Besoin d'aide pour l'installation / configuration de ReadyMedia "alias minidlna"
J’ai installer minidlna via apt-get.
Source : https://www.guillaume-leduc.fr/creer-un-serveur-upnp-en-10-min-avec-minidlna.html
  • etc/default/minidlna :
####cat etc/default/minidlna
’# Defaults for minidlna initscript
’# sourced by /etc/init.d/minidlna
’# installed at /etc/default/minidlna by the maintainer scripts
'# Start the daemon if set to "yes"
START_DAEMON=“yes”
'# Path to the configuration file
CONFIGFILE="/etc/minidlna.conf"
'# Path to the log file
LOGFILE="/var/log/minidlna.log"
‘# User and group the daemon should run as
’#USER=“minidlna-chromebook”
’#GROUP=“minidlna”
'# Additional options that are passed to the daemon
DAEMON_OPTS=""
  • etc/minidlna.conf :
####cat etc/minidlna.conf
’# port for HTTP (descriptions, SOAP, media transfer) traffic
port=8200
'# network interfaces to serve, comma delimited
network_interface=wlan0
‘# specify the user account name or uid to run as
’#user=jmaggard
‘# set this to the directory you want scanned.
’# * if you want multiple directories, you can have multiple media_dir= lines
’# * if you want to restrict a media_dir to specific content types, you
’# can prepend the types, followed by a comma, to the directory:
’# + “A” for audio (eg. media_dir=A,/home/jmaggard/Music)
’# + “V” for video (eg. media_dir=V,/home/jmaggard/Videos)
’# + “P” for images (eg. media_dir=P,/home/jmaggard/Pictures)
’# + “PV” for pictures and video (eg. media_dir=PV,/home/jmaggard/digital_camera)
media_dir=/home/etrust/Téléchargements/
‘# set this to merge all media_dir base contents into the root container
’# note: the default is no
merge_media_dirs=no
'# set this if you want to customize the name that shows up on your clients
friendly_name=My DLNA Server
'# set this if you would like to specify the directory where you want MiniDLNA to store its database and album art cache
db_dir=/var/cache/minidlna
'# set this if you would like to specify the directory where you want MiniDLNA to store its log file
log_dir=/var/log
‘# set this to change the verbosity of the information that is logged
’# each section can use a different level: off, fatal, error, warn, info, or debug
log_level=general,artwork,database,inotify,scanner,metadata,http,ssdp,tivo=warn
‘# this should be a list of file names to check for when searching for album art
’# note: names should be delimited with a forward slash ("/")
album_art_names=Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg/AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg/Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg
‘# set this to no to disable inotify monitoring to automatically discover new files
’# note: the default is yes
inotify=yes
'# set this to yes to enable support for streaming .jpg and .mp3 files to a TiVo supporting HMO
enable_tivo=no
‘# set this to strictly adhere to DLNA standards.
’# * This will allow server-side downscaling of very large JPEG images,
’# which may hurt JPEG serving performance on (at least) Sony DLNA products.
strict_dlna=no
‘# default presentation url is http address on port 80
’#presentation_url=http://www.mylan/index.php
'# notify interval in seconds. default is 895 seconds.
notify_interval=900
‘# serial and model number the daemon will report to clients
’# in its XML description
serial=12345678
model_number=1
'# specify the path to the MiniSSDPd socket
minissdpdsocket=/var/run/minissdpd.sock
‘# use different container as root of the tree
’# possible values:
’# + “.” - use standard container (this is the default)
’# + “B” - “Browse Directory”
’# + “M” - “Music”
’# + “V” - “Video”
’# + “P” - “Pictures”
’# + Or, you can specify the ObjectID of your desired root container (eg. 1$F for Music/Playlists)
’# if you specify “B” and client device is audio-only then “Music/Folders” will be used as root
root_container=.
'# always force SortCriteria to this value, regardless of the SortCriteria passed by the client
force_sort_criteria=+upnp:class,+upnp:originalTrackNumber,+dc:title
‘# maximum number of simultaneous connections
’# note: many clients open several simultaneous connections while streaming
max_connections=50
*Apparemment le serveur uPnP / Dlna ne s’exécute pas ?
#####Merci de votre aide pour la configuration.
Je viens de voir que le projet a été rebaptisé " ReadyMedia ".
(SourceForge) ; " je pense que l’archive sur SourceForge doit être compilée ? "
salut,
minidlna des dépôts fonctionne très bien
desktop:~$ apt-cache policy minidlna
minidlna:
  Installé : 1.1.2+dfsg-1.1+b3
  Candidat : 1.1.2+dfsg-1.1+b3
 Table de version :
     1.1.5+dfsg-2~bpo8+1 0
        100 http://httpredir.debian.org/debian/ jessie-backports/main i386 Packages
 *** 1.1.2+dfsg-1.1+b3 0
        500 http://httpredir.debian.org/debian/ jessie/main i386 Packages
        100 /var/lib/dpkg/status
@desktop:~$ systemctl status minidlna
● minidlna.service - LSB: Start minidlna at boot time
   Loaded: loaded (/etc/init.d/minidlna)
   Active: active (running) since sam. 2016-05-21 08:47:05 CEST; 16min ago
  Process: 881 ExecStart=/etc/init.d/minidlna start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/minidlna.service
           └─1261 /usr/bin/minidlnad -f /etc/minidlna.conf -P /run/minidlna/m...
je le fais se lancer en root pour ne pas m’emmerder avec quelque probleme d’accès aux fichiers que se soit
@desktop:~$ cat /etc/default/minidlna
# These options can be set to modify the behavior of the minidlna init script.
# The options commented out show the default values.
START_DAEMON="yes"
USER="root"
GROUP="root"
DAEMON_OPTS=""
j’ai aussi un soucis et Root ne semble pas le résoudre.
Mais cela est un autre sujet, pas la présente question.
Si je poste, c’est pour avoir le contenu de /var/log/minidlna.log
Ca pourrait être informatif.
