DIRS=’‘
ALLOCA=’‘
AR=’‘
BINDIR=’‘
BUILD_SHARED_MODULE_OBJS=’‘
BUILD_STATIC_MODULE_ARCHIVES=’‘
BUILD_STATIC_MODULE_OBJS=’‘
CC=‘gcc’
CFLAGS=’‘
CPP=’‘
CPPFLAGS=’‘
CURSES_LIBS=’‘
CXX=’‘
CXXCPP=’‘
CXXFLAGS=’‘
DATADIR=’‘
DEFS=’‘
ECHO=‘echo’
ECHO_C=’‘
ECHO_N=’-n’
ECHO_T=’‘
EGREP=’‘
ENABLE_NLS=’‘
EXEEXT=’‘
F77=’‘
FFLAGS=’‘
GLUE_MODULE_OBJS=’‘
INCLTDL=’-I${top_srcdir}/lib/libltdl’
INCLUDEDIR=’‘
INCLUDES=’‘
INSTALL_DATA=’‘
INSTALL_DEPS=’‘
INSTALL_PROGRAM=’‘
INSTALL_SCRIPT=’‘
INSTALL_STRIP=’‘
LDFLAGS=’‘
LIBDIRS=’‘
LIBEXECDIR=’‘
LIBLTDL=’${top_builddir}/lib/libltdl/libltdlc.la’
LIBOBJS=’‘
LIBRARIES=’‘
LIBS=’‘
LIBTOOL=’‘
LIBTOOL_DEPS=’‘
LIB_DEPS=’‘
LIB_OBJS=’‘
LN_S=’‘
LOCALSTATEDIR=’‘
LTLIBOBJS=’‘
MAIN_LDFLAGS=’‘
MAIN_LIBS=’‘
MODULE_DEPS=’‘
MODULE_LDFLAGS=’‘
OBJEXT=’‘
OSREL=’-DLINUX’
OSTYPE=’‘
PACKAGE_BUGREPORT=’‘
PACKAGE_NAME=’‘
PACKAGE_STRING=’‘
PACKAGE_TARNAME=’‘
PACKAGE_VERSION=’‘
PATH_SEPARATOR=’:‘
PREFIX=’‘
RANLIB=’‘
SBINDIR=’‘
SET_MAKE=’‘
SHARED_MODULE_DIRS=’‘
SHARED_MODULE_LIBS=’‘
SHELL=’/bin/sh’
STATIC_MODULE_DIRS=’‘
STRIP=’‘
SYSCONFDIR=’‘
UTILS_LIBS=’‘
VERSION=’‘
ac_ct_AR=’'
ac_ct_CC=‘gcc’
ac_ct_CXX=’‘
ac_ct_F77=’‘
ac_ct_RANLIB=’‘
ac_ct_STRIP=’‘
bindir=’${exec_prefix}/bin’
build=‘i686-pc-linux-gnulibc1’
build_alias=’'
build_cpu=‘i686’
build_os=‘linux-gnulibc1’
build_vendor=‘pc’
datadir=’${prefix}/share’
exec_prefix=‘NONE’
host=‘i686-pc-linux-gnulibc1’
host_alias=’‘
host_cpu=‘i686’
host_os=‘linux-gnulibc1’
host_vendor=‘pc’
includedir=’${prefix}/include’
infodir=’${prefix}/info’
install_group=’‘
install_user=’‘
libdir=’${exec_prefix}/lib’
libexecdir=’${exec_prefix}/libexec’
localstatedir=’${prefix}/var’
mandir=’${prefix}/man’
oldincludedir=’/usr/include’
prefix=‘NONE’
program_transform_name=‘s,x,x,‘
sbindir=’${exec_prefix}/sbin’
sharedstatedir=’${prefix}/com’
subdirs=’‘
sysconfdir=’${prefix}/etc’
target=‘i686-pc-linux-gnulibc1’
target_alias=’'
target_cpu='i686’
target_os='linux-gnulibc1’
target_vendor=‘pc’
confdefs.h.
configure: exit 77[/code]
