Blocage systématique lors du démarrage de ma lenny
J’ai depuis quelques jours des soucis à chaque démarrage de ma Lenny : celle-ci se bloque toujours au même endroit (“loop: module loaded”) et je suis obligé de faire un [Ctrl] + C et [Ctrl] + D pour pouvoir booter jusqu’au bout ! :open_mouth:
Voici mon dmesg :$ dmesg [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 2.6.26-2-amd64 (Debian 2.6.26-24lenny1) (dannf@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25)) #1 SMP Thu Aug 19 00:37:36 UTC 2010 [ 0.000000] Command line: root=/dev/sda1 ro vga=837 [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable) [ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 0000000077fa0000 (usable) [ 0.000000] BIOS-e820: 0000000077fa0000 - 0000000077fae000 (ACPI data) [ 0.000000] BIOS-e820: 0000000077fae000 - 0000000077fe0000 (ACPI NVS) [ 0.000000] BIOS-e820: 0000000077fe0000 - 0000000078000000 (reserved) [ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved) [ 0.000000] BIOS-e820: 00000000ff700000 - 0000000100000000 (reserved) [ 0.000000] Entering add_active_range(0, 0, 159) 0 entries of 3200 used [ 0.000000] Entering add_active_range(0, 256, 491424) 1 entries of 3200 used [ 0.000000] max_pfn_mapped = 1048576 [ 0.000000] init_memory_mapping [ 0.000000] DMI 2.3 present. [ 0.000000] ACPI: RSDP 000FBE50, 0024 (r2 ACPIAM) [ 0.000000] ACPI: XSDT 77FA0100, 007C (r1 _ASUS_ Notebook 20080425 MSFT 97) [ 0.000000] ACPI: FACP 77FA0290, 00F4 (r3 042508 FACP1114 20080425 MSFT 97) [ 0.000000] ACPI: DSDT 77FA04A0, ACFE (r1 A0925 A0925000 0 INTL 20060113) [ 0.000000] ACPI: FACS 77FAE000, 0040 [ 0.000000] ACPI: APIC 77FA0390, 0080 (r1 042508 APIC1114 20080425 MSFT 97) [ 0.000000] ACPI: MCFG 77FA0410, 003C (r1 042508 OEMMCFG 20080425 MSFT 97) [ 0.000000] ACPI: WDRT 77FA0450, 0047 (r1 042508 NV-WDRT 20080425 MSFT 97) [ 0.000000] ACPI: OEMB 77FAE040, 0073 (r1 042508 OEMB1114 20080425 MSFT 97) [ 0.000000] ACPI: HPET 77FAB1A0, 0038 (r1 042508 OEMHPET0 20080425 MSFT 97) [ 0.000000] ACPI: INFO 77FAE0C0, 0124 (r1 042508 AMDINFO 20080425 MSFT 97) [ 0.000000] ACPI: NVHD 77FAE1F0, 0284 (r1 042508 NVHDCP 20080425 MSFT 97) [ 0.000000] ACPI: OSFR 77FAB1E0, 00B0 (r1 042508 OEMOSFR 20080425 MSFT 97) [ 0.000000] ACPI: SLIC 77FAB290, 0176 (r1 _ASUS_ Notebook 20080425 MSFT 97) [ 0.000000] ACPI: SSDT 77FAB410, 028A (r1 A M I POWERNOW 1 AMD 1) [ 0.000000] Scanning NUMA topology in Northbridge 24 [ 0.000000] No NUMA configuration found [ 0.000000] Faking a node at 0000000000000000-0000000077fa0000 [ 0.000000] Entering add_active_range(0, 0, 159) 0 entries of 3200 used [ 0.000000] Entering add_active_range(0, 256, 491424) 1 entries of 3200 used [ 0.000000] Bootmem setup node 0 0000000000000000-0000000077fa0000 [ 0.000000] NODE_DATA [000000000000c000 - 0000000000010fff] [ 0.000000] bootmap [0000000000011000 - 000000000001fff7] pages f [ 0.000000] early res: 0 [0-fff] BIOS data page [ 0.000000] early res: 1 [6000-7fff] TRAMPOLINE [ 0.000000] early res: 2 [200000-675397] TEXT DATA BSS [ 0.000000] early res: 3 [37986000-37fef6a2] RAMDISK [ 0.000000] early res: 4 [9fc00-fffff] BIOS reserved [ 0.000000] early res: 5 [8000-bfff] PGTABLE [ 0.000000] [ffffe20000000000-ffffe20001bfffff] PMD -> [ffff810001200000-ffff810002dfffff] on node 0 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0 -> 4096 [ 0.000000] DMA32 4096 -> 1048576 [ 0.000000] Normal 1048576 -> 1048576 [ 0.000000] Movable zone start PFN for each node [ 0.000000] early_node_map[2] active PFN ranges [ 0.000000] 0: 0 -> 159 [ 0.000000] 0: 256 -> 491424 [ 0.000000] On node 0 totalpages: 491327 [ 0.000000] DMA zone: 56 pages used for memmap [ 0.000000] DMA zone: 1246 pages reserved [ 0.000000] DMA zone: 2697 pages, LIFO batch:0 [ 0.000000] DMA32 zone: 6663 pages used for memmap [ 0.000000] DMA32 zone: 480665 pages, LIFO batch:31 [ 0.000000] Normal zone: 0 pages used for memmap [ 0.000000] Movable zone: 0 pages used for memmap [ 0.000000] Detected use of extended apic ids on hypertransport bus [ 0.000000] ACPI: PM-Timer IO Port: 0x508 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled) [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 2, version 0, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] ACPI: IRQ14 used by override. [ 0.000000] ACPI: IRQ15 used by override. [ 0.000000] Setting APIC routing to flat [ 0.000000] ACPI: HPET id: 0x10de8201 base: 0xfed00000 [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000 [ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at 80000000 (gap: 78000000:86c00000) [ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs [ 0.000000] PERCPU: Allocating 37168 bytes of per cpu data [ 0.000000] NR_CPUS: 32, nr_cpu_ids: 4 [ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 483362 [ 0.000000] Policy zone: DMA32 [ 0.000000] Kernel command line: root=/dev/sda1 ro vga=837 [ 0.000000] Initializing CPU#0 [ 0.000000] PID hash table entries: 4096 (order: 12, 32768 bytes) [ 0.000000] Extended CMOS year: 2000 [ 0.000000] TSC calibrated against PM_TIMER [ 0.000000] Marking TSC unstable due to TSCs unsynchronized [ 0.000000] time.c: Detected 2600.000 MHz processor. [ 0.004000] spurious 8259A interrupt: IRQ7. [ 0.004000] Console: colour dummy device 80x25 [ 0.004000] console [tty0] enabled [ 0.004000] Checking aperture... [ 0.004000] Node 0: aperture @ fba000000 size 32 MB [ 0.004000] Aperture beyond 4GB. Ignoring. [ 0.004000] No AGP bridge found [ 0.004000] Memory: 1925140k/1965696k available (2229k kernel code, 40168k reserved, 1084k data, 392k init) [ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated [ 0.004000] hpet clockevent registered [ 0.083828] Calibrating delay using timer specific routine.. 5205.48 BogoMIPS (lpj=10410968) [ 0.083880] Security Framework initialized [ 0.083887] SELinux: Disabled at boot. [ 0.083893] Capability LSM initialized [ 0.084005] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.084005] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.084005] Mount-cache hash table entries: 256 [ 0.084005] Initializing cgroup subsys ns [ 0.084005] Initializing cgroup subsys cpuacct [ 0.084005] Initializing cgroup subsys devices [ 0.084005] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line) [ 0.084005] CPU: L2 Cache: 1024K (64 bytes/line) [ 0.084005] CPU 0/0 -> Node 0 [ 0.084005] CPU: Physical Processor ID: 0 [ 0.084005] CPU: Processor Core ID: 0 [ 0.084005] ACPI: Core revision 20080321 [ 0.136501] CPU0: AMD Athlon(tm) 64 X2 Dual Core Processor 5200+ stepping 02 [ 0.136509] Using local APIC timer interrupts. [ 0.144009] APIC timer calibration result 12500030 [ 0.144009] Detected 12.500 MHz APIC timer. [ 0.144009] Booting processor 1/1 ip 6000 [ 0.152009] Initializing CPU#1 [ 0.152009] Calibrating delay using timer specific routine.. 5200.12 BogoMIPS (lpj=10400241) [ 0.152009] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line) [ 0.152009] CPU: L2 Cache: 1024K (64 bytes/line) [ 0.152009] CPU 1/1 -> Node 0 [ 0.152009] CPU: Physical Processor ID: 0 [ 0.152009] CPU: Processor Core ID: 1 [ 0.231867] CPU1: AMD Athlon(tm) 64 X2 Dual Core Processor 5200+ stepping 02 [ 0.231904] Brought up 2 CPUs [ 0.231909] Total of 2 processors activated (10405.60 BogoMIPS). [ 0.232014] CPU0 attaching sched-domain: [ 0.232014] domain 0: span 0-1 [ 0.232014] groups: 0 1 [ 0.232014] domain 1: span 0-1 [ 0.232014] groups: 0-1 [ 0.232014] CPU1 attaching sched-domain: [ 0.232014] domain 0: span 0-1 [ 0.232014] groups: 1 0 [ 0.232014] domain 1: span 0-1 [ 0.232014] groups: 0-1 [ 0.232014] net_namespace: 1224 bytes [ 0.232014] Booting paravirtualized kernel on bare hardware [ 0.232014] NET: Registered protocol family 16 [ 0.232014] node 0 link 0: io port [1000, ffffff] [ 0.232014] TOM: 0000000080000000 aka 2048M [ 0.232014] node 0 link 0: mmio [e0000000, efffffff] [ 0.232014] node 0 link 0: mmio [80000000, dfffffff] [ 0.232014] node 0 link 0: mmio [f0000000, fe0bffff] [ 0.232014] node 0 link 0: mmio [a0000, bffff] [ 0.232014] bus: [00,07] on node 0 link 0 [ 0.232014] bus: 00 index 0 io port: [0, ffff] [ 0.232014] bus: 00 index 1 mmio: [80000000, fcffffffff] [ 0.232014] bus: 00 index 2 mmio: [a0000, bffff] [ 0.232014] ACPI: bus type pci registered [ 0.232014] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255 [ 0.232014] PCI: Not using MMCONFIG. [ 0.232014] PCI: Using configuration type 1 for base access [ 0.232014] ACPI: EC: Look up EC in DSDT [ 0.251188] ACPI: Interpreter enabled [ 0.251194] ACPI: (supports S0 S1 S3 S4 S5) [ 0.251212] ACPI: Using IOAPIC for interrupt routing [ 0.251280] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255 [ 0.262633] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources [ 0.275753] PCI: Using MMCONFIG at e0000000 - efffffff [ 0.296018] ACPI: PCI Root Bridge [PCI0] (0000:00) [ 0.298477] PCI: Transparent bridge - 0000:00:08.0 [ 0.298901] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.299413] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT] [ 0.299563] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.IXVE._PRT] [ 0.299683] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.MXR0._PRT] [ 0.299822] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR12._PRT] [ 0.299959] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR13._PRT] [ 0.300097] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR14._PRT] [ 0.320829] ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *0, disabled. [ 0.321130] ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *0, disabled. [ 0.321130] ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *11 [ 0.321130] ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled. [ 0.321130] ACPI: PCI Interrupt Link [LN0A] (IRQs 16 17 18 19) *11 [ 0.321130] ACPI: PCI Interrupt Link [LN0B] (IRQs 16 17 18 19) *0, disabled. [ 0.321130] ACPI: PCI Interrupt Link [LN0C] (IRQs 16 17 18 19) *0, disabled. [ 0.321130] ACPI: PCI Interrupt Link [LN0D] (IRQs 16 17 18 19) *0, disabled. [ 0.321436] ACPI: PCI Interrupt Link [LN1A] (IRQs 16 17 18 19) *0, disabled. [ 0.323729] ACPI: PCI Interrupt Link [LN1B] (IRQs 16 17 18 19) *0, disabled. [ 0.324031] ACPI: PCI Interrupt Link [LN1C] (IRQs 16 17 18 19) *0, disabled. [ 0.324335] ACPI: PCI Interrupt Link [LN1D] (IRQs 16 17 18 19) *0, disabled. [ 0.324641] ACPI: PCI Interrupt Link [LN2A] (IRQs 16 17 18 19) *10 [ 0.324943] ACPI: PCI Interrupt Link [LN2B] (IRQs 16 17 18 19) *0, disabled. [ 0.325246] ACPI: PCI Interrupt Link [LN2C] (IRQs 16 17 18 19) *0, disabled. [ 0.325549] ACPI: PCI Interrupt Link [LN2D] (IRQs 16 17 18 19) *0, disabled. [ 0.325856] ACPI: PCI Interrupt Link [LN3A] (IRQs 16 17 18 19) *15 [ 0.326158] ACPI: PCI Interrupt Link [LN3B] (IRQs 16 17 18 19) *0, disabled. [ 0.326460] ACPI: PCI Interrupt Link [LN3C] (IRQs 16 17 18 19) *0, disabled. [ 0.326763] ACPI: PCI Interrupt Link [LN3D] (IRQs 16 17 18 19) *0, disabled. [ 0.327070] ACPI: PCI Interrupt Link [LN4A] (IRQs 16 17 18 19) *7 [ 0.327121] ACPI: PCI Interrupt Link [LN4B] (IRQs 16 17 18 19) *0, disabled. [ 0.327720] ACPI: PCI Interrupt Link [LN4C] (IRQs 16 17 18 19) *0, disabled. [ 0.328023] ACPI: PCI Interrupt Link [LN4D] (IRQs 16 17 18 19) *0, disabled. [ 0.328330] ACPI: PCI Interrupt Link [LN5A] (IRQs 16 17 18 19) *0, disabled. [ 0.328632] ACPI: PCI Interrupt Link [LN5B] (IRQs 16 17 18 19) *0, disabled. [ 0.328935] ACPI: PCI Interrupt Link [LN5C] (IRQs 16 17 18 19) *0, disabled. [ 0.329238] ACPI: PCI Interrupt Link [LN5D] (IRQs 16 17 18 19) *0, disabled. [ 0.329541] ACPI: PCI Interrupt Link [LN6A] (IRQs 16 17 18 19) *0, disabled. [ 0.329843] ACPI: PCI Interrupt Link [LN6B] (IRQs 16 17 18 19) *0, disabled. [ 0.330148] ACPI: PCI Interrupt Link [LN6C] (IRQs 16 17 18 19) *0, disabled. [ 0.330452] ACPI: PCI Interrupt Link [LN6D] (IRQs 16 17 18 19) *0, disabled. [ 0.330756] ACPI: PCI Interrupt Link [LN7A] (IRQs 16 17 18 19) *0, disabled. [ 0.331059] ACPI: PCI Interrupt Link [LN7B] (IRQs 16 17 18 19) *0, disabled. [ 0.331362] ACPI: PCI Interrupt Link [LN7C] (IRQs 16 17 18 19) *0, disabled. [ 0.331711] ACPI: PCI Interrupt Link [LN7D] (IRQs 16 17 18 19) *0, disabled. [ 0.332018] ACPI: PCI Interrupt Link [LUB0] (IRQs 20 21 22 23) *7 [ 0.332326] ACPI: PCI Interrupt Link [LUB2] (IRQs 20 21 22 23) *11 [ 0.332629] ACPI: PCI Interrupt Link [LMAC] (IRQs 20 21 22 23) *0, disabled. [ 0.332936] ACPI: PCI Interrupt Link [LAZA] (IRQs 20 21 22 23) *7 [ 0.333242] ACPI: PCI Interrupt Link [SGRU] (IRQs 20 21 22 23) *11 [ 0.333548] ACPI: PCI Interrupt Link [LSMB] (IRQs 20 21 22 23) *10 [ 0.333854] ACPI: PCI Interrupt Link [LPMU] (IRQs 20 21 22 23) *15 [ 0.334160] ACPI: PCI Interrupt Link [LSA0] (IRQs 20 21 22 23) *5 [ 0.334514] ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22 23) *0, disabled. [ 0.334822] ACPI: PCI Interrupt Link [UB11] (IRQs 20 21 22 23) *10 [ 0.335128] ACPI: PCI Interrupt Link [UB12] (IRQs 20 21 22 23) *15 [ 0.335456] ACPI Warning (tbutils-0217): Incorrect checksum in table [OEMB] - 09, should be 08 [20080321] [ 0.335456] Linux Plug and Play Support v0.97 (c) Adam Belay [ 0.339456] pnp: PnP ACPI init [ 0.339456] ACPI: bus type pnp registered [ 0.339456] pnp 00:00: parse allocated resources [ 0.339456] pnp 00:00: add io 0xcf8-0xcff flags 0x1 [ 0.339456] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active) [ 0.339456] pnp 00:01: parse allocated resources [ 0.339456] pnp 00:01: add dma 4 flags 0x4 [ 0.339456] pnp 00:01: add io 0x0-0xf flags 0x1 [ 0.339456] pnp 00:01: add io 0x81-0x83 flags 0x1 [ 0.339456] pnp 00:01: add io 0x87-0x87 flags 0x1 [ 0.339456] pnp 00:01: add io 0x89-0x8b flags 0x1 [ 0.339456] pnp 00:01: add io 0x8f-0x8f flags 0x1 [ 0.339456] pnp 00:01: add io 0xc0-0xdf flags 0x1 [ 0.339456] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.339456] pnp 00:02: parse allocated resources [ 0.339456] pnp 00:02: add io 0x61-0x61 flags 0x1 [ 0.339456] pnp 00:02: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.339456] pnp 00:03: parse allocated resources [ 0.339456] pnp 00:03: add io 0xf0-0xff flags 0x1 [ 0.339456] pnp 00:03: add irq 13 flags 0x1 [ 0.339456] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.339456] pnp 00:04: parse allocated resources [ 0.339456] pnp 00:04: add io 0x10-0x1f flags 0x1 [ 0.339456] pnp 00:04: add io 0x22-0x3f flags 0x1 [ 0.339456] pnp 00:04: add io 0x44-0x4d flags 0x1 [ 0.339456] pnp 00:04: add io 0x50-0x5f flags 0x1 [ 0.339456] pnp 00:04: add io 0x62-0x63 flags 0x1 [ 0.339456] pnp 00:04: add io 0x65-0x6f flags 0x1 [ 0.339456] pnp 00:04: add io 0x72-0x7f flags 0x1 [ 0.339456] pnp 00:04: add io 0x80-0x80 flags 0x1 [ 0.339456] pnp 00:04: add io 0x84-0x86 flags 0x1 [ 0.339456] pnp 00:04: add io 0x88-0x88 flags 0x1 [ 0.339456] pnp 00:04: add io 0x8c-0x8e flags 0x1 [ 0.339456] pnp 00:04: add io 0x90-0x9f flags 0x1 [ 0.339456] pnp 00:04: add io 0xa2-0xbf flags 0x1 [ 0.339456] pnp 00:04: add io 0xe0-0xef flags 0x1 [ 0.339456] pnp 00:04: add io 0x4d0-0x4d1 flags 0x1 [ 0.339456] pnp 00:04: add io 0x800-0x80f flags 0x1 [ 0.339456] pnp 00:04: add io 0x500-0x57f flags 0x1 [ 0.339456] pnp 00:04: add io 0x580-0x5ff flags 0x1 [ 0.339456] pnp 00:04: add io 0x800-0x87f flags 0x1 [ 0.339456] pnp 00:04: add io 0x880-0x8ff flags 0x1 [ 0.339456] pnp 00:04: add io 0xd00-0xd7f flags 0x1 [ 0.339456] pnp 00:04: add io 0xd80-0xdff flags 0x1 [ 0.339456] pnp 00:04: add io 0xa00-0xafe flags 0x1 [ 0.339456] pnp 00:04: add io 0x900-0x9fd flags 0x1 [ 0.339456] pnp 00:04: add mem 0x0-0xffffffffffffffff flags 0x10000000 [ 0.339456] pnp 00:04: add mem 0x0-0xffffffffffffffff flags 0x10000000 [ 0.339456] pnp 00:04: add mem 0xfed04000-0xfed04fff flags 0x0 [ 0.339456] pnp 00:04: add mem 0xfee01000-0xfeefffff flags 0x0 [ 0.339456] pnp 00:04: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c [ 0.339456] pnp 00:04: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.339456] pnp 00:05: parse allocated resources [ 0.339456] pnp 00:05: add mem 0xfed00000-0xfed00fff flags 0x1 [ 0.339456] pnp 00:05: add irq 8 flags 0x1 [ 0.339456] pnp 00:05: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.339456] pnp 00:06: parse allocated resources [ 0.339456] pnp 00:06: add io 0x70-0x71 flags 0x1 [ 0.339456] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.339456] pnp 00:07: parse allocated resources [ 0.339456] pnp 00:07: add io 0x3f8-0x3ff flags 0x1 [ 0.339456] pnp 00:07: add irq 4 flags 0x1 [ 0.339456] pnp 00:07: parse resource options [ 0.339456] pnp 00:07: new independent option [ 0.339456] pnp 00:07: new dependent option (priority 0x0) [ 0.339456] pnp 00:07: io min 0x3f8 max 0x3f8 align 1 size 8 flags 0x1 [ 0.339456] pnp 00:07: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000010 flags 0x1 [ 0.339456] pnp 00:07: new dependent option (priority 0x1) [ 0.339457] pnp 00:07: io min 0x3f8 max 0x3f8 align 1 size 8 flags 0x1 [ 0.339457] pnp 00:07: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1 [ 0.339457] pnp 00:07: new dependent option (priority 0x1) [ 0.339457] pnp 00:07: io min 0x2f8 max 0x2f8 align 1 size 8 flags 0x1 [ 0.339457] pnp 00:07: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1 [ 0.339457] pnp 00:07: new dependent option (priority 0x1) [ 0.339457] pnp 00:07: io min 0x3e8 max 0x3e8 align 1 size 8 flags 0x1 [ 0.339457] pnp 00:07: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1 [ 0.339457] pnp 00:07: new dependent option (priority 0x1) [ 0.339457] pnp 00:07: io min 0x2e8 max 0x2e8 align 1 size 8 flags 0x1 [ 0.339457] pnp 00:07: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1 [ 0.339457] pnp 00:07: end dependent options [ 0.339457] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.339457] pnp 00:08: parse allocated resources [ 0.339457] pnp 00:08: add io 0x60-0x60 flags 0x1 [ 0.339457] pnp 00:08: add io 0x64-0x64 flags 0x1 [ 0.339457] pnp 00:08: add irq 1 flags 0x1 [ 0.339457] pnp 00:08: Plug and Play ACPI device, IDs PNP0303 PNP030b (active) [ 0.339457] pnp 00:09: parse allocated resources [ 0.339457] pnp 00:09: add irq 12 flags 0x1 [ 0.339457] pnp 00:09: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active) [ 0.339457] pnp 00:0a: parse allocated resources [ 0.339457] pnp 00:0a: add io 0x0-0xffffffffffffffff flags 0x10000001 [ 0.339457] pnp 00:0a: add io 0x230-0x23f flags 0x1 [ 0.339457] pnp 00:0a: add io 0x290-0x29f flags 0x1 [ 0.339457] pnp 00:0a: add io 0xa00-0xa0f flags 0x1 [ 0.339457] pnp 00:0a: add io 0xa10-0xa1f flags 0x1 [ 0.339457] pnp 00:0a: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c [ 0.339457] pnp 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.339457] pnp 00:0b: parse allocated resources [ 0.339457] pnp 00:0b: add mem 0xfec00000-0xfec00fff flags 0x0 [ 0.339457] pnp 00:0b: add mem 0xfee00000-0xfee00fff flags 0x0 [ 0.339457] pnp 00:0b: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c [ 0.339457] pnp 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.343984] pnp 00:0c: parse allocated resources [ 0.344058] pnp 00:0c: add mem 0xe0000000-0xefffffff flags 0x0 [ 0.344060] pnp 00:0c: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c [ 0.344240] pnp 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.344310] pnp 00:0d: parse allocated resources [ 0.344527] pnp 00:0d: add mem 0x0-0x9ffff flags 0x1 [ 0.344529] pnp 00:0d: add mem 0xc0000-0xcffff flags 0x0 [ 0.344531] pnp 00:0d: add mem 0xe0000-0xfffff flags 0x0 [ 0.344533] pnp 00:0d: add mem 0x100000-0x7fffffff flags 0x1 [ 0.344535] pnp 00:0d: add mem 