J’ai installé la version 1 on dirait de ath3k, j’avais trouvé une documentation sur internet, mais aurais tu un site répertoriant les drivers les plus récents pour ce type de carte s’il te plait ?
Pour ce qui est du ifconfig -a, l’adresse a l’air aléatoire à chaque redémarrage.
Bluez doit être la dernière version car j’ai fait un apt-get install bluez.
Un cat /var/log/messages me donne ça quand le BT ne fonctionne pas :
Aug 19 10:21:29 medetic kernel: imklog 4.6.4, log source = /proc/kmsg started.
Aug 19 10:21:29 medetic rsyslogd: [origin software="rsyslogd" swVersion="4.6.4" x-pid="1172" x-info="http://www.rsyslog.com"] (re)start
Aug 19 10:21:29 medetic kernel: [ 0.000000] Initializing cgroup subsys cpuset
Aug 19 10:21:29 medetic kernel: [ 0.000000] Linux version 2.6.32-5-686 (Debian 2.6.32-35) (dannf@debian.org) (gcc version 4.3.5 (Debian 4.3.5-4) ) #1 SMP Mon Jun 13 04:13:06 UTC 2011
Aug 19 10:21:29 medetic kernel: [ 0.000000] KERNEL supported cpus:
Aug 19 10:21:29 medetic kernel: [ 0.000000] Intel GenuineIntel
Aug 19 10:21:29 medetic kernel: [ 0.000000] AMD AuthenticAMD
Aug 19 10:21:29 medetic kernel: [ 0.000000] NSC Geode by NSC
Aug 19 10:21:29 medetic kernel: [ 0.000000] Cyrix CyrixInstead
Aug 19 10:21:29 medetic kernel: [ 0.000000] Centaur CentaurHauls
Aug 19 10:21:29 medetic kernel: [ 0.000000] Transmeta GenuineTMx86
Aug 19 10:21:29 medetic kernel: [ 0.000000] Transmeta TransmetaCPU
Aug 19 10:21:29 medetic kernel: [ 0.000000] UMC UMC UMC UMC
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-provided physical RAM map:
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009ec00 (usable)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000000009ec00 - 00000000000a0000 (reserved)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 0000000000100000 - 000000007f2f6000 (usable)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f2f6000 - 000000007f2f8000 (reserved)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f2f8000 - 000000007f2ff000 (ACPI NVS)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f2ff000 - 000000007f3f1000 (usable)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f3f1000 - 000000007f437000 (ACPI NVS)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f437000 - 000000007f440000 (ACPI data)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f440000 - 000000007f443000 (ACPI NVS)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f443000 - 000000007f46a000 (reserved)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f46a000 - 000000007f46b000 (usable)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f46b000 - 000000007f475000 (ACPI NVS)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f475000 - 000000007f49f000 (reserved)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f49f000 - 000000007f600000 (usable)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 000000007f600000 - 0000000080000000 (reserved)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed01000 (reserved)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed90000 (reserved)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Aug 19 10:21:29 medetic kernel: [ 0.000000] BIOS-e820: 00000000ffe00000 - 0000000100000000 (reserved)
Aug 19 10:21:29 medetic kernel: [ 0.000000] DMI 2.6 present.
Aug 19 10:21:29 medetic kernel: [ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it.
Aug 19 10:21:29 medetic kernel: [ 0.000000] last_pfn = 0x7f600 max_arch_pfn = 0x100000
Aug 19 10:21:29 medetic kernel: [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
Aug 19 10:21:29 medetic kernel: [ 0.000000] init_memory_mapping: 0000000000000000-00000000373fe000
Aug 19 10:21:29 medetic kernel: [ 0.000000] RAMDISK: 377b3000 - 37fef60c
Aug 19 10:21:29 medetic kernel: [ 0.000000] Allocated new RAMDISK: 00100000 - 0093c60c
Aug 19 10:21:29 medetic kernel: [ 0.000000] Move RAMDISK from 00000000377b3000 - 0000000037fef60b to 00100000 - 0093c60b
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: RSDP 000f0420 00024 (v03 AMI )
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: XSDT 7f437080 00054 (v01 AMI APTIO 01072009 AMI 00010013)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: FACP 7f43fa50 000F4 (v04 AMI APTIO 01072009 AMI 00010013)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI Warning: 32/64 FACS address mismatch in FADT - two FACS tables! (20090903/tbfadt-369)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI Warning: 32/64X FACS address mismatch in FADT - 7F471F40/000000007F471F80, using 32 (20090903/tbfadt-486)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0000000000000820/0 (20090903/tbfadt-557)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI Warning: Invalid length for Pm2ControlBlock: 0, using default 8 (20090903/tbfadt-607)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: DSDT 7f437168 088E1 (v02 AMI APTIO 00000000 INTL 20051117)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: FACS 7f471f40 00040
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: APIC 7f43fb48 00072 (v01 AMI APTIO 01072009 AMI 00010013)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: MCFG 7f43fbc0 0003C (v01 AMI APTIO 01072009 MSFT 00000097)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: SLIC 7f43fc00 00176 (v01 AMI APTIO 01072009 AMI 00010013)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: HPET 7f43fd78 00038 (v01 AMI APTIO 01072009 AMI. 00000004)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: ECDT 7f43fdb0 000C1 (v01 AMI APTIO 01072009 AMI. 00000004)
Aug 19 10:21:29 medetic kernel: [ 0.000000] 1154MB HIGHMEM available.
Aug 19 10:21:29 medetic kernel: [ 0.000000] 883MB LOWMEM available.
