J’ai suivi ca : coagul.org/article.php3?id_article=185
Je n’ai pas touché au named.conf originel, j’ai seulement ajouté à la fin du fichier
[code]zone “domaine.com” {
type master;
file “/etc/bind/domaine.com”;
forwarders{}
zone “9.168.192.in-addr.arpa” {
type master;
file “/etc/bind/9.domaine”;
forwarders{}
};[/code]
Fichier domaine.com
[code]$TTL 604800
@ IN SOA debian-dns.domaine.com. root.domaine.com. (
20070509
604800
86400
2419200
604800
NS debian-dns.domaine.com.
debian-dns A 192.168.9.10
serveurAD A 192.168.9.1
servermail A 192.168.9.2
;** Alias entre nom
domaine CNAME serveurAD
mail CNAME servermail
[code]$TTL 604800
@ in SOA debian-dns.domaine.com.
postmaster.domaine.com. (
20070509
604800
86400
2419200
604800 )
1 PTR serveurAD
2 PTR serveurmail
[/code][/b]
J’ai aussi modifier resolv.conf, hosts et hosts.conf
Un cat /var/log/daemon.log me donne
[code]
May 9 19:21:12 debian-dns named[2010]: hint zone “” (IN) loaded (serial 0)
May 9 19:21:12 debian-dns named[2010]: master zone “localhost” (IN) loaded (serial 1)
May 9 19:21:12 debian-dns named[2010]: master zone “127.in-addr.arpa” (IN) loaded (serial 1)
May 9 19:21:12 debian-dns named[2010]: master zone “0.in-addr.arpa” (IN) loaded (serial 1)
May 9 19:21:12 debian-dns named[2010]: master zone “255.in-addr.arpa” (IN) loaded (serial 1)
May 9 19:21:12 debian-dns named[2010]: /etc/bind/named.conf:55: syntax error near '}'
May 9 19:21:12 debian-dns named[2010]: /etc/bind/named.conf:59: zone filename already set; s kipping
May 9 19:21:12 debian-dns named[2010]: /etc/bind/named.conf:61: syntax error near '}'
May 9 19:21:12 debian-dns named[2010]: listening on [127.0.0.1].53 (lo)
May 9 19:21:12 debian-dns named[2010]: listening on [192.168.9.10].53 (eth0)
May 9 19:21:12 debian-dns named[2010]: Forwarding source address is [::].1026
May 9 19:21:12 debian-dns named[2010]: Forwarding source address is [0.0.0.0].1027
May 9 19:21:12 debian-dns named[2011]: Ready to answer queries.[/code]
Deux questions, ou j’ai merdé ?!
Comment supprimer les log pour les remettres à zero ? rm ?