0xfec00000-0xffffffff flags 0x0 [ 0.344537] pnp 00:0d: PNP0c01: calling quirk_system_pci_resources+0x0/0x15c [ 0.344722] pnp 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.348938] pnp: PnP ACPI: found 14 devices [ 0.348943] ACPI: ACPI bus type pnp unregistered [ 0.349815] usbcore: registered new interface driver usbfs [ 0.349815] usbcore: registered new interface driver hub [ 0.349815] usbcore: registered new device driver usb [ 0.349815] PCI: Using ACPI for IRQ routing [ 0.369816] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 31 [ 0.369816] hpet0: 3 32-bit timers, 25000000 Hz [ 0.369816] ACPI: RTC can wake from S4 [ 0.372654] Switched to high resolution mode on CPU 0 [ 0.373958] Switched to high resolution mode on CPU 1 [ 0.384608] pnp: the driver 'system' has been registered [ 0.384618] system 00:04: ioport range 0x4d0-0x4d1 has been reserved [ 0.384624] system 00:04: ioport range 0x800-0x80f has been reserved [ 0.384629] system 00:04: ioport range 0x500-0x57f has been reserved [ 0.384635] system 00:04: ioport range 0x580-0x5ff has been reserved [ 0.384640] system 00:04: ioport range 0x800-0x87f could not be reserved [ 0.384646] system 00:04: ioport range 0x880-0x8ff has been reserved [ 0.384652] system 00:04: ioport range 0xd00-0xd7f has been reserved [ 0.384657] system 00:04: ioport range 0xd80-0xdff has been reserved [ 0.384663] system 00:04: ioport range 0xa00-0xafe has been reserved [ 0.384668] system 00:04: ioport range 0x900-0x9fd has been reserved [ 0.384675] system 00:04: iomem range 0xfed04000-0xfed04fff has been reserved [ 0.384681] system 00:04: iomem range 0xfee01000-0xfeefffff could not be reserved [ 0.384688] system 00:04: driver attached [ 0.384694] system 00:0a: ioport range 0x230-0x23f has been reserved [ 0.384699] system 00:0a: ioport range 0x290-0x29f has been reserved [ 0.384705] system 00:0a: ioport range 0xa00-0xa0f has been reserved [ 0.384710] system 00:0a: ioport range 0xa10-0xa1f has been reserved [ 0.384716] system 00:0a: driver attached [ 0.384721] system 00:0b: iomem range 0xfec00000-0xfec00fff could not be reserved [ 0.384729] system 00:0b: iomem range 0xfee00000-0xfee00fff could not be reserved [ 0.384736] system 00:0b: driver attached [ 0.384741] system 00:0c: iomem range 0xe0000000-0xefffffff has been reserved [ 0.384747] system 00:0c: driver attached [ 0.384752] system 00:0d: iomem range 0x0-0x9ffff could not be reserved [ 0.384757] system 00:0d: iomem range 0xc0000-0xcffff has been reserved [ 0.384763] system 00:0d: iomem range 0xe0000-0xfffff could not be reserved [ 0.384768] system 00:0d: iomem range 0x100000-0x7fffffff could not be reserved [ 0.384776] system 00:0d: iomem range 0xfec00000-0xffffffff could not be reserved [ 0.384783] system 00:0d: driver attached [ 0.386299] PCI: Bridge: 0000:00:08.0 [ 0.386299] IO window: c000-cfff [ 0.386299] MEM window: 0xfcf00000-0xfcffffff [ 0.386299] PREFETCH window: disabled. [ 0.386299] PCI: Bridge: 0000:00:0b.0 [ 0.386299] IO window: d000-dfff [ 0.386299] MEM window: 0xfd000000-0xfeafffff [ 0.386299] PREFETCH window: 0x00000000ce000000-0x00000000dfffffff [ 0.386299] PCI: Bridge: 0000:00:10.0 [ 0.386299] IO window: disabled. [ 0.386299] MEM window: disabled. [ 0.386299] PREFETCH window: disabled. [ 0.386299] PCI: Bridge: 0000:00:12.0 [ 0.386299] IO window: e000-efff [ 0.386299] MEM window: 0xfeb00000-0xfebfffff [ 0.386299] PREFETCH window: disabled. [ 0.386299] PCI: Bridge: 0000:00:13.0 [ 0.386299] IO window: disabled. [ 0.386299] MEM window: disabled. [ 0.386299] PREFETCH window: disabled. [ 0.386299] PCI: Bridge: 0000:00:14.0 [ 0.386299] IO window: disabled. [ 0.386299] MEM window: disabled. [ 0.386299] PREFETCH window: disabled. [ 0.386299] PCI: Setting latency timer of device 0000:00:08.0 to 64 [ 0.386299] PCI: Setting latency timer of device 0000:00:0b.0 to 64 [ 0.386299] ACPI: PCI Interrupt Link [LN0A] enabled at IRQ 19 [ 0.386299] ACPI: PCI Interrupt 0000:00:10.0[A] -> Link [LN0A] -> GSI 19 (level, low) -> IRQ 19 [ 0.386299] PCI: Setting latency timer of device 0000:00:10.0 to 64 [ 0.386299] ACPI: PCI Interrupt Link [LN2A] enabled at IRQ 18 [ 0.386299] ACPI: PCI Interrupt 0000:00:12.0[A] -> Link [LN2A] -> GSI 18 (level, low) -> IRQ 18 [ 0.386299] PCI: Setting latency timer of device 0000:00:12.0 to 64 [ 0.386299] ACPI: PCI Interrupt Link [LN3A] enabled at IRQ 17 [ 0.386299] ACPI: PCI Interrupt 0000:00:13.0[A] -> Link [LN3A] -> GSI 17 (level, low) -> IRQ 17 [ 0.386299] PCI: Setting latency timer of device 0000:00:13.0 to 64 [ 0.386299] ACPI: PCI Interrupt Link [LN4A] enabled at IRQ 16 [ 0.386299] ACPI: PCI Interrupt 0000:00:14.0[A] -> Link [LN4A] -> GSI 16 (level, low) -> IRQ 16 [ 0.386299] PCI: Setting latency timer of device 0000:00:14.0 to 64 [ 0.386299] NET: Registered protocol family 2 [ 0.425624] IP route cache hash table entries: 65536 (order: 7, 524288 bytes) [ 0.426474] TCP established hash table entries: 262144 (order: 10, 4194304 bytes) [ 0.428427] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes) [ 0.428427] TCP: Hash tables configured (established 262144 bind 65536) [ 0.428427] TCP reno registered [ 0.441613] NET: Registered protocol family 1 [ 0.441709] checking if image is initramfs... it is [ 0.818084] Freeing initrd memory: 6565k freed [ 0.825112] audit: initializing netlink socket (disabled) [ 0.825112] type=2000 audit(1284720103.808:1): initialized [ 0.825112] Total HugeTLB memory allocated, 0 [ 0.825112] VFS: Disk quotas dquot_6.5.1 [ 0.825112] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.825112] msgmni has been set to 3772 [ 0.825112] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.825112] io scheduler noop registered [ 0.825112] io scheduler anticipatory registered [ 0.825112] io scheduler deadline registered [ 0.825112] io scheduler cfq registered (default) [ 0.890948] pci 0000:00:07.0: Enabling HT MSI Mapping [ 0.890980] pci 0000:00:08.0: Enabling HT MSI Mapping [ 0.891012] pci 0000:00:09.0: Enabling HT MSI Mapping [ 0.891042] pci 0000:00:0b.0: Enabling HT MSI Mapping [ 0.891100] pci 0000:00:10.0: Enabling HT MSI Mapping [ 0.891169] pci 0000:00:12.0: Enabling HT MSI Mapping [ 0.891238] pci 0000:00:13.0: Enabling HT MSI Mapping [ 0.891306] pci 0000:00:14.0: Enabling HT MSI Mapping [ 0.891356] pci 0000:02:00.0: Boot video device [ 0.893107] PCI: Setting latency timer of device 0000:00:10.0 to 64 [ 0.893107] assign_interrupt_mode Found MSI capability [ 0.893107] Allocate Port Service[0000:00:10.0:pcie00] [ 0.893107] PCI: Setting latency timer of device 0000:00:12.0 to 64 [ 0.893107] assign_interrupt_mode Found MSI capability [ 0.893107] Allocate Port Service[0000:00:12.0:pcie00] [ 0.893107] PCI: Setting latency timer of device 0000:00:13.0 to 64 [ 0.893107] assign_interrupt_mode Found MSI capability [ 0.893107] Allocate Port Service[0000:00:13.0:pcie00] [ 0.893107] PCI: Setting latency timer of device 0000:00:14.0 to 64 [ 0.893107] assign_interrupt_mode Found MSI capability [ 0.893107] Allocate Port Service[0000:00:14.0:pcie00] [ 0.893107] vesafb: framebuffer at 0xcf000000, mapped to 0xffffc20010980000, using 3750k, total 14336k [ 0.893107] vesafb: mode is 1600x1200x8, linelength=1600, pages=1 [ 0.893107] vesafb: scrolling: redraw [ 0.893107] vesafb: Pseudocolor: size=8:8:8:8, shift=0:0:0:0 [ 0.903049] Console: switching to colour frame buffer device 200x75 [ 0.911962] fb0: VESA VGA frame buffer device [ 0.913107] hpet_resources: 0xfed00000 is busy [ 0.913107] Linux agpgart interface v0.103 [ 0.913107] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled [ 0.913107] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.917110] pnp: the driver 'serial' has been registered [ 0.917110] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.917110] serial 00:07: driver attached [ 0.917110] brd: module loaded [ 0.917110] input: Macintosh mouse button emulation as /class/input/input0 [ 0.917110] pnp: the driver 'i8042 kbd' has been registered [ 0.917110] i8042 kbd 00:08: driver attached [ 0.917110] pnp: the driver 'i8042 aux' has been registered [ 0.917110] i8042 aux 00:09: driver attached [ 0.917110] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12 [ 0.921109] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 0.921109] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 0.940919] mice: PS/2 mouse device common for all mice [ 0.941109] pnp: the driver 'rtc_cmos' has been registered [ 0.941109] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0 [ 0.941109] rtc0: alarms up to one year, y3k [ 0.941109] rtc_cmos 00:06: driver attached [ 0.941109] cpuidle: using governor ladder [ 0.941109] cpuidle: using governor menu [ 0.941109] No iBFT detected. [ 0.941109] TCP cubic registered [ 0.941109] NET: Registered protocol family 17 [ 0.941109] registered taskstats version 1 [ 0.941109] rtc_cmos 00:06: setting system clock to 2010-09-17 10:41:45 UTC (1284720105) [ 0.941109] Freeing unused kernel memory: 392k freed [ 0.956898] input: AT Translated Set 2 keyboard as /class/input/input1 [ 1.028200] ACPI: ACPI0007:00 is registered as cooling_device0 [ 1.028200] ACPI: ACPI0007:01 is registered as cooling_device1 [ 1.316749] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.317222] ACPI: PCI Interrupt Link [LUB0] enabled at IRQ 23 [ 1.317278] ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LUB0] -> GSI 23 (level, low) -> IRQ 23 [ 1.317353] PCI: Setting latency timer of device 0000:00:02.0 to 64 [ 1.317356] ohci_hcd 0000:00:02.0: OHCI Host Controller [ 1.317527] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1 [ 1.317599] ohci_hcd 0000:00:02.0: irq 23, io mem 0xfce7f000 [ 1.335765] No dock devices found. [ 1.345672] SCSI subsystem initialized [ 1.357673] libata version 3.00 loaded. [ 1.372526] usb usb1: configuration #1 chosen from 1 choice [ 1.372599] hub 1-0:1.0: USB hub found [ 1.372635] hub 1-0:1.0: 6 ports detected [ 1.475553] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.475612] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.475665] usb usb1: Product: OHCI Host Controller [ 1.475701] usb usb1: Manufacturer: Linux 2.6.26-2-amd64 ohci_hcd [ 1.475745] usb usb1: SerialNumber: 0000:00:02.0 [ 1.477674] ACPI: PCI Interrupt Link [UB11] enabled at IRQ 22 [ 1.477674] ACPI: PCI Interrupt 0000:00:04.0[A] -> Link [UB11] -> GSI 22 (level, low) -> IRQ 22 [ 1.477674] PCI: Setting latency timer of device 0000:00:04.0 to 64 [ 1.477674] ohci_hcd 0000:00:04.0: OHCI Host Controller [ 1.477674] ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2 [ 1.477674] ohci_hcd 0000:00:04.0: irq 22, io mem 0xfce7d000 [ 1.531233] usb usb2: configuration #1 chosen from 1 choice [ 1.531299] hub 2-0:1.0: USB hub found [ 1.531334] hub 2-0:1.0: 6 ports detected [ 1.634925] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.636470] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.639965] usb usb2: Product: OHCI Host Controller [ 1.643965] usb usb2: Manufacturer: Linux 2.6.26-2-amd64 ohci_hcd [ 1.643965] usb usb2: SerialNumber: 0000:00:04.0 [ 1.684426] ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 21 [ 1.684426] ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [LUB2] -> GSI 21 (level, low) -> IRQ 21 [ 1.684440] PCI: Setting latency timer of device 0000:00:02.1 to 64 [ 1.684444] ehci_hcd 0000:00:02.1: EHCI Host Controller [ 1.688123] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 3 [ 1.688123] ehci_hcd 0000:00:02.1: debug port 1 [ 1.689893] PCI: cache line size of 64 is not supported by device 0000:00:02.1 [ 1.689906] ehci_hcd 0000:00:02.1: irq 21, io mem 0xfce7ec00 [ 1.703966] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004 [ 1.707960] usb usb3: configuration #1 chosen from 1 choice [ 1.707960] hub 3-0:1.0: USB hub found [ 1.709825] hub 3-0:1.0: 6 ports detected [ 1.812038] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.813963] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.815901] usb usb3: Product: EHCI Host Controller [ 1.817873] usb usb3: Manufacturer: Linux 2.6.26-2-amd64 ehci_hcd [ 1.821870] usb usb3: SerialNumber: 0000:00:02.1 [ 1.825876] ACPI: PCI Interrupt Link [UB12] enabled at IRQ 20 [ 1.827918] ACPI: PCI Interrupt 0000:00:04.1[B] -> Link [UB12] -> GSI 20 (level, low) -> IRQ 20 [ 1.829950] PCI: Setting latency timer of device 0000:00:04.1 to 64 [ 1.829950] ehci_hcd 0000:00:04.1: EHCI Host Controller [ 1.832099] ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 4 [ 1.834180] ehci_hcd 0000:00:04.1: debug port 1 [ 1.838185] PCI: cache line size of 64 is not supported by device 0000:00:04.1 [ 1.838193] ehci_hcd 0000:00:04.1: irq 20, io mem 0xfce7e800 [ 1.981574] usb 2-3: new full speed USB device using ohci_hcd and address 2 [ 1.993574] ehci_hcd 0000:00:04.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004 [ 1.995749] usb usb4: configuration #1 chosen from 1 choice [ 1.997914] hub 4-0:1.0: USB hub found [ 2.002365] hub 4-0:1.0: 6 ports detected [ 2.057784] hub 2-0:1.0: unable to enumerate USB device on port 3 [ 2.141379] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.143516] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.145630] usb usb4: Product: EHCI Host Controller [ 2.149628] usb usb4: Manufacturer: Linux 2.6.26-2-amd64 ehci_hcd [ 2.151762] usb usb4: SerialNumber: 0000:00:04.1 [ 2.153884] ahci 0000:00:09.0: version 3.0 [ 2.153884] ACPI: PCI Interrupt Link [LSA0] enabled at IRQ 23 [ 2.155979] ACPI: PCI Interrupt 0000:00:09.0[A] -> Link [LSA0] -> GSI 23 (level, low) -> IRQ 23 [ 2.456757] usb 4-3: new high speed USB device using ehci_hcd and address 2 [ 2.683184] usb 4-3: configuration #1 chosen from 1 choice [ 2.736558] usb 4-3: New USB device found, idVendor=05dc, idProduct=a731 [ 2.738721] usb 4-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2.741291] usb 4-3: Product: JD FireFly [ 2.743440] usb 4-3: Manufacturer: Lexar [ 2.745585] usb 4-3: SerialNumber: AA04015200003289 [ 3.375973] ahci 0000:00:09.0: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl IDE mode [ 3.378182] ahci 0000:00:09.0: flags: 64bit ncq sntf led clo pmp pio [ 3.380375] PCI: Setting latency timer of device 0000:00:09.0 to 64 [ 3.380979] scsi0 : ahci [ 3.383402] scsi1 : ahci [ 3.387096] scsi2 : ahci [ 3.389215] scsi3 : ahci [ 3.391381] scsi4 : ahci [ 3.393412] scsi5 : ahci [ 3.393574] ata1: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76100 irq 1275 [ 3.395602] ata2: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76180 irq 1275 [ 3.397614] ata3: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76200 irq 1275 [ 3.399598] ata4: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76280 irq 1275 [ 3.401616] ata5: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76300 irq 1275 [ 3.403565] ata6: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76380 irq 1275 [ 3.983970] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 3.987341] ata1.00: ATA-8: MAXTOR STM3500320AS, MX15, max UDMA/133 [ 3.989939] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32) [ 3.993263] ata1.00: configured for UDMA/133 [ 4.340677] ata2: SATA link down (SStatus 0 SControl 300) [ 4.660282] ata3: SATA link down (SStatus 0 SControl 300) [ 4.997279] ata4: SATA link down (SStatus 0 SControl 300) [ 5.352776] ata5: SATA link down (SStatus 0 SControl 300) [ 5.707657] ata6: SATA link down (SStatus 0 SControl 300) [ 5.715643] scsi 0:0:0:0: Direct-Access ATA MAXTOR STM350032 MX15 PQ: 0 ANSI: 5 [ 5.724425] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 19 [ 5.724425] ACPI: PCI Interrupt 0000:01:06.0[A] -> Link [LNKC] -> GSI 19 (level, low) -> IRQ 19 [ 5.782775] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[19] MMIO=[fcfff800-fcffffff] Max Packet=[2048] IR/IT contexts=[4/8] [ 5.791639] Uniform Multi-Platform E-IDE driver [ 5.791980] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx [ 5.795177] ACPI: PCI Interrupt 0000:04:00.0[A] -> Link [LN2A] -> GSI 18 (level, low) -> IRQ 18 [ 5.797289] PCI: Setting latency timer of device 0000:04:00.0 to 64 [ 5.797320] sky2 0000:04:00.0: v1.21 addr 0xfebfc000 irq 18 Yukon-EC Ultra (0xb4) rev 3 [ 5.799691] sky2 eth0: addr 00:1f:c6:d7:71:4e [ 5.804505] NFORCE-MCP77: 0000:00:06.0 (rev a1) UDMA133 controller [ 5.806587] NFORCE-MCP77: IDE controller (0x10de:0x0759 rev 0xa1) at PCI slot 0000:00:06.0 [ 5.808273] NFORCE-MCP77: not 100% native mode: will probe irqs later [ 5.810400] NFORCE-MCP77: BIOS didn't set cable bits correctly. Enabling workaround. [ 5.812414] NFORCE-MCP77: IDE port disabled [ 5.814431] ide0: BM-DMA at 0xffa0-0xffa7 [ 5.814437] Probing IDE interface ide0... [ 5.852671] Driver 'sd' needs updating - please use bus_type methods [ 5.852671] sd 0:0:0:0: [sda] 976773168 512-byte hardware sectors (500108 MB) [ 5.854771] sd 0:0:0:0: [sda] Write Protect is off [ 5.856858] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 5.856891] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 5.861543] sd 0:0:0:0: [sda] 976773168 512-byte hardware sectors (500108 MB) [ 5.863653] sd 0:0:0:0: [sda] Write Protect is off [ 5.864971] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 5.864971] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 5.867086] sda:<6>Initializing USB Mass Storage driver... [ 5.877666] scsi6 : SCSI emulation for USB Mass Storage devices [ 5.877666] sda1 sda2 <<7>usb-storage: device found at 2 [ 5.877666] usbcore: registered new interface driver usb-storage [ 5.877666] USB Mass Storage support registered. [ 5.887204] usb-storage: waiting for device to settle before scanning [ 5.889876] sda5 sda6 sda7 sda8 sda9 > [ 5.917237] sd 0:0:0:0: [sda] Attached SCSI disk [ 6.591721] hda: HL-DT-STDVD-RAM GH22NP20, ATAPI CD/DVD-ROM drive [ 6.927661] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4 [ 6.927821] hda: UDMA/66 mode selected [ 6.933882] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14 [ 6.966596] hda: ATAPI 48X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache [ 6.968702] Uniform CD-ROM driver Revision: 3.20 [ 7.078599] PM: Starting manual resume from disk [ 7.108299] kjournald starting. Commit interval 5 seconds [ 7.110420] EXT3-fs: mounted filesystem with ordered data mode. [ 7.128468] ieee1394: Host added: ID:BUS[0-00:1023] GUID[001e8c0001434cf8] [ 7.929062] udevd version 125 started [ 8.404563] input: Power Button (FF) as /class/input/input2 [ 8.462106] ACPI: Power Button (FF) [PWRF] [ 8.464372] input: Power Button (CM) as /class/input/input3 [ 8.527334] ACPI: Power Button (CM) [PWRB] [ 8.754074] ACPI: WMI: Mapper loaded [ 8.913923] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 8.923243] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 [ 9.064219] input: PC Speaker as /class/input/input4 [ 9.249919] logips2pp: Detected unknown logitech mouse model 115 [ 9.263115] ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 22 [ 9.264921] ACPI: PCI Interrupt 0000:00:07.0[A] -> Link [LAZA] -> GSI 22 (level, low) -> IRQ 22 [ 9.267269] PCI: Setting latency timer of device 0000:00:07.0 to 64 [ 9.300916] hda_codec: Unknown model for ALC883, trying auto-probe from BIOS... [ 9.512864] input: ImExPS/2 Logitech Explorer Mouse as /class/input/input5 [ 10.603344] Adding 5662872k swap on /dev/sda7. Priority:-1 extents:1 across:5662872k [ 10.795831] EXT3 FS on sda1, internal journal [ 10.994356] usb-storage: device scan complete [ 10.994356] isa bounce pool size: 16 pages [ 10.996673] scsi 6:0:0:0: Direct-Access Lexar JD FireFly 1100 PQ: 0 ANSI: 0 CCS [ 11.042647] sd 6:0:0:0: [sdb] 7831552 512-byte hardware sectors (4010 MB) [ 11.046906] sd 6:0:0:0: [sdb] Write Protect is off [ 11.048514] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00 [ 11.048514] sd 6:0:0:0: [sdb] Assuming drive cache: write through [ 11.064513] sd 6:0:0:0: [sdb] 7831552 512-byte hardware sectors (4010 MB) [ 11.068513] sd 6:0:0:0: [sdb] Write Protect is off [ 11.070204] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00 [ 11.070204] sd 6:0:0:0: [sdb] Assuming drive cache: write through [ 11.072732] sdb: sdb1 [ 11.078202] sd 6:0:0:0: [sdb] Attached SCSI removable disk [ 11.674095] loop: module loaded [ 27.119547] kjournald starting. Commit interval 5 seconds [ 27.119547] EXT3-fs warning: maximal mount count reached, running e2fsck is recommended [ 27.135919] EXT3 FS on sda9, internal journal [ 27.135923] EXT3-fs: mounted filesystem with ordered data mode. [ 27.167554] kjournald starting. Commit interval 5 seconds [ 27.168783] EXT3 FS on sda8, internal journal [ 27.168783] EXT3-fs: mounted filesystem with ordered data mode. [ 27.227559] kjournald starting. Commit interval 5 seconds [ 27.227559] EXT3 FS on sda5, internal journal [ 27.227559] EXT3-fs: mounted filesystem with ordered data mode. [ 27.296098] kjournald starting. Commit interval 5 seconds [ 27.296098] EXT3 FS on sda6, internal journal [ 27.296098] EXT3-fs: mounted filesystem with ordered data mode. [ 29.077929] sky2 eth0: enabling interface [ 31.008900] sky2 eth0: Link is up at 100 Mbps, full duplex, flow control both [ 32.036887] powernow-k8: Found 1 AMD Athlon(tm) 64 X2 Dual Core Processor 5200+ processors (2 cpu cores) (version 2.20.00) [ 32.038099] powernow-k8: 0 : fid 0x12 (2600 MHz), vid 0x8 [ 32.038099] powernow-k8: 1 : fid 0x10 (2400 MHz), vid 0xa [ 32.038099] powernow-k8: 2 : fid 0xe (2200 MHz), vid 0xc [ 32.038099] powernow-k8: 3 : fid 0xc (2000 MHz), vid 0xe [ 32.038099] powernow-k8: 4 : fid 0xa (1800 MHz), vid 0x10 [ 32.038099] powernow-k8: 5 : fid 0x2 (1000 MHz), vid 0x12 [ 33.539217] Clocksource tsc unstable (delta = -258383627 ns) [ 34.695338] pnp: the driver 'parport_pc' has been registered [ 34.696280] lp: driver loaded but no devices found [ 34.860281] ppdev: user-space parallel port driver [ 36.483776] NET: Registered protocol family 10 [ 36.493117] lo: Disabled Privacy Extensions [ 40.846277] nvidia: module license 'NVIDIA' taints kernel. [ 41.113783] ACPI: PCI Interrupt Link [SGRU] enabled at IRQ 21 [ 41.113786] ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [SGRU] -> GSI 21 (level, low) -> IRQ 21 [ 41.113793] PCI: Setting latency timer of device 0000:02:00.0 to 64 [ 41.113931] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 173.14.09 Wed Jun 4 23:40:50 PDT 2008 [ 47.952828] eth0: no IPv6 routers present [ 58.655922] warning: `ntpd' uses 32-bit capabilities (legacy support in use) et je bloque systématiquement à [ 11.674095] loop: module loaded
J’ai eu beau chercher un peu sur le Net, mais je n’ai trouvé personne qui ait déjà eu le même soucis… (par contre je suis tombé sur une quantité de “loop: module loaded” qui n’étaient en fait que portions de dmesg ! :083 )
Quelqu’un pourrait-il m’indiquer vers quelle direction chercher parce que là…
Merci d’avance à vous,
Eric
aucune idée, mai essaye peux etre sans l’acpi depuis le grub ?
Salut panthere,
Merci pour ta proposition… mais ça ne semble pas une bonne idée de supprimer l’acpi… vu ce que ça m’a apporté comme frayeurs : j’ai été obligé d’utiliser les magickeys pour m’en sortir !
Et de toute façon ça s’est bloqué entre-autre au même endroit! (en plus de ceux où apparaissent les résultats des magickeys bien-sur : [ 73.220637] et [ 91.671353])
[ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 2.6.26-2-amd64 (Debian 2.6.26-24lenny1) (dannf@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25)) #1 SMP Thu Aug 19 00:37:36 UTC 2010 [ 0.000000] Command line: root=/dev/sda1 ro vga=837 acpi=off [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable) [ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 0000000077fa0000 (usable) [ 0.000000] BIOS-e820: 0000000077fa0000 - 0000000077fae000 (ACPI data) [ 0.000000] BIOS-e820: 0000000077fae000 - 0000000077fe0000 (ACPI NVS) [ 0.000000] BIOS-e820: 0000000077fe0000 - 0000000078000000 (reserved) [ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved) [ 0.000000] BIOS-e820: 00000000ff700000 - 0000000100000000 (reserved) [ 0.000000] Entering add_active_range(0, 0, 159) 0 entries of 3200 used [ 0.000000] Entering add_active_range(0, 256, 491424) 1 entries of 3200 used [ 0.000000] max_pfn_mapped = 1048576 [ 0.000000] init_memory_mapping [ 0.000000] DMI 2.3 present. [ 0.000000] Scanning NUMA topology in Northbridge 24 [ 0.000000] No NUMA configuration found [ 0.000000] Faking a node at 0000000000000000-0000000077fa0000 [ 0.000000] Entering add_active_range(0, 0, 159) 0 entries of 3200 used [ 0.000000] Entering add_active_range(0, 256, 491424) 1 entries of 3200 used [ 0.000000] Bootmem setup node 0 0000000000000000-0000000077fa0000 [ 0.000000] NODE_DATA [000000000000c000 - 0000000000010fff] [ 0.000000] bootmap [0000000000011000 - 000000000001fff7] pages f [ 0.000000] early res: 0 [0-fff] BIOS data page [ 0.000000] early res: 1 [6000-7fff] TRAMPOLINE [ 0.000000] early res: 2 [200000-675397] TEXT DATA BSS [ 0.000000] early res: 3 [37986000-37fef6a2] RAMDISK [ 0.000000] early res: 4 [9fc00-fffff] BIOS reserved [ 0.000000] early res: 5 [8000-bfff] PGTABLE [ 0.000000] [ffffe20000000000-ffffe20001bfffff] PMD -> [ffff810001200000-ffff810002dfffff] on node 0 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0 -> 4096 [ 0.000000] DMA32 4096 -> 1048576 [ 0.000000] Normal 1048576 -> 1048576 [ 0.000000] Movable zone start PFN for each node [ 0.000000] early_node_map[2] active PFN ranges [ 0.000000] 0: 0 -> 159 [ 0.000000] 0: 256 -> 491424 [ 0.000000] On node 0 totalpages: 491327 [ 0.000000] DMA zone: 56 pages used for memmap [ 0.000000] DMA zone: 1246 pages reserved [ 0.000000] DMA zone: 2697 pages, LIFO batch:0 [ 0.000000] DMA32 zone: 6663 pages used for memmap [ 0.000000] DMA32 zone: 480665 pages, LIFO batch:31 [ 0.000000] Normal zone: 0 pages used for memmap [ 0.000000] Movable zone: 0 pages used for memmap [ 0.000000] Nvidia board detected. Ignoring ACPI timer override. [ 0.000000] If you got timer trouble try acpi_use_timer_override [ 0.000000] Detected use of extended apic ids on hypertransport bus [ 0.000000] Intel MultiProcessor Specification v1.4 [ 0.000000] MPTABLE: OEM ID: TEMPLATE Product ID: T-M3N8200 <6>MPTABLE: Product ID: T-M3N8200 <6>MPTABLE: APIC at: 0xFEE00000 [ 0.000000] Processor #0 (Bootup-CPU) [ 0.000000] Processor #1 [ 0.000000] I/O APIC #2 Version 17 at 0xFEC00000. [ 0.000000] Setting APIC routing to flat [ 0.000000] Processors: 2 [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000 [ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at 80000000 (gap: 78000000:86c00000) [ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs [ 0.000000] PERCPU: Allocating 37168 bytes of per cpu data [ 0.000000] NR_CPUS: 32, nr_cpu_ids: 2 [ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 483362 [ 0.000000] Policy zone: DMA32 [ 0.000000] Kernel command line: root=/dev/sda1 ro vga=837 acpi=off [ 0.000000] Initializing CPU#0 [ 0.000000] PID hash table entries: 4096 (order: 12, 32768 bytes) [ 0.000000] TSC calibrated against PIT [ 0.000000] Marking TSC unstable due to TSCs unsynchronized [ 0.000000] time.c: Detected 2600.022 MHz processor. [ 0.004000] spurious 8259A interrupt: IRQ7. [ 0.004000] Console: colour dummy device 80x25 [ 0.004000] console [tty0] enabled [ 0.004000] Checking aperture... [ 0.004000] Node 0: aperture @ fba000000 size 32 MB [ 0.004000] Aperture beyond 4GB. Ignoring. [ 0.004000] No AGP bridge found [ 0.004000] Memory: 1925220k/1965696k available (2229k kernel code, 40088k reserved, 1084k data, 392k init) [ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated [ 0.084008] Calibrating delay using timer specific routine.. 5205.82 BogoMIPS (lpj=10411645) [ 0.084059] Security Framework initialized [ 0.084067] SELinux: Disabled at boot. [ 0.084072] Capability LSM initialized [ 0.084269] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.085440] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.086093] Mount-cache hash table entries: 256 [ 0.086250] Initializing cgroup subsys ns [ 0.086257] Initializing cgroup subsys cpuacct [ 0.086262] Initializing cgroup subsys devices [ 0.086283] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line) [ 0.086289] CPU: L2 Cache: 1024K (64 bytes/line) [ 0.086293] CPU 0/0 -> Node 0 [ 0.086307] CPU: Physical Processor ID: 0 [ 0.086310] CPU: Processor Core ID: 0 [ 0.087060] ExtINT not setup in hardware but reported by MP table [ 0.127513] CPU0: AMD Athlon(tm) 64 X2 Dual Core Processor 5200+ stepping 02 [ 0.127520] Using local APIC timer interrupts. [ 0.132008] APIC timer calibration result 12500148 [ 0.132008] Detected 12.500 MHz APIC timer. [ 0.132008] Booting processor 1/1 ip 6000 [ 0.140008] Initializing CPU#1 [ 0.140008] Calibrating delay using timer specific routine.. 