Aug 19 10:21:29 medetic kernel: [ 0.000000] mapped low ram: 0 - 373fe000
Aug 19 10:21:29 medetic kernel: [ 0.000000] low ram: 0 - 373fe000
Aug 19 10:21:29 medetic kernel: [ 0.000000] node 0 low ram: 00000000 - 373fe000
Aug 19 10:21:29 medetic kernel: [ 0.000000] node 0 bootmap 00012000 - 00018e80
Aug 19 10:21:29 medetic kernel: [ 0.000000] found SMP MP-table at [c00fcc30] fcc30
Aug 19 10:21:29 medetic kernel: [ 0.000000] Zone PFN ranges:
Aug 19 10:21:29 medetic kernel: [ 0.000000] DMA 0x00000010 -> 0x00001000
Aug 19 10:21:29 medetic kernel: [ 0.000000] Normal 0x00001000 -> 0x000373fe
Aug 19 10:21:29 medetic kernel: [ 0.000000] HighMem 0x000373fe -> 0x0007f600
Aug 19 10:21:29 medetic kernel: [ 0.000000] Movable zone start PFN for each node
Aug 19 10:21:29 medetic kernel: [ 0.000000] early_node_map[5] active PFN ranges
Aug 19 10:21:29 medetic kernel: [ 0.000000] 0: 0x00000010 -> 0x0000009e
Aug 19 10:21:29 medetic kernel: [ 0.000000] 0: 0x00000100 -> 0x0007f2f6
Aug 19 10:21:29 medetic kernel: [ 0.000000] 0: 0x0007f2ff -> 0x0007f3f1
Aug 19 10:21:29 medetic kernel: [ 0.000000] 0: 0x0007f46a -> 0x0007f46b
Aug 19 10:21:29 medetic kernel: [ 0.000000] 0: 0x0007f49f -> 0x0007f600
Aug 19 10:21:29 medetic kernel: [ 0.000000] Using APIC driver default
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: PM-Timer IO Port: 0x808
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x04] disabled)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
Aug 19 10:21:29 medetic kernel: [ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Aug 19 10:21:29 medetic kernel: [ 0.000000] Using ACPI (MADT) for SMP configuration information
Aug 19 10:21:29 medetic kernel: [ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
Aug 19 10:21:29 medetic kernel: [ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
Aug 19 10:21:29 medetic kernel: [ 0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000
Aug 19 10:21:29 medetic kernel: [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
Aug 19 10:21:29 medetic kernel: [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
Aug 19 10:21:29 medetic kernel: [ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
Aug 19 10:21:29 medetic kernel: [ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:7ec00000)
Aug 19 10:21:29 medetic kernel: [ 0.000000] Booting paravirtualized kernel on bare hardware
Aug 19 10:21:29 medetic kernel: [ 0.000000] NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:4 nr_node_ids:1
Aug 19 10:21:29 medetic kernel: [ 0.000000] PERCPU: Embedded 14 pages/cpu @c2800000 s34328 r0 d23016 u1048576
Aug 19 10:21:29 medetic kernel: [ 0.000000] pcpu-alloc: s34328 r0 d23016 u1048576 alloc=1*4194304
Aug 19 10:21:29 medetic kernel: [ 0.000000] pcpu-alloc: [0] 0 1 2 3
Aug 19 10:21:29 medetic kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 517355
Aug 19 10:21:29 medetic kernel: [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-686 root=UUID=4026a8a5-381c-4768-88e9-464cf3e5abe3 ro quiet
Aug 19 10:21:29 medetic kernel: [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
Aug 19 10:21:29 medetic kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Aug 19 10:21:29 medetic kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Aug 19 10:21:29 medetic kernel: [ 0.000000] Enabling fast FPU save and restore... done.
Aug 19 10:21:29 medetic kernel: [ 0.000000] Enabling unmasked SIMD FPU exception support... done.
Aug 19 10:21:29 medetic kernel: [ 0.000000] Initializing CPU#0
Aug 19 10:21:29 medetic kernel: [ 0.000000] Initializing HighMem for node 0 (000373fe:0007f600)
Aug 19 10:21:29 medetic kernel: [ 0.000000] Memory: 2053872k/2086912k available (2504k kernel code, 30772k reserved, 1313k data, 380k init, 1180976k highmem)
Aug 19 10:21:29 medetic kernel: [ 0.000000] virtual kernel memory layout:
Aug 19 10:21:29 medetic kernel: [ 0.000000] fixmap : 0xffd56000 - 0xfffff000 (2724 kB)
Aug 19 10:21:29 medetic kernel: [ 0.000000] pkmap : 0xff400000 - 0xff800000 (4096 kB)
Aug 19 10:21:29 medetic kernel: [ 0.000000] vmalloc : 0xf7bfe000 - 0xff3fe000 ( 120 MB)
Aug 19 10:21:29 medetic kernel: [ 0.000000] lowmem : 0xc0000000 - 0xf73fe000 ( 883 MB)
Aug 19 10:21:29 medetic kernel: [ 0.000000] .init : 0xc13bb000 - 0xc141a000 ( 380 kB)
Aug 19 10:21:29 medetic kernel: [ 0.000000] .data : 0xc1272001 - 0xc13ba4c0 (1313 kB)
Aug 19 10:21:29 medetic kernel: [ 0.000000] .text : 0xc1000000 - 0xc1272001 (2504 kB)
Aug 19 10:21:29 medetic kernel: [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
Aug 19 10:21:29 medetic kernel: [ 0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Aug 19 10:21:29 medetic kernel: [ 0.000000] Hierarchical RCU implementation.
Aug 19 10:21:29 medetic kernel: [ 0.000000] NR_IRQS:1280
Aug 19 10:21:29 medetic kernel: [ 0.000000] Extended CMOS year: 2000
Aug 19 10:21:29 medetic kernel: [ 0.000000] Console: colour VGA+ 80x25
Aug 19 10:21:29 medetic kernel: [ 0.000000] console [tty0] enabled
Aug 19 10:21:29 medetic kernel: [ 0.000000] Fast TSC calibration using PIT
Aug 19 10:21:29 medetic kernel: [ 0.000000] Detected 1679.151 MHz processor.
Aug 19 10:21:29 medetic kernel: [ 0.004008] Calibrating delay loop (skipped), value calculated using timer frequency.. 3358.30 BogoMIPS (lpj=6716604)
Aug 19 10:21:29 medetic kernel: [ 0.004039] Security Framework initialized
Aug 19 10:21:29 medetic kernel: [ 0.004047] SELinux: Disabled at boot.
