Quand je tape le code suivant sur la console:
j’ai le résultat suivant:
; <<>> DiG 9.2.4 <<>> mondomaine.com soa@nsa.bookmyname.com
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 43587
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 1
;; QUESTION SECTION:
;mondomaine.com. IN A
;; ANSWER SECTION:
mondomaine.com. 86400 IN A IP_Serveur
;; AUTHORITY SECTION:
mondomaine.com. 86400 IN NS ns.kimsufi.com.
mondomaine.com. 86400 IN NS ks****.kimsufi.com.
;; ADDITIONAL SECTION:
ns.kimsufi.com. 106934 IN A 213.186.33.199
;; Query time: 12 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Fri Apr 20 17:12:03 2007
;; MSG SIZE rcvd: 108
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 20561
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;soa\@nsa.bookmyname.com. IN A
bookmyname.com. 3600 IN SOA nsa.bookmyname.com. hostmaster.bookmyname.com. 2007011702 3600 3600 604800 3600
;; Query time: 335 msec
;; WHEN: Fri Apr 20 17:12:04 2007
;; MSG SIZE rcvd: 91
On peut voir que le résultat est différent du tiens.
Apres je suis aller sur le site http://www.dnsreport.com. Quand je test mon domaine, j’ai 3 fail qui apparaisse:
1: MX Category : ERROR: I couldn’t find any MX records for MonDomain.com. If you want to receive E-mail on this domain, you should have MX record(s). Without any MX records, mailservers should attempt to deliver mail to the A record for MonDomain.com. I can’t continue in a case like this, so I’m assuming you don’t receive mail on this domain.
2: Domain A Lookup :ERROR: I couldn’t find any A records for MonDomain.com. But I did find a referral to MonDomaine.com), you will need an A record for MonDomaine.com. If you do not want a website at MonDomaine.com, you can ignore this error.
3: Connect to mail servers : ERROR: I could not find any mailservers for MonDomaine.com.
Donc si quelqu’un pouvait m’en dir un peu plus sur ces messages d’erreur.
En ce qui conserne le message d’erreur sur “Connect to mail”. J’ai installé Postfix comme serveur Mail. J’arrive à envoyé des mail à partir du serveur, en local et vers une boite extérieur (style Gmail, yahoo…). Par contre quand j’essaye d’envoyé un mail à partir de Gmail, mon serveur ne recois rien et dans le fichier " /var/log/mail.log ", je n’ai aucun message d’erreur. Par contre sur ma boite mail “Gmail”, je reçois le message suivant :[quote]Technical details of permanent failure:
PERM_FAILURE: DNS Error: DNS server returned answer with no data[/quote]
Donc je pense que tout es lié au serveur dns.
Voici les differents fichiers de configuration de Bind:
zone.MonDomaine.com :
zone "MonDomaine.com" {
type master;
notify yes;
allow-transfer {88.191.249.135; 217.24.82.34;};
file "/etc/bind/db.MonDomain.com";
db.MonDomain.com :
$ttl 86400
MonDomain.com. IN SOA ks____.kimsufi.com. webmaster.MonDomain.com. (
2007041903
21600
3600
604800
86400 )
MonDomain.com. IN NS ks____.kimsufi.com.
MonDomain.com. IN NS ns.kimsufi.com.
MonDomain.com. IN MX 10 mail.MonDomain.com.
MonDomain.com. IN A IP_SERVEUR
Server IN A IP_SERVEUR
mail IN A IP_SERVEUR
smtp.MonDomain.com. IN A IP_SERVEUR
pop.MonDomain.com. IN A IP_SERVEUR
pop3 IN CNAME Server
imap IN A IP_SERVEUR
sql IN A IP_SERVEUR
mysql IN A IP_SERVEUR
Voila, j’espère que vous avez tout ce qui faut pour répondre aux différents problèmes.
Fréd’o