5200.10 BogoMIPS (lpj=10400214) [ 0.140008] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line) [ 0.140008] CPU: L2 Cache: 1024K (64 bytes/line) [ 0.140008] CPU 1/1 -> Node 0 [ 0.140008] CPU: Physical Processor ID: 0 [ 0.140008] CPU: Processor Core ID: 1 [ 0.219894] CPU1: AMD Athlon(tm) 64 X2 Dual Core Processor 5200+ stepping 02 [ 0.219932] Brought up 2 CPUs [ 0.219936] Total of 2 processors activated (10405.92 BogoMIPS). [ 0.220013] CPU0 attaching sched-domain: [ 0.220013] domain 0: span 0-1 [ 0.220013] groups: 0 1 [ 0.220013] domain 1: span 0-1 [ 0.220013] groups: 0-1 [ 0.220013] CPU1 attaching sched-domain: [ 0.220013] domain 0: span 0-1 [ 0.220013] groups: 1 0 [ 0.220013] domain 1: span 0-1 [ 0.220013] groups: 0-1 [ 0.220013] net_namespace: 1224 bytes [ 0.220013] Booting paravirtualized kernel on bare hardware [ 0.220013] NET: Registered protocol family 16 [ 0.220013] node 0 link 0: io port [1000, ffffff] [ 0.220013] TOM: 0000000080000000 aka 2048M [ 0.220013] node 0 link 0: mmio [e0000000, efffffff] [ 0.220013] node 0 link 0: mmio [80000000, dfffffff] [ 0.220013] node 0 link 0: mmio [f0000000, fe0bffff] [ 0.220013] node 0 link 0: mmio [a0000, bffff] [ 0.220013] bus: [00,07] on node 0 link 0 [ 0.220013] bus: 00 index 0 io port: [0, ffff] [ 0.220013] bus: 00 index 1 mmio: [80000000, fcffffffff] [ 0.220013] bus: 00 index 2 mmio: [a0000, bffff] [ 0.220013] PCI: Using configuration type 1 for base access [ 0.220013] ACPI: Interpreter disabled. [ 0.220013] Linux Plug and Play Support v0.97 (c) Adam Belay [ 0.220013] pnp: PnP ACPI: disabled [ 0.220013] usbcore: registered new interface driver usbfs [ 0.220013] usbcore: registered new interface driver hub [ 0.220013] usbcore: registered new device driver usb [ 0.220013] PCI: Probing PCI hardware [ 0.220013] PCI: Probing PCI hardware (bus 00) [ 0.220013] PCI: Transparent bridge - 0000:00:08.0 [ 0.224014] PCI: Using IRQ router default [10de/0568] at 0000:00:01.4 [ 0.224014] PCI->APIC IRQ transform: 0000:00:01.1[A] -> IRQ 10 [ 0.224014] PCI->APIC IRQ transform: 0000:00:01.3[B] -> IRQ 15 [ 0.224014] PCI->APIC IRQ transform: 0000:00:02.0[A] -> IRQ 7 [ 0.224014] PCI->APIC IRQ transform: 0000:00:02.1[B] -> IRQ 11 [ 0.224014] PCI->APIC IRQ transform: 0000:00:04.0[A] -> IRQ 10 [ 0.224014] PCI->APIC IRQ transform: 0000:00:04.1[B] -> IRQ 15 [ 0.224014] PCI->APIC IRQ transform: 0000:00:07.0[A] -> IRQ 7 [ 0.224014] PCI->APIC IRQ transform: 0000:00:09.0[A] -> IRQ 5 [ 0.224014] PCI->APIC IRQ transform: 0000:00:10.0[A] -> IRQ 11 [ 0.224014] PCI->APIC IRQ transform: 0000:00:12.0[A] -> IRQ 10 [ 0.224014] PCI->APIC IRQ transform: 0000:00:13.0[A] -> IRQ 15 [ 0.224014] PCI->APIC IRQ transform: 0000:00:14.0[A] -> IRQ 7 [ 0.224014] PCI->APIC IRQ transform: 0000:01:06.0[A] -> IRQ 11 [ 0.224014] PCI->APIC IRQ transform: 0000:02:00.0[A] -> IRQ 11 [ 0.224014] PCI->APIC IRQ transform: 0000:04:00.0[A] -> IRQ 10 [ 0.244015] pnp: the driver 'system' has been registered [ 0.244015] PCI: Bridge: 0000:00:08.0 [ 0.244015] IO window: c000-cfff [ 0.244015] MEM window: 0xfcf00000-0xfcffffff [ 0.244015] PREFETCH window: disabled. [ 0.244015] PCI: Bridge: 0000:00:0b.0 [ 0.244015] IO window: d000-dfff [ 0.244015] MEM window: 0xfd000000-0xfeafffff [ 0.244015] PREFETCH window: 0x00000000ce000000-0x00000000dfffffff [ 0.244015] PCI: Bridge: 0000:00:10.0 [ 0.244015] IO window: disabled. [ 0.244015] MEM window: disabled. [ 0.244015] PREFETCH window: disabled. [ 0.244015] PCI: Bridge: 0000:00:12.0 [ 0.244015] IO window: e000-efff [ 0.244015] MEM window: 0xfeb00000-0xfebfffff [ 0.244015] PREFETCH window: disabled. [ 0.244015] PCI: Bridge: 0000:00:13.0 [ 0.244015] IO window: disabled. [ 0.244015] MEM window: disabled. [ 0.244015] PREFETCH window: disabled. [ 0.244015] PCI: Bridge: 0000:00:14.0 [ 0.244015] IO window: disabled. [ 0.244015] MEM window: disabled. [ 0.244015] PREFETCH window: disabled. [ 0.244015] PCI: Setting latency timer of device 0000:00:08.0 to 64 [ 0.244015] PCI: Setting latency timer of device 0000:00:0b.0 to 64 [ 0.244015] PCI: Setting latency timer of device 0000:00:10.0 to 64 [ 0.244015] PCI: Setting latency timer of device 0000:00:12.0 to 64 [ 0.244015] PCI: Setting latency timer of device 0000:00:13.0 to 64 [ 0.244015] PCI: Setting latency timer of device 0000:00:14.0 to 64 [ 0.244015] NET: Registered protocol family 2 [ 0.283069] IP route cache hash table entries: 65536 (order: 7, 524288 bytes) [ 0.286892] TCP established hash table entries: 262144 (order: 10, 4194304 bytes) [ 0.287029] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes) [ 0.287029] TCP: Hash tables configured (established 262144 bind 65536) [ 0.287029] TCP reno registered [ 0.295568] NET: Registered protocol family 1 [ 0.298865] checking if image is initramfs... it is [ 0.673776] Freeing initrd memory: 6565k freed [ 0.678146] platform rtc_cmos: registered platform RTC device (no PNP device found) [ 0.678270] audit: initializing netlink socket (disabled) [ 0.678285] type=2000 audit(1284730040.672:1): initialized [ 0.678876] Total HugeTLB memory allocated, 0 [ 0.679242] VFS: Disk quotas dquot_6.5.1 [ 0.679270] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.679310] msgmni has been set to 3773 [ 0.679519] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.679527] io scheduler noop registered [ 0.679531] io scheduler anticipatory registered [ 0.679535] io scheduler deadline registered [ 0.679550] io scheduler cfq registered (default) [ 0.714178] pci 0000:00:07.0: Enabling HT MSI Mapping [ 0.714210] pci 0000:00:08.0: Enabling HT MSI Mapping [ 0.714242] pci 0000:00:09.0: Enabling HT MSI Mapping [ 0.714272] pci 0000:00:0b.0: Enabling HT MSI Mapping [ 0.715702] pci 0000:00:10.0: Enabling HT MSI Mapping [ 0.715771] pci 0000:00:12.0: Enabling HT MSI Mapping [ 0.715840] pci 0000:00:13.0: Enabling HT MSI Mapping [ 0.715909] pci 0000:00:14.0: Enabling HT MSI Mapping [ 0.715956] pci 0000:02:00.0: Boot video device [ 0.716355] PCI: Setting latency timer of device 0000:00:10.0 to 64 [ 0.716519] assign_interrupt_mode Found MSI capability [ 0.716637] Allocate Port Service[0000:00:10.0:pcie00] [ 0.717134] PCI: Setting latency timer of device 0000:00:12.0 to 64 [ 0.717295] assign_interrupt_mode Found MSI capability [ 0.717407] Allocate Port Service[0000:00:12.0:pcie00] [ 0.717899] PCI: Setting latency timer of device 0000:00:13.0 to 64 [ 0.718061] assign_interrupt_mode Found MSI capability [ 0.718117] Allocate Port Service[0000:00:13.0:pcie00] [ 0.718117] PCI: Setting latency timer of device 0000:00:14.0 to 64 [ 0.718117] assign_interrupt_mode Found MSI capability [ 0.718117] Allocate Port Service[0000:00:14.0:pcie00] [ 0.718117] vesafb: framebuffer at 0xcf000000, mapped to 0xffffc20000900000, using 3750k, total 14336k [ 0.718117] vesafb: mode is 1600x1200x8, linelength=1600, pages=1 [ 0.718117] vesafb: scrolling: redraw [ 0.718117] vesafb: Pseudocolor: size=8:8:8:8, shift=0:0:0:0 [ 0.727011] Console: switching to colour frame buffer device 200x75 [ 0.735874] fb0: VESA VGA frame buffer device [ 0.738117] Linux agpgart interface v0.103 [ 0.738117] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled [ 0.738117] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.738117] pnp: the driver 'serial' has been registered [ 0.742117] brd: module loaded [ 0.742117] input: Macintosh mouse button emulation as /class/input/input0 [ 0.742117] pnp: the driver 'i8042 kbd' has been registered [ 0.742117] pnp: the driver 'i8042 aux' has been registered [ 0.742117] pnp: the driver 'i8042 kbd' has been unregistered [ 0.742117] pnp: the driver 'i8042 aux' has been unregistered [ 0.742117] PNP: No PS/2 controller found. Probing ports directly. [ 0.992504] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.006117] mice: PS/2 mouse device common for all mice [ 1.006117] pnp: the driver 'rtc_cmos' has been registered [ 1.006117] rtc_cmos rtc_cmos: rtc core: registered rtc_cmos as rtc0 [ 1.006117] rtc0: alarms up to one day [ 1.023565] input: AT Translated Set 2 keyboard as /class/input/input1 [ 1.042581] cpuidle: using governor ladder [ 1.042610] cpuidle: using governor menu [ 1.042640] No iBFT detected. [ 1.042975] TCP cubic registered [ 1.042999] NET: Registered protocol family 17 [ 1.043268] registered taskstats version 1 [ 1.043268] rtc_cmos rtc_cmos: setting system clock to 2010-09-17 13:27:22 UTC (1284730042) [ 1.043268] Freeing unused kernel memory: 392k freed [ 1.188857] thermal: Unknown symbol acpi_processor_set_thermal_limit [ 1.347084] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.347123] PCI: Setting latency timer of device 0000:00:02.0 to 64 [ 1.347126] ohci_hcd 0000:00:02.0: OHCI Host Controller [ 1.347281] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1 [ 1.347352] ohci_hcd 0000:00:02.0: irq 7, io mem 0xfce7f000 [ 1.378045] SCSI subsystem initialized [ 1.384890] libata version 3.00 loaded. [ 1.404861] usb usb1: configuration #1 chosen from 1 choice [ 1.404933] hub 1-0:1.0: USB hub found [ 1.404967] hub 1-0:1.0: 6 ports detected [ 1.506804] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.506860] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.508303] usb usb1: Product: OHCI Host Controller [ 1.508338] usb usb1: Manufacturer: Linux 2.6.26-2-amd64 ohci_hcd [ 1.508380] usb usb1: SerialNumber: 0000:00:02.0 [ 1.508745] PCI: Setting latency timer of device 0000:00:04.0 to 64 [ 1.508748] ohci_hcd 0000:00:04.0: OHCI Host Controller [ 1.508825] ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2 [ 1.508894] ohci_hcd 0000:00:04.0: irq 10, io mem 0xfce7d000 [ 1.566273] usb usb2: configuration #1 chosen from 1 choice [ 1.566336] hub 2-0:1.0: USB hub found [ 1.566369] hub 2-0:1.0: 6 ports detected [ 1.668152] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.668200] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.668250] usb usb2: Product: OHCI Host Controller [ 1.668283] usb usb2: Manufacturer: Linux 2.6.26-2-amd64 ohci_hcd [ 1.668325] usb usb2: SerialNumber: 0000:00:04.0 [ 1.669113] PCI: Setting latency timer of device 0000:00:02.1 to 64 [ 1.669116] ehci_hcd 0000:00:02.1: EHCI Host Controller [ 1.670811] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 3 [ 1.672082] ehci_hcd 0000:00:02.1: debug port 1 [ 1.673767] PCI: cache line size of 64 is not supported by device 0000:00:02.1 [ 1.673777] ehci_hcd 0000:00:02.1: irq 11, io mem 0xfce7ec00 [ 1.684261] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004 [ 1.686048] usb usb3: configuration #1 chosen from 1 choice [ 1.687844] hub 3-0:1.0: USB hub found [ 1.689623] hub 3-0:1.0: 6 ports detected [ 1.792144] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.793984] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.795845] usb usb3: Product: EHCI Host Controller [ 1.797714] usb usb3: Manufacturer: Linux 2.6.26-2-amd64 ehci_hcd [ 1.799620] usb usb3: SerialNumber: 0000:00:02.1 [ 1.804082] PCI: Setting latency timer of device 0000:00:04.1 to 64 [ 1.804082] ehci_hcd 0000:00:04.1: EHCI Host Controller [ 1.804082] ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 4 [ 1.808082] ehci_hcd 0000:00:04.1: debug port 1 [ 1.808082] PCI: cache line size of 64 is not supported by device 0000:00:04.1 [ 1.808082] ehci_hcd 0000:00:04.1: irq 15, io mem 0xfce7e800 [ 1.976090] usb 2-3: new full speed USB device using ohci_hcd and address 2 [ 1.985296] ehci_hcd 0000:00:04.