Aug 19 10:21:29 medetic kernel: [ 0.004062] Mount-cache hash table entries: 512
Aug 19 10:21:29 medetic kernel: [ 0.004260] Initializing cgroup subsys ns
Aug 19 10:21:29 medetic kernel: [ 0.004268] Initializing cgroup subsys cpuacct
Aug 19 10:21:29 medetic kernel: [ 0.004277] Initializing cgroup subsys devices
Aug 19 10:21:29 medetic kernel: [ 0.004282] Initializing cgroup subsys freezer
Aug 19 10:21:29 medetic kernel: [ 0.004287] Initializing cgroup subsys net_cls
Aug 19 10:21:29 medetic kernel: [ 0.004322] CPU: L1 I cache: 32K, L1 D cache: 24K
Aug 19 10:21:29 medetic kernel: [ 0.004327] CPU: L2 cache: 512K
Aug 19 10:21:29 medetic kernel: [ 0.004332] CPU: Physical Processor ID: 0
Aug 19 10:21:29 medetic kernel: [ 0.004336] CPU: Processor Core ID: 0
Aug 19 10:21:29 medetic kernel: [ 0.004342] mce: CPU supports 5 MCE banks
Aug 19 10:21:29 medetic kernel: [ 0.004355] CPU0: Thermal monitoring enabled (TM2)
Aug 19 10:21:29 medetic kernel: [ 0.004362] using mwait in idle threads.
Aug 19 10:21:29 medetic kernel: [ 0.004372] Performance Events: Atom events, Intel PMU driver.
Aug 19 10:21:29 medetic kernel: [ 0.004384] ... version: 3
Aug 19 10:21:29 medetic kernel: [ 0.004387] ... bit width: 40
Aug 19 10:21:29 medetic kernel: [ 0.004391] ... generic registers: 2
Aug 19 10:21:29 medetic kernel: [ 0.004395] ... value mask: 000000ffffffffff
Aug 19 10:21:29 medetic kernel: [ 0.004399] ... max period: 000000007fffffff
Aug 19 10:21:29 medetic kernel: [ 0.004403] ... fixed-purpose events: 3
Aug 19 10:21:29 medetic kernel: [ 0.004407] ... event mask: 0000000700000003
Aug 19 10:21:29 medetic kernel: [ 0.004415] Checking 'hlt' instruction... OK.
Aug 19 10:21:29 medetic kernel: [ 0.021585] ACPI: Core revision 20090903
Aug 19 10:21:29 medetic kernel: [ 0.036103] Enabling APIC mode: Flat. Using 1 I/O APICs
Aug 19 10:21:29 medetic kernel: [ 0.036431] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
Aug 19 10:21:29 medetic kernel: [ 0.077205] CPU0: Intel(R) Atom(TM) CPU N450 @ 1.66GHz stepping 0a
Aug 19 10:21:29 medetic kernel: [ 0.080001] Booting processor 1 APIC 0x1 ip 0x6000
Aug 19 10:21:29 medetic kernel: [ 0.008000] Initializing CPU#1
Aug 19 10:21:29 medetic kernel: [ 0.008000] CPU: L1 I cache: 32K, L1 D cache: 24K
Aug 19 10:21:29 medetic kernel: [ 0.008000] CPU: L2 cache: 512K
Aug 19 10:21:29 medetic kernel: [ 0.008000] CPU: Physical Processor ID: 0
Aug 19 10:21:29 medetic kernel: [ 0.008000] CPU: Processor Core ID: 0
Aug 19 10:21:29 medetic kernel: [ 0.008000] CPU1: Thermal monitoring enabled (TM2)
Aug 19 10:21:29 medetic kernel: [ 0.164104] CPU1: Intel(R) Atom(TM) CPU N450 @ 1.66GHz stepping 0a
Aug 19 10:21:29 medetic kernel: [ 0.164119] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
Aug 19 10:21:29 medetic kernel: [ 0.168075] Brought up 2 CPUs
Aug 19 10:21:29 medetic kernel: [ 0.168082] Total of 2 processors activated (6716.72 BogoMIPS).
Aug 19 10:21:29 medetic kernel: [ 0.168662] devtmpfs: initialized
Aug 19 10:21:29 medetic kernel: [ 0.168662] regulator: core version 0.5
Aug 19 10:21:29 medetic kernel: [ 0.168662] NET: Registered protocol family 16
Aug 19 10:21:29 medetic kernel: [ 0.168662] ACPI: bus type pci registered
Aug 19 10:21:29 medetic kernel: [ 0.168662] PCI: MCFG configuration 0: base f0000000 segment 0 buses 0 - 63
Aug 19 10:21:29 medetic kernel: [ 0.168662] PCI: Not using MMCONFIG.
Aug 19 10:21:29 medetic kernel: [ 0.187415] PCI: Using configuration type 1 for base access
Aug 19 10:21:29 medetic kernel: [ 0.188053] bio: create slab <bio-0> at 0
Aug 19 10:21:29 medetic kernel: [ 0.189507] ACPI: EC: EC description table is found, configuring boot EC
Aug 19 10:21:29 medetic kernel: [ 0.192712] ACPI: Executed 1 blocks of module-level executable AML code
Aug 19 10:21:29 medetic kernel: [ 0.203833] ACPI: Interpreter enabled
Aug 19 10:21:29 medetic kernel: [ 0.203840] ACPI: (supports S0 S1 S3 S4 S5)
Aug 19 10:21:29 medetic kernel: [ 0.203888] ACPI: Using IOAPIC for interrupt routing
Aug 19 10:21:29 medetic kernel: [ 0.203986] PCI: MCFG configuration 0: base f0000000 segment 0 buses 0 - 63
Aug 19 10:21:29 medetic kernel: [ 0.204152] PCI: MCFG area at f0000000 reserved in ACPI motherboard resources
Aug 19 10:21:29 medetic kernel: [ 0.204157] PCI: Using MMCONFIG for extended config space
Aug 19 10:21:29 medetic kernel: [ 0.208072] ACPI: BIOS _OSI(Linux) query ignored
Aug 19 10:21:29 medetic kernel: [ 0.222712] ACPI: EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62
Aug 19 10:21:29 medetic kernel: [ 0.223218] ACPI: No dock devices found.
