bonjour à tous
une fois téléchargé et installé le module squidguard pour webmin sur ma linux wheezy je dois configurer :
Create a basic configuration file
This page iwll help you to setup your SquidGuard with a basic configuration. Please define below where you want the database files and log files to be store. Use full (!) path names to the directories of this entries. (Examples: dbhome=/etc/squidguard/db, logdir=/var/log/squidguard)
Database Directory
Log Directory
You can decide below whether the basic configuration file will allow all traffic or now traffic. Depending on what you want to do you can decide between those settings. You may change them later in the module!
All traffic No traffic
Je remplis les 2 champs avec :/var/lib/squidguard/db et /var/log/squidguard
puis je valide et j’obtiens cette erreur :
Error - Perl execution failed
Undefined subroutine &squidguard::terror called at /usr/share/webmin/squidguard/create_plainconf.cgi line 31.
Quelqu’un aurait-il une réponse ?
merci