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004 [ 1.988082] usb usb4: configuration #1 chosen from 1 choice [ 1.992096] hub 4-0:1.0: USB hub found [ 1.994220] hub 4-0:1.0: 6 ports detected [ 2.045666] hub 2-0:1.0: unable to enumerate USB device on port 3 [ 2.101496] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.102611] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.105646] usb usb4: Product: EHCI Host Controller [ 2.107453] usb usb4: Manufacturer: Linux 2.6.26-2-amd64 ehci_hcd [ 2.111453] usb usb4: SerialNumber: 0000:00:04.1 [ 2.109654] ahci 0000:00:09.0: version 3.0 [ 2.418888] usb 4-3: new high speed USB device using ehci_hcd and address 2 [ 2.553936] usb 4-3: configuration #1 chosen from 1 choice [ 2.556495] usb 4-3: New USB device found, idVendor=05dc, idProduct=a731 [ 2.558691] usb 4-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2.558886] usb 4-3: Product: JD FireFly [ 2.562886] usb 4-3: Manufacturer: Lexar [ 2.565035] usb 4-3: SerialNumber: AA04015200003289 [ 3.114897] ahci 0000:00:09.0: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl IDE mode [ 3.117081] ahci 0000:00:09.0: flags: 64bit ncq sntf led clo pmp pio [ 3.119249] PCI: Setting latency timer of device 0000:00:09.0 to 64 [ 3.120177] scsi0 : ahci [ 3.122883] scsi1 : ahci [ 3.126338] scsi2 : ahci [ 3.126883] scsi3 : ahci [ 3.130883] scsi4 : ahci [ 3.130883] scsi5 : ahci [ 3.130909] ata1: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76100 irq 1275 [ 3.134883] ata2: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76180 irq 1275 [ 3.134885] ata3: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76200 irq 1275 [ 3.138884] ata4: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76280 irq 1275 [ 3.140917] ata5: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76300 irq 1275 [ 3.142885] ata6: SATA max UDMA/133 abar m8192@0xfce76000 port 0xfce76380 irq 1275 [ 3.626697] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 3.630147] ata1.00: ATA-8: MAXTOR STM3500320AS, MX15, max UDMA/133 [ 3.631980] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32) [ 3.635466] ata1.00: configured for UDMA/133 [ 3.954697] ata2: SATA link down (SStatus 0 SControl 300) [ 4.274697] ata3: SATA link down (SStatus 0 SControl 300) [ 4.594697] ata4: SATA link down (SStatus 0 SControl 300) [ 4.914697] ata5: SATA link down (SStatus 0 SControl 300) [ 5.234697] ata6: SATA link down (SStatus 0 SControl 300) [ 5.236807] scsi 0:0:0:0: Direct-Access ATA MAXTOR STM350032 MX15 PQ: 0 ANSI: 5 [ 5.240981] PCI: Setting latency timer of device 0000:04:00.0 to 64 [ 5.241016] sky2 0000:04:00.0: v1.21 addr 0xfebfc000 irq 10 Yukon-EC Ultra (0xb4) rev 3 [ 5.243017] sky2 eth0: addr 00:1f:c6:d7:71:4e [ 5.298297] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[11] MMIO=[fcfff800-fcffffff] Max Packet=[2048] IR/IT contexts=[4/8] [ 5.305467] Uniform Multi-Platform E-IDE driver [ 5.306691] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx [ 5.314691] NFORCE-MCP77: 0000:00:06.0 (rev a1) UDMA133 controller [ 5.316609] NFORCE-MCP77: IDE controller (0x10de:0x0759 rev 0xa1) at PCI slot 0000:00:06.0 [ 5.318526] NFORCE-MCP77: not 100% native mode: will probe irqs later [ 5.320424] NFORCE-MCP77: BIOS didn't set cable bits correctly. Enabling workaround. [ 5.322379] NFORCE-MCP77: IDE port disabled [ 5.324240] ide0: BM-DMA at 0xffa0-0xffa7 [ 5.326082] Probing IDE interface ide0... [ 5.354379] Initializing USB Mass Storage driver... [ 5.358379] scsi6 : SCSI emulation for USB Mass Storage devices [ 5.358379] usb-storage: device found at 2 [ 5.358379] usb-storage: waiting for device to settle before scanning [ 5.358379] usbcore: registered new interface driver usb-storage [ 5.358399] USB Mass Storage support registered. [ 5.376504] Driver 'sd' needs updating - please use bus_type methods [ 5.378464] sd 0:0:0:0: [sda] 976773168 512-byte hardware sectors (500108 MB) [ 5.380361] sd 0:0:0:0: [sda] Write Protect is off [ 5.382231] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 5.382250] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 5.384303] sd 0:0:0:0: [sda] 976773168 512-byte hardware sectors (500108 MB) [ 5.386227] sd 0:0:0:0: [sda] Write Protect is off [ 5.388116] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 5.388132] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 5.390051] sda: sda1 sda2 < sda5 sda6 sda7 sda8 sda9 > [ 5.462742] sd 0:0:0:0: [sda] Attached SCSI disk [ 6.066822] hda: HL-DT-STDVD-RAM GH22NP20, ATAPI CD/DVD-ROM drive [ 6.402753] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4 [ 6.405292] hda: UDMA/66 mode selected [ 6.407368] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14 [ 6.589101] ieee1394: Host added: ID:BUS[0-00:1023] GUID[001e8c0001434cf8] [ 10.361397] usb-storage: device scan complete [ 10.361397] isa bounce pool size: 16 pages [ 10.364850] scsi 6:0:0:0: Direct-Access Lexar JD FireFly 1100 PQ: 0 ANSI: 0 CCS [ 10.370049] sd 6:0:0:0: [sdb] 7831552 512-byte hardware sectors (4010 MB) [ 10.376930] sd 6:0:0:0: [sdb] Write Protect is off [ 10.378854] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00 [ 10.378856] sd 6:0:0:0: [sdb] Assuming drive cache: write through [ 10.392362] sd 6:0:0:0: [sdb] 7831552 512-byte hardware sectors (4010 MB) [ 10.396488] sd 6:0:0:0: [sdb] Write Protect is off [ 10.398406] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00 [ 10.398408] sd 6:0:0:0: [sdb] Assuming drive cache: write through [ 10.400323] sdb: sdb1 [ 10.405463] sd 6:0:0:0: [sdb] Attached SCSI removable disk [ 13.435135] ide-cd: cmd 0x5a timed out [ 13.437062] hda: lost interrupt [ 73.220637] SysRq : Emergency Sync [ 73.220637] Emergency Sync complete [ 73.435134] ide-cd: cmd 0x5a timed out [ 73.437029] hda: lost interrupt [ 73.438911] hda: ATAPI 48X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache [ 73.440796] Uniform CD-ROM driver Revision: 3.20 [ 91.671353] SysRq : Terminate All Tasks [ 102.077739] PM: Starting manual resume from disk [ 102.107239] kjournald starting. Commit interval 5 seconds [ 102.110752] EXT3-fs: mounted filesystem with ordered data mode. [ 102.911979] udevd version 125 started [ 103.487865] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 103.502185] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 [ 103.602458] input: PC Speaker as /class/input/input2 [ 103.782611] PCI: Setting latency timer of device 0000:00:07.0 to 64 [ 103.818305] hda_codec: Unknown model for ALC883, trying auto-probe from BIOS... [ 105.112796] Adding 5662872k swap on /dev/sda7. Priority:-1 extents:1 across:5662872k [ 105.296488] EXT3 FS on sda1, internal journal [ 106.163274] loop: module loaded [ 133.454958] hda: lost interrupt [ 193.454961] ide-cd: cmd 0x3 timed out [ 193.457116] hda: lost interrupt [ 202.941124] INFO: task modprobe:813 blocked for more than 120 seconds. [ 202.943285] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 202.946950] modprobe D 0000000000000000 0 813 1 [ 202.949124] ffff810075037898 0000000000000086 0000000000000000 ffffffffa00d0b00 [ 202.951310] ffff8100378938b0 ffff810077b7d470 ffff810037893b38 00000001379f9400 [ 202.953496] ffffffffa00d0b90 0000000000000000 00000000ffffffff 0000000000000000 [ 202.953547] Call Trace: [ 202.957846] [<ffffffffa0111534>] :ide_cd_mod:cdrom_do_newpc_cont+0x0/0x2b [ 202.960035] [<ffffffff804294a6>] schedule_timeout+0x1e/0xad [ 202.962232] [<ffffffffa00ba305>] :ide_core:ide_do_request+0x8e4/0x933 [ 202.964414] [<ffffffffa00b9a3d>] :ide_core:ide_do_request+0x1c/0x933 [ 202.966612] [<ffffffff80428abb>] wait_for_common+0xcf/0x13a [ 202.968762] [<ffffffff8022c168>] default_wake_function+0x0/0xe [ 202.972656] [<ffffffffa00ba436>] :ide_core:ide_do_drive_cmd+0xe2/0x109 [ 202.974787] [<ffffffffa010fd55>] :ide_cd_mod:ide_cd_queue_pc+0x42/0xca [ 202.976907] [<ffffffff80373458>] notify_update+0x2b/0x30 [ 202.979017] [<ffffffff8030d8b5>] blk_rq_init+0x1c/0x85 [ 202.984138] [<ffffffffa0110098>] :ide_cd_mod:cdrom_check_status+0x68/0x77 [ 202.984358] [<ffffffff803102de>] blk_end_sync_rq+0x0/0x2e [ 202.987762] [<ffffffffa0110117>] :ide_cd_mod:ide_cd_read_toc+0x70/0x3d6 [ 202.988358] [<ffffffffa00c15de>] :ide_core:__ide_add_setting+0xf2/0x119 [ 202.990443] [<ffffffffa0110a2c>] :ide_cd_mod:ide_cd_probe+0x5af/0x5e7 [ 202.992358] [<ffffffff802e3595>] sysfs_create_link+0xb6/0x105 [ 202.994437] [<ffffffff80385810>] driver_probe_device+0xd0/0x14d [ 202.996358] [<ffffffff803858d3>] __driver_attach+0x46/0x6d [ 202.999740] [<ffffffff8038588d>] __driver_attach+0x0/0x6d [ 203.000358] [<ffffffff80384fb3>] bus_for_each_dev+0x44/0x6f [ 203.002402] [<ffffffff803853e9>] bus_add_driver+0xb4/0x203 [ 203.004358] [<ffffffff80385b2f>] driver_register+0x8d/0x101 [ 203.006389] [<ffffffff802550cd>] sys_init_module+0x191b/0x1ab1 [ 203.008358] [<ffffffff8023d07f>] msleep+0x0/0x1e [ 203.011486] [<ffffffff8020beda>] system_call_after_swapgs+0x8a/0x8f [ 203.012358] [ 331.788618] INFO: task modprobe:813 blocked for more than 120 seconds. [ 331.792358] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 331.796351] modprobe D 0000000000000000 0 813 1 [ 331.798436] ffff810075037898 0000000000000086 0000000000000000 ffffffffa00d0b00 [ 331.800537] ffff8100378938b0 ffff810077b7d470 ffff810037893b38 00000001379f9400 [ 331.802647] ffffffffa00d0b90 0000000000000000 00000000ffffffff 0000000000000000 [ 331.802697] Call Trace: [ 331.806873] [<ffffffffa0111534>] :ide_cd_mod:cdrom_do_newpc_cont+0x0/0x2b [ 331.808998] [<ffffffff804294a6>] schedule_timeout+0x1e/0xad [ 331.811151] [<ffffffffa00ba305>] :ide_core:ide_do_request+0x8e4/0x933 [ 331.813296] [<ffffffffa00b9a3d>] :ide_core:ide_do_request+0x1c/0x933 [ 331.815421] [<ffffffff80428abb>] wait_for_common+0xcf/0x13a [ 331.817531] [<ffffffff8022c168>] default_wake_function+0x0/0xe [ 331.819650] [<ffffffffa00ba436>] :ide_core:ide_do_drive_cmd+0xe2/0x109 [ 331.821788] [<ffffffffa010fd55>] :ide_cd_mod:ide_cd_queue_pc+0x42/0xca [ 331.823906] [<ffffffff80373458>] notify_update+0x2b/0x30 [ 331.825991] [<ffffffff8030d8b5>] blk_rq_init+0x1c/0x85 [ 331.828075] [<ffffffffa0110098>] :ide_cd_mod:cdrom_check_status+0x68/0x77 [ 331.830167] [<ffffffff803102de>] blk_end_sync_rq+0x0/0x2e [ 331.832263] [<ffffffffa0110117>] :ide_cd_mod:ide_cd_read_toc+0x70/0x3d6 [ 331.834365] [<ffffffffa00c15de>] :ide_core:__ide_add_setting+0xf2/0x119 [ 331.836451] [<ffffffffa0110a2c>] :ide_cd_mod:ide_cd_probe+0x5af/0x5e7 [ 331.838522] [<ffffffff802e3595>] sysfs_create_link+0xb6/0x105 [ 331.840585] [<ffffffff80385810>] driver_probe_device+0xd0/0x14d [ 331.842646] [<ffffffff803858d3>] __driver_attach+0x46/0x6d [ 331.844699] [<ffffffff8038588d>] __driver_attach+0x0/0x6d [ 331.846738] [<ffffffff80384fb3>] bus_for_each_dev+0x44/0x6f [ 331.848752] [<ffffffff803853e9>] bus_add_driver+0xb4/0x203 [ 331.850741] [<ffffffff80385b2f>] driver_register+0x8d/0x101 [ 331.852724] [<ffffffff802550cd>] sys_init_module+0x191b/0x1ab1 [ 331.854684] [<ffffffff8023d07f>] msleep+0x0/0x1e [ 331.856601] [<ffffffff8020beda>] system_call_after_swapgs+0x8a/0x8f [ 331.858518] [ 346.304419] kjournald starting. Commit interval 5 seconds [ 346.307394] EXT3-fs warning: maximal mount count reached, running e2fsck is recommended [ 346.307803] EXT3 FS on sda9, internal journal [ 346.307807] EXT3-fs: mounted filesystem with ordered data mode. [ 346.332075] kjournald starting. Commit interval 5 seconds [ 346.334483] EXT3 FS on sda8, internal journal [ 346.334486] EXT3-fs: mounted filesystem with ordered data mode. [ 346.368075] kjournald starting. Commit interval 5 seconds [ 346.369549] EXT3 FS on sda5, internal journal [ 346.369552] EXT3-fs: mounted filesystem with ordered data mode. [ 346.411081] kjournald starting. Commit interval 5 seconds [ 346.411432] EXT3 FS on sda6, internal journal [ 346.411435] EXT3-fs: mounted filesystem with ordered data mode. [ 347.883891] sky2 eth0: enabling interface [ 349.475571] powernow_k8: Unknown symbol acpi_processor_notify_smm [ 349.475571] powernow_k8: Unknown symbol acpi_processor_unregister_performance [ 349.475662] powernow_k8: Unknown symbol acpi_processor_register_performance [ 349.517616] acpi_cpufreq: Unknown symbol acpi_processor_notify_smm [ 349.517649] acpi_cpufreq: Unknown symbol acpi_processor_unregister_performance [ 349.517773] acpi_cpufreq: Unknown symbol acpi_processor_preregister_performance [ 349.517821] acpi_cpufreq: Unknown symbol acpi_processor_register_performance [ 349.614360] sky2 eth0: Link is up at 100 Mbps, full duplex, flow control both [ 352.030092] pnp: the driver 'parport_pc' has been registered [ 352.052953] lp: driver loaded but no devices found [ 352.180918] ppdev: user-space parallel port driver [ 353.192958] NET: Registered protocol family 10 [ 353.195336] lo: Disabled Privacy Extensions [ 356.747236] nvidia: module license 'NVIDIA' taints kernel. [ 357.003585] PCI: Setting latency timer of device 0000:02:00.0 to 64 [ 357.003754] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 173.14.09 Wed Jun 4 23:40:50 PDT 2008 [ 357.005369] NVRM: failed to register with the ACPI subsystem! [ 363.743736] eth0: no IPv6 routers present [ 373.419915] warning: `ntpd' uses 32-bit capabilities (legacy support in use)
A noter ces messages qui sont apparus plusieurs fois juste après le “loop: module loaded” qui bloque :hda: lost interrupt
:017
J’ai eu ce genre de problèmes pendant des semaines, et puis lors d’une mise à jour, c’est parti ! passe en SID :wink:
[quote=“debianhadic”]passe en SID[/quote]Non, non, non… il y a forcement une autre solution que celle-ci (un peu radicale) tu ne crois pas ??? :104
en ce moment c est pas vraiment le truc a faire s’il veux passer en stable plus tard…
pis bon je trouve que c est un réflexe de windowsien qui a la flemme de chercher (on est samdei :laughing: )
Eric75 tu as essaye avec un autre kernel ?
J’ai eu un (gros) problème similaire il y a quelques jours. En fait, le démarrage se déroulait bien, comme j’ai pu le voir via les logs par la suite, mais l’affichage bloquait de la même façon sur un truc spécifique.
Et pareil à toi, je n’ai rien trouvé sur le web qui parle de ce problème.
Après quelques essais, j’ai fini par m’apercevoir que ça ne le faisait qu’avec un noyau de la branche 2.6.3x… Sans savoir pourquoi. Sachant que j’étais depuis plusieurs semaines avec un 2.6.32 en trunk, et que le problème est survenu après une mise à jour foireuse du module Nvidia et de Xorg…
Depuis, j’ai récupéré le 2.6.29 sur le dépôt boisson de notre camarade (avec le 2.6.26, Starcraft II buggait), et je n’ai plus aucun problème. :slight_smile:
Donc effectivement, tenter avec un autre noyau me semble une bonne idée…
Merci à tous pour vos réponses à ce post laissé quelque peu à la traine car beaucoup de taff dernièrement !
En fait, mon pb est résolu ! :mrgreen:
Comment ?
Bonne question : rien fait de particulier si ce n’est un aptitude update/aptitude safe-upgrade non effectué depuis une dizaine de jours ! :119
Donc sûrement un bug dans une appli mise à jour récemment…
D’ailleurs à ce propos, aptitude doit sûrement faire un fichier de log des softs installés/mis à jour ?
Où peut-on voir ça et de quelle façon le visualiser svp ?
[quote=“Eric75”]
Où peut-on voir ça et de quelle façon le visualiser svp ?[/quote]
Fichier à consulter avec ton éditeur de texte préféré ou avec la commande cat : /var/log/aptitude.
Merci martin_mtl pour l’info !
A priori, lors du dernier aptitude safe-upgrade, j’ai du changer de kernel sans m’en rendre compte : :blush: [MIS A JOUR] linux-headers-2.6.26-2-amd64 2.6.26-24lenny1 -> 2.6.26-25lenny1 [MIS A JOUR] linux-headers-2.6.26-2-common 2.6.26-24lenny1 -> 2.6.26-25lenny1 [MIS A JOUR] linux-image-2.6.26-2-amd64 2.6.26-24lenny1 -> 2.6.26-25lenny1
Par contre, je viens de m’appercevoir qu’un uname -a ne rend pas forcement des infos très explicites :$ uname -a Linux PC02 2.6.26-2-amd64 #1 SMP Thu Sep 16 15:56:38 UTC 2010 x86_64 GNU/Linux2.6.26-2 alors qu’à priori je suis en 2.6.26-25 : avec ça, faut le deviner que j’ai changé de noyau !!!
Ou alors j’ai loupé kekchose…
On me corrigera si je suis dans l'erreur. Tu as bien le noyau 2.6.26.2. Tu as simplement eu une cinquième mise à jour de sécurité, d'où le -25lenny1. Pour te convaincre, tu peux regarder les infos concernant le noyau [url=http://packages.debian.org/lenny/linux-image-2.6.26-2-amd64]linux-image-2.6.26-2-amd64[/url].
Un [code]apt-cache policy linux-image-2.6.26-2-amd64[/code] ou un [code]aptitude show linux-image-2.6.26-2-amd64[/code] seront aussi plus parlant.
On me corrigera si je suis dans l’erreur. Tu as bien le noyau 2.6.26.2. Tu as simplement eu une cinquième mise à jour de sécurité, d’où le -25lenny1. Pour te convaincre, tu peux regarder les infos concernant le noyau linux-image-2.6.26-2-amd64.
Un apt-cache policy linux-image-2.6.26-2-amd64 ou un aptitude show linux-image-2.6.26-2-amd64 seront aussi plus parlant.
Effectivement :$ apt-cache policy linux-image-2.6.26-2-amd64 linux-image-2.6.26-2-amd64: Installé : 2.6.26-25lenny1 Candidat : 2.6.26-25lenny1 Table de version : *** 2.6.26-25lenny1 0 990 http://security.debian.org stable/updates/main Packages 100 /var/lib/dpkg/status 2.6.26-25 0 990 http://ftp.fr.debian.org stable/main Packagesou$ aptitude show linux-image-2.6.26-2-amd64 Paquet : linux-image-2.6.26-2-amd64 État: installé Automatiquement installé: oui Version : 2.6.26-25lenny1 Priorité : optionnel Section : admin Responsable : Debian Kernel Team <debian-kernel@lists.debian.org> Taille décompressée : 83,0M Dépend: module-init-tools, initramfs-tools (>= 0.55) | yaird (>= 0.0.13) | linux-initramfs-tool Pré-dépend: debconf | debconf-2.0 Suggère: linux-doc-2.6.26, grub | lilo Est en conflit: initramfs-tools (< 0.55), yaird (< 0.0.13) Fournit: linux-image, linux-image-2.6, linux-modules-2.6.26-2-amd64 Description : Linux 2.6.26 image on AMD64 This package provides the binary image and pre-built loadable modules for Linux kernel 2.6.26 on all 64bit single- and multiprocessor AMD and Intel machines.c’est quand même plus clair !
Par contre, j’ai cherché un peu sur le Net comment Debian numérotait exactement ses versions de kernel mais j’ai pas trouvé d’infos précises… (sur les màj de sécurité notamment)