Aug 19 10:21:29 medetic kernel: [ 0.223699] ACPI: PCI Root Bridge [PCI0] (0000:00)
Aug 19 10:21:29 medetic kernel: [ 0.224175] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
Aug 19 10:21:29 medetic kernel: [ 0.224184] pci 0000:00:1a.7: PME# disabled
Aug 19 10:21:29 medetic kernel: [ 0.224278] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
Aug 19 10:21:29 medetic kernel: [ 0.224285] pci 0000:00:1b.0: PME# disabled
Aug 19 10:21:29 medetic kernel: [ 0.224355] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Aug 19 10:21:29 medetic kernel: [ 0.224361] pci 0000:00:1c.0: PME# disabled
Aug 19 10:21:29 medetic kernel: [ 0.224433] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
Aug 19 10:21:29 medetic kernel: [ 0.224439] pci 0000:00:1c.2: PME# disabled
Aug 19 10:21:29 medetic kernel: [ 0.224719] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
Aug 19 10:21:29 medetic kernel: [ 0.224726] pci 0000:00:1d.7: PME# disabled
Aug 19 10:21:29 medetic kernel: [ 0.224861] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0068 (mask 0007)
Aug 19 10:21:29 medetic kernel: [ 0.225073] pci 0000:00:1f.2: PME# supported from D3hot
Aug 19 10:21:29 medetic kernel: [ 0.225080] pci 0000:00:1f.2: PME# disabled
Aug 19 10:21:29 medetic kernel: [ 0.225280] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
Aug 19 10:21:29 medetic kernel: [ 0.225288] pci 0000:01:00.0: PME# disabled
Aug 19 10:21:29 medetic kernel: [ 0.240158] pci 0000:00:1e.0: transparent bridge
Aug 19 10:21:29 medetic kernel: [ 0.288602] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Aug 19 10:21:29 medetic kernel: [ 0.288831] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Aug 19 10:21:29 medetic kernel: [ 0.289057] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Aug 19 10:21:29 medetic kernel: [ 0.289287] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
Aug 19 10:21:29 medetic kernel: [ 0.289511] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 *7 10 11 12 14 15)
Aug 19 10:21:29 medetic kernel: [ 0.289735] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Aug 19 10:21:29 medetic kernel: [ 0.289960] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15)
Aug 19 10:21:29 medetic kernel: [ 0.290184] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 *4 5 6 7 10 11 12 14 15)
Aug 19 10:21:29 medetic kernel: [ 0.290397] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
Aug 19 10:21:29 medetic kernel: [ 0.290418] vgaarb: loaded
Aug 19 10:21:29 medetic kernel: [ 0.290456] PCI: Using ACPI for IRQ routing
Aug 19 10:21:29 medetic kernel: [ 0.290456] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
Aug 19 10:21:29 medetic kernel: [ 0.290456] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
Aug 19 10:21:29 medetic kernel: [ 0.290456] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
Aug 19 10:21:29 medetic kernel: [ 0.296027] Switching to clocksource tsc
Aug 19 10:21:29 medetic kernel: [ 0.298096] pnp: PnP ACPI init
Aug 19 10:21:29 medetic kernel: [ 0.298127] ACPI: bus type pnp registered
Aug 19 10:21:29 medetic kernel: [ 0.302241] pnp: PnP ACPI: found 10 devices
Aug 19 10:21:29 medetic kernel: [ 0.302247] ACPI: ACPI bus type pnp unregistered
Aug 19 10:21:29 medetic kernel: [ 0.302255] PnPBIOS: Disabled by ACPI PNP
Aug 19 10:21:29 medetic kernel: [ 0.302280] system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved
Aug 19 10:21:29 medetic kernel: [ 0.302287] system 00:01: iomem range 0xf0000000-0xf3ffffff has been reserved
Aug 19 10:21:29 medetic kernel: [ 0.302301] system 00:02: ioport range 0x800-0x87f has been reserved
Aug 19 10:21:29 medetic kernel: [ 0.302308] system 00:02: ioport range 0x480-0x4bf has been reserved
Aug 19 10:21:29 medetic kernel: [ 0.302315] system 00:02: iomem range 0xfec00000-0xfec00fff could not be reserved
Aug 19 10:21:29 medetic kernel: [ 0.302323] system 00:02: iomem range 0xfee00000-0xfee00fff has been reserved
Aug 19 10:21:29 medetic kernel: [ 0.302330] system 00:02: iomem range 0xfed1c000-0xfed1ffff has been reserved
Aug 19 10:21:29 medetic kernel: [ 0.302337] system 00:02: iomem range 0xfed20000-0xfed8ffff has been reserved
Aug 19 10:21:29 medetic kernel: [ 0.302344] system 00:02: iomem range 0xffe00000-0xffffffff has been reserved
Aug 19 10:21:29 medetic kernel: [ 0.302365] system 00:06: ioport range 0x4d0-0x4d1 has been reserved
Aug 19 10:21:29 medetic kernel: [ 0.302373] system 00:06: iomem range 0xffa00000-0xffbfffff has been reserved
Aug 19 10:21:29 medetic kernel: [ 0.337377] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:01
Aug 19 10:21:29 medetic kernel: [ 0.337385] pci 0000:00:1c.0: IO window: 0x1000-0x1fff
Aug 19 10:21:29 medetic kernel: [ 0.337393] pci 0000:00:1c.0: MEM window: 0xfe200000-0xfe2fffff
Aug 19 10:21:29 medetic kernel: [ 0.337401] pci 0000:00:1c.0: PREFETCH window: 0x00000080000000-0x000000801fffff
Aug 19 10:21:29 medetic kernel: [ 0.337411] pci 0000:00:1c.2: PCI bridge, secondary bus 0000:02
Aug 19 10:21:29 medetic kernel: [ 0.337417] pci 0000:00:1c.2: IO window: 0x2000-0x2fff
Aug 19 10:21:29 medetic kernel: [ 0.337425] pci 0000:00:1c.2: MEM window: 0xfd800000-0xfe0fffff
Aug 19 10:21:29 medetic kernel: [ 0.337432] pci 0000:00:1c.2: PREFETCH window: 0x00000080200000-0x000000803fffff
Aug 19 10:21:29 medetic kernel: [ 0.337442] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:03
Aug 19 10:21:29 medetic kernel: [ 0.337446] pci 0000:00:1e.0: IO window: disabled
Aug 19 10:21:29 medetic kernel: [ 0.337453] pci 0000:00:1e.0: MEM window: disabled
Aug 19 10:21:29 medetic kernel: [ 0.337459] pci 0000:00:1e.0: PREFETCH window: disabled
Aug 19 10:21:29 medetic kernel: [ 0.337487] pci 0000:00:1c.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
Aug 19 10:21:29 medetic kernel: [ 0.337510] pci 0000:00:1c.2: PCI INT C -> GSI 20 (level, low) -> IRQ 20
Aug 19 10:21:29 medetic kernel: [ 0.337653] NET: Registered protocol family 2
Aug 19 10:21:29 medetic kernel: [ 0.337833] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Aug 19 10:21:29 medetic kernel: [ 0.338417] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
Aug 19 10:21:29 medetic kernel: [ 0.339326] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
Aug 19 10:21:29 medetic kernel: [ 0.339785] TCP: Hash tables configured (established 131072 bind 65536)
Aug 19 10:21:29 medetic kernel: [ 0.339791] TCP reno registered
Aug 19 10:21:29 medetic kernel: [ 0.339988] NET: Registered protocol family 1
Aug 19 10:21:29 medetic kernel: [ 0.895811] Unpacking initramfs...
Aug 19 10:21:29 medetic kernel: [ 1.284022] Freeing initrd memory: 8433k freed
Aug 19 10:21:29 medetic kernel: [ 1.290799] audit: initializing netlink socket (disabled)
Aug 19 10:21:29 medetic kernel: [ 1.290823] type=2000 audit(1313749282.287:1): initialized
Aug 19 10:21:29 medetic kernel: [ 1.296479] highmem bounce pool size: 64 pages
Aug 19 10:21:29 medetic kernel: [ 1.296490] HugeTLB registered 4 MB page size, pre-allocated 0 pages
Aug 19 10:21:29 medetic kernel: [ 1.299524] VFS: Disk quotas dquot_6.5.2
Aug 19 10:21:29 medetic kernel: [ 1.299638] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 19 10:21:29 medetic kernel: [ 1.299815] msgmni has been set to 1723
Aug 19 10:21:29 medetic kernel: [ 1.300219] alg: No test for stdrng (krng)
Aug 19 10:21:29 medetic kernel: [ 1.300332] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
Aug 19 10:21:29 medetic kernel: [ 1.300339] io scheduler noop registered
Aug 19 10:21:29 medetic kernel: [ 1.300344] io scheduler anticipatory registered
Aug 19 10:21:29 medetic kernel: [ 1.300348] io scheduler deadline registered
Aug 19 10:21:29 medetic kernel: [ 1.300436] io scheduler cfq registered (default)
Aug 19 10:21:29 medetic kernel: [ 1.301122] isapnp: Scanning for PnP cards...
Aug 19 10:21:29 medetic kernel: [ 1.654108] isapnp: No Plug & Play device found
Aug 19 10:21:29 medetic kernel: [ 1.657330] Linux agpgart interface v0.103
Aug 19 10:21:29 medetic kernel: [ 1.657472] agpgart-intel 0000:00:00.0: Intel IGD Chipset
Aug 19 10:21:29 medetic kernel: [ 1.657757] agpgart-intel 0000:00:00.0: detected 8188K stolen memory
Aug 19 10:21:29 medetic kernel: [ 1.670532] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
Aug 19 10:21:29 medetic kernel: [ 1.670680] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Aug 19 10:21:29 medetic kernel: [ 1.671327] PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
Aug 19 10:21:29 medetic kernel: [ 1.671332] PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Aug 19 10:21:29 medetic kernel: [ 1.673923] serio: i8042 KBD port at 0x60,0x64 irq 1
Aug 19 10:21:29 medetic kernel: [ 1.674062] mice: PS/2 mouse device common for all mice
Aug 19 10:21:29 medetic kernel: [ 1.674127] rtc_cmos 00:04: RTC can wake from S4
Aug 19 10:21:29 medetic kernel: [ 1.674201] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
Aug 19 10:21:29 medetic kernel: [ 1.674234] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
Aug 19 10:21:29 medetic kernel: [ 1.674257] cpuidle: using governor ladder
Aug 19 10:21:29 medetic kernel: [ 1.674262] cpuidle: using governor menu
Aug 19 10:21:29 medetic kernel: [ 1.674271] No iBFT detected.
Aug 19 10:21:29 medetic kernel: [ 1.675090] TCP cubic registered
Aug 19 10:21:29 medetic kernel: [ 1.675436] NET: Registered protocol family 10
Aug 19 10:21:29 medetic kernel: [ 1.676086] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
Aug 19 10:21:29 medetic kernel: [ 1.677097] Mobile IPv6
Aug 19 10:21:29 medetic kernel: [ 1.677104] NET: Registered protocol family 17
Aug 19 10:21:29 medetic kernel: [ 1.677133] Using IPI No-Shortcut mode
Aug 19 10:21:29 medetic kernel: [ 1.677330] registered taskstats version 1
Aug 19 10:21:29 medetic kernel: [ 1.677809] rtc_cmos 00:04: setting system clock to 2011-08-19 10:21:23 UTC (1313749283)
Aug 19 10:21:29 medetic kernel: [ 1.677942] Initalizing network drop monitor service
Aug 19 10:21:29 medetic kernel: [ 1.677991] Freeing unused kernel memory: 380k freed
Aug 19 10:21:29 medetic kernel: [ 1.678265] Write protecting the kernel text: 2508k
Aug 19 10:21:29 medetic kernel: [ 1.678303] Write protecting the kernel read-only data: 904k
Aug 19 10:21:29 medetic kernel: [ 1.710493] udev[56]: starting version 164
Aug 19 10:21:29 medetic kernel: [ 2.079711] usbcore: registered new interface driver usbfs
Aug 19 10:21:29 medetic kernel: [ 2.079769] usbcore: registered new interface driver hub
Aug 19 10:21:29 medetic kernel: [ 2.080940] usbcore: registered new device driver usb
Aug 19 10:21:29 medetic kernel: [ 2.094649] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 19 10:21:29 medetic kernel: [ 2.094718] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18
Aug 19 10:21:29 medetic kernel: [ 2.094766] ehci_hcd 0000:00:1a.7: EHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.094888] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
Aug 19 10:21:29 medetic kernel: [ 2.094965] ehci_hcd 0000:00:1a.7: debug port 1
Aug 19 10:21:29 medetic kernel: [ 2.098917] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xfe406000
Aug 19 10:21:29 medetic kernel: [ 2.112530] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
Aug 19 10:21:29 medetic kernel: [ 2.112589] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Aug 19 10:21:29 medetic kernel: [ 2.112598] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 19 10:21:29 medetic kernel: [ 2.112607] usb usb1: Product: EHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.112613] usb usb1: Manufacturer: Linux 2.6.32-5-686 ehci_hcd
Aug 19 10:21:29 medetic kernel: [ 2.112620] usb usb1: SerialNumber: 0000:00:1a.7
Aug 19 10:21:29 medetic kernel: [ 2.113012] usb usb1: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 2.113214] hub 1-0:1.0: USB hub found
Aug 19 10:21:29 medetic kernel: [ 2.113238] hub 1-0:1.0: 4 ports detected
Aug 19 10:21:29 medetic kernel: [ 2.113390] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
Aug 19 10:21:29 medetic kernel: [ 2.113436] ehci_hcd 0000:00:1d.7: EHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.113461] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
Aug 19 10:21:29 medetic kernel: [ 2.113523] ehci_hcd 0000:00:1d.7: debug port 1
Aug 19 10:21:29 medetic kernel: [ 2.117465] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfe405000
Aug 19 10:21:29 medetic kernel: [ 2.132524] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
Aug 19 10:21:29 medetic kernel: [ 2.132588] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Aug 19 10:21:29 medetic kernel: [ 2.132597] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 19 10:21:29 medetic kernel: [ 2.132605] usb usb2: Product: EHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.132612] usb usb2: Manufacturer: Linux 2.6.32-5-686 ehci_hcd
Aug 19 10:21:29 medetic kernel: [ 2.132619] usb usb2: SerialNumber: 0000:00:1d.7
Aug 19 10:21:29 medetic kernel: [ 2.132975] usb usb2: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 2.133171] hub 2-0:1.0: USB hub found
Aug 19 10:21:29 medetic kernel: [ 2.133195] hub 2-0:1.0: 6 ports detected
Aug 19 10:21:29 medetic kernel: [ 2.144663] SCSI subsystem initialized
Aug 19 10:21:29 medetic kernel: [ 2.212863] uhci_hcd: USB Universal Host Controller Interface driver
Aug 19 10:21:29 medetic kernel: [ 2.212966] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Aug 19 10:21:29 medetic kernel: [ 2.212992] uhci_hcd 0000:00:1a.0: UHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.213025] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
Aug 19 10:21:29 medetic kernel: [ 2.213082] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000f0a0
Aug 19 10:21:29 medetic kernel: [ 2.213182] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
Aug 19 10:21:29 medetic kernel: [ 2.213191] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 19 10:21:29 medetic kernel: [ 2.213199] usb usb3: Product: UHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.213205] usb usb3: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
Aug 19 10:21:29 medetic kernel: [ 2.213212] usb usb3: SerialNumber: 0000:00:1a.0
Aug 19 10:21:29 medetic kernel: [ 2.213563] usb usb3: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 2.213769] hub 3-0:1.0: USB hub found
Aug 19 10:21:29 medetic kernel: [ 2.213793] hub 3-0:1.0: 2 ports detected
Aug 19 10:21:29 medetic kernel: [ 2.213932] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
Aug 19 10:21:29 medetic kernel: [ 2.213957] uhci_hcd 0000:00:1a.1: UHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.213981] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
Aug 19 10:21:29 medetic kernel: [ 2.214034] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000f080
Aug 19 10:21:29 medetic kernel: [ 2.214128] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
Aug 19 10:21:29 medetic kernel: [ 2.214137] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 19 10:21:29 medetic kernel: [ 2.214144] usb usb4: Product: UHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.214151] usb usb4: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
Aug 19 10:21:29 medetic kernel: [ 2.214158] usb usb4: SerialNumber: 0000:00:1a.1
Aug 19 10:21:29 medetic kernel: [ 2.214483] usb usb4: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 2.214681] hub 4-0:1.0: USB hub found
Aug 19 10:21:29 medetic kernel: [ 2.214703] hub 4-0:1.0: 2 ports detected
Aug 19 10:21:29 medetic kernel: [ 2.214832] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
Aug 19 10:21:29 medetic kernel: [ 2.214858] uhci_hcd 0000:00:1d.0: UHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.214882] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
Aug 19 10:21:29 medetic kernel: [ 2.214920] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000f060
Aug 19 10:21:29 medetic kernel: [ 2.215012] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
Aug 19 10:21:29 medetic kernel: [ 2.215020] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 19 10:21:29 medetic kernel: [ 2.215028] usb usb5: Product: UHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.215035] usb usb5: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
Aug 19 10:21:29 medetic kernel: [ 2.215042] usb usb5: SerialNumber: 0000:00:1d.0
Aug 19 10:21:29 medetic kernel: [ 2.215367] usb usb5: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 2.215561] hub 5-0:1.0: USB hub found
Aug 19 10:21:29 medetic kernel: [ 2.215584] hub 5-0:1.0: 2 ports detected
Aug 19 10:21:29 medetic kernel: [ 2.215718] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
Aug 19 10:21:29 medetic kernel: [ 2.215742] uhci_hcd 0000:00:1d.1: UHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.215766] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
Aug 19 10:21:29 medetic kernel: [ 2.215818] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000f040
Aug 19 10:21:29 medetic kernel: [ 2.215919] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
Aug 19 10:21:29 medetic kernel: [ 2.215927] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 19 10:21:29 medetic kernel: [ 2.215935] usb usb6: Product: UHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.215942] usb usb6: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
Aug 19 10:21:29 medetic kernel: [ 2.215949] usb usb6: SerialNumber: 0000:00:1d.1
Aug 19 10:21:29 medetic kernel: [ 2.216313] usb usb6: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 2.216525] hub 6-0:1.0: USB hub found
Aug 19 10:21:29 medetic kernel: [ 2.216549] hub 6-0:1.0: 2 ports detected
Aug 19 10:21:29 medetic kernel: [ 2.216684] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
Aug 19 10:21:29 medetic kernel: [ 2.216710] uhci_hcd 0000:00:1d.2: UHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.216734] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
Aug 19 10:21:29 medetic kernel: [ 2.216774] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000f020
Aug 19 10:21:29 medetic kernel: [ 2.216867] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
Aug 19 10:21:29 medetic kernel: [ 2.216876] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 19 10:21:29 medetic kernel: [ 2.216884] usb usb7: Product: UHCI Host Controller
Aug 19 10:21:29 medetic kernel: [ 2.216890] usb usb7: Manufacturer: Linux 2.6.32-5-686 uhci_hcd
Aug 19 10:21:29 medetic kernel: [ 2.216897] usb usb7: SerialNumber: 0000:00:1d.2
Aug 19 10:21:29 medetic kernel: [ 2.217239] usb usb7: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 2.217441] hub 7-0:1.0: USB hub found
Aug 19 10:21:29 medetic kernel: [ 2.217464] hub 7-0:1.0: 2 ports detected
Aug 19 10:21:29 medetic kernel: [ 2.228268] ata_piix 0000:00:1f.1: PCI INT A -> GSI 19 (level, low) -> IRQ 19
Aug 19 10:21:29 medetic kernel: [ 2.233396] scsi0 : ata_piix
Aug 19 10:21:29 medetic kernel: [ 2.233881] scsi1 : ata_piix
Aug 19 10:21:29 medetic kernel: [ 2.237722] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xf120 irq 14
Aug 19 10:21:29 medetic kernel: [ 2.237732] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xf128 irq 15
Aug 19 10:21:29 medetic kernel: [ 2.237861] ata_piix 0000:00:1f.2: PCI INT B -> GSI 18 (level, low) -> IRQ 18
Aug 19 10:21:29 medetic kernel: [ 2.237874] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
Aug 19 10:21:29 medetic kernel: [ 2.392661] scsi2 : ata_piix
Aug 19 10:21:29 medetic kernel: [ 2.392987] scsi3 : ata_piix
Aug 19 10:21:29 medetic kernel: [ 2.396582] ata3: SATA max UDMA/133 cmd 0xf110 ctl 0xf100 bmdma 0xf0d0 irq 18
Aug 19 10:21:29 medetic kernel: [ 2.396593] ata4: SATA max UDMA/133 cmd 0xf0f0 ctl 0xf0e0 bmdma 0xf0d8 irq 18
Aug 19 10:21:29 medetic kernel: [ 2.768023] usb 2-6: new high speed USB device using ehci_hcd and address 5
Aug 19 10:21:29 medetic kernel: [ 3.134039] usb 2-6: New USB device found, idVendor=04f2, idProduct=b213
Aug 19 10:21:29 medetic kernel: [ 3.134046] usb 2-6: New USB device strings: Mfr=2, Product=1, SerialNumber=3
Aug 19 10:21:29 medetic kernel: [ 3.134052] usb 2-6: Product: USB 2.0 Camera
Aug 19 10:21:29 medetic kernel: [ 3.134057] usb 2-6: Manufacturer: Chicony Electronics Co., Ltd.
Aug 19 10:21:29 medetic kernel: [ 3.134061] usb 2-6: SerialNumber: SN0001
Aug 19 10:21:29 medetic kernel: [ 3.134225] usb 2-6: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 3.196575] ata3.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Aug 19 10:21:29 medetic kernel: [ 3.196591] ata3.01: SATA link down (SStatus 0 SControl 300)
Aug 19 10:21:29 medetic kernel: [ 3.205002] ata3.00: ATA-8: SanDisk SSD P4 32GB, SSD 8.10, max UDMA/133
Aug 19 10:21:29 medetic kernel: [ 3.205009] ata3.00: 62533296 sectors, multi 1: LBA48
Aug 19 10:21:29 medetic kernel: [ 3.212357] ata3.00: configured for UDMA/133
Aug 19 10:21:29 medetic kernel: [ 3.212564] scsi 2:0:0:0: Direct-Access ATA SanDisk SSD P4 3 SSD PQ: 0 ANSI: 5
Aug 19 10:21:29 medetic kernel: [ 3.376026] usb 3-1: new full speed USB device using uhci_hcd and address 2
Aug 19 10:21:29 medetic kernel: [ 3.534177] usb 3-1: New USB device found, idVendor=0eef, idProduct=72a1
Aug 19 10:21:29 medetic kernel: [ 3.534185] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 19 10:21:29 medetic kernel: [ 3.534191] usb 3-1: Product: USB TouchController
Aug 19 10:21:29 medetic kernel: [ 3.534195] usb 3-1: Manufacturer: eGalax Inc.
Aug 19 10:21:29 medetic kernel: [ 3.534361] usb 3-1: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 3.759191] ata4.00: SATA link down (SStatus 0 SControl 300)
Aug 19 10:21:29 medetic kernel: [ 3.759208] ata4.01: SATA link down (SStatus 0 SControl 0)
Aug 19 10:21:29 medetic kernel: [ 3.776926] usbcore: registered new interface driver hiddev
Aug 19 10:21:29 medetic kernel: [ 3.780569] usb 5-1: new low speed USB device using uhci_hcd and address 2
Aug 19 10:21:29 medetic kernel: [ 3.782934] input: eGalax Inc. USB TouchController as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1:1.0/input/input1
Aug 19 10:21:29 medetic kernel: [ 3.783940] generic-usb 0003:0EEF:72A1.0001: input,hiddev0,hidraw0: USB HID v2.10 Pointer [eGalax Inc. USB TouchController] on usb-0000:00:1a.0-1/input0
Aug 19 10:21:29 medetic kernel: [ 3.784013] usbcore: registered new interface driver usbhid
Aug 19 10:21:29 medetic kernel: [ 3.784408] usbhid: v2.6:USB HID core driver
Aug 19 10:21:29 medetic kernel: [ 3.790297] sd 2:0:0:0: [sda] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
Aug 19 10:21:29 medetic kernel: [ 3.790500] sd 2:0:0:0: [sda] Write Protect is off
Aug 19 10:21:29 medetic kernel: [ 3.790594] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 19 10:21:29 medetic kernel: [ 3.791076] sda: sda1 sda2 sda3 < sda5 sda6 >
Aug 19 10:21:29 medetic kernel: [ 3.794523] sd 2:0:0:0: [sda] Attached SCSI disk
Aug 19 10:21:29 medetic kernel: [ 3.930490] PM: Starting manual resume from disk
Aug 19 10:21:29 medetic kernel: [ 3.956025] usb 5-1: New USB device found, idVendor=046d, idProduct=c019
Aug 19 10:21:29 medetic kernel: [ 3.956036] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 19 10:21:29 medetic kernel: [ 3.956045] usb 5-1: Product: USB Optical Mouse
Aug 19 10:21:29 medetic kernel: [ 3.956051] usb 5-1: Manufacturer: Logitech
Aug 19 10:21:29 medetic kernel: [ 3.956272] usb 5-1: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 3.972507] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb5/5-1/5-1:1.0/input/input2
Aug 19 10:21:29 medetic kernel: [ 3.972712] generic-usb 0003:046D:C019.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.0-1/input0
Aug 19 10:21:29 medetic kernel: [ 3.974857] kjournald starting. Commit interval 5 seconds
Aug 19 10:21:29 medetic kernel: [ 3.974896] EXT3-fs: mounted filesystem with ordered data mode.
Aug 19 10:21:29 medetic kernel: [ 4.212067] usb 5-2: new low speed USB device using uhci_hcd and address 3
Aug 19 10:21:29 medetic kernel: [ 4.329870] udev[382]: starting version 164
Aug 19 10:21:29 medetic kernel: [ 4.385050] usb 5-2: New USB device found, idVendor=0b38, idProduct=0003
Aug 19 10:21:29 medetic kernel: [ 4.385060] usb 5-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 19 10:21:29 medetic kernel: [ 4.385069] usb 5-2: Product: USB-compliant keyboard
Aug 19 10:21:29 medetic kernel: [ 4.385276] usb 5-2: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 4.403828] input: USB-compliant keyboard as /devices/pci0000:00/0000:00:1d.0/usb5/5-2/5-2:1.0/input/input3
Aug 19 10:21:29 medetic kernel: [ 4.403963] generic-usb 0003:0B38:0003.0003: input,hidraw2: USB HID v1.10 Keyboard [USB-compliant keyboard] on usb-0000:00:1d.0-2/input0
Aug 19 10:21:29 medetic kernel: [ 4.432557] input: USB-compliant keyboard as /devices/pci0000:00/0000:00:1d.0/usb5/5-2/5-2:1.1/input/input4
Aug 19 10:21:29 medetic kernel: [ 4.432857] generic-usb 0003:0B38:0003.0004: input,hiddev1,hidraw3: USB HID v1.10 Mouse [USB-compliant keyboard] on usb-0000:00:1d.0-2/input1
Aug 19 10:21:29 medetic kernel: [ 4.672066] usb 6-1: new full speed USB device using uhci_hcd and address 2
Aug 19 10:21:29 medetic kernel: [ 4.736333] ACPI: SSDT 7f46cc18 00374 (v01 AMI IST 00000001 MSFT 03000001)
Aug 19 10:21:29 medetic kernel: [ 4.744327] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
Aug 19 10:21:29 medetic kernel: [ 4.744343] ACPI: Power Button [PWRB]
Aug 19 10:21:29 medetic kernel: [ 4.825401] usb 6-1: New USB device found, idVendor=13d3, idProduct=3304
Aug 19 10:21:29 medetic kernel: [ 4.825412] usb 6-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 19 10:21:29 medetic kernel: [ 4.825626] usb 6-1: configuration #1 chosen from 1 choice
Aug 19 10:21:29 medetic kernel: [ 4.909394] ACPI: AC Adapter [AC0] (off-line)
Aug 19 10:21:29 medetic kernel: [ 4.920087] Marking TSC unstable due to TSC halts in idle
Aug 19 10:21:29 medetic kernel: [ 4.920339] processor LNXCPU:00: registered as cooling_device0
Aug 19 10:21:29 medetic kernel: [ 4.920564] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
Aug 19 10:21:29 medetic kernel: [ 4.920677] ACPI: Power Button [PWRF]
Aug 19 10:21:29 medetic kernel: [ 4.932992] Switching to clocksource hpet
Aug 19 10:21:29 medetic kernel: [ 4.957234] processor LNXCPU:01: registered as cooling_device1
Aug 19 10:21:29 medetic kernel: [ 4.957572] input: PC Speaker as /devices/platform/pcspkr/input/input7
Aug 19 10:21:29 medetic kernel: [ 4.987643] asus_laptop: Asus Laptop Support version 0.42
Aug 19 10:21:29 medetic kernel: [ 4.995653] ACPI: Battery Slot [BAT0] (battery present)
Aug 19 10:21:29 medetic kernel: [ 5.032331] asus_laptop: Lucid model detected
Aug 19 10:21:29 medetic kernel: [ 5.033121] input: Asus Laptop extra buttons as /devices/virtual/input/input8
Aug 19 10:21:29 medetic kernel: [ 5.033431] Registered led device: asus::mail
Aug 19 10:21:29 medetic kernel: [ 5.033481] Registered led device: asus::touchpad
Aug 19 10:21:29 medetic kernel: [ 5.033534] Registered led device: asus::record
Aug 19 10:21:29 medetic kernel: [ 5.033582] Registered led device: asus::phone
Aug 19 10:21:29 medetic kernel: [ 5.050465] asus_laptop: Brightness ignored, must be controlled by ACPI video driver
Aug 19 10:21:29 medetic kernel: [ 5.115035] i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
Aug 19 10:21:29 medetic kernel: [ 5.157842] Linux video capture interface: v2.00
Aug 19 10:21:29 medetic kernel: [ 5.171201] cfg80211: Using static regulatory domain info
Aug 19 10:21:29 medetic kernel: [ 5.171209] cfg80211: Regulatory domain: US
Aug 19 10:21:29 medetic kernel: [ 5.171329] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Aug 19 10:21:29 medetic kernel: [ 5.171339] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
Aug 19 10:21:29 medetic kernel: [ 5.171348] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
Aug 19 10:21:29 medetic kernel: [ 5.171357] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
Aug 19 10:21:29 medetic kernel: [ 5.171366] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
Aug 19 10:21:29 medetic kernel: [ 5.171375] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
Aug 19 10:21:29 medetic kernel: [ 5.171383] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
Aug 19 10:21:29 medetic kernel: [ 5.172177] cfg80211: Calling CRDA for country: US
Aug 19 10:21:29 medetic kernel: [ 5.201406] Bluetooth: Core ver 2.15
Aug 19 10:21:29 medetic kernel: [ 5.201547] NET: Registered protocol family 31
Aug 19 10:21:29 medetic kernel: [ 5.201553] Bluetooth: HCI device and connection manager initialized
Aug 19 10:21:29 medetic kernel: [ 5.201561] Bluetooth: HCI socket layer initialized
Aug 19 10:21:29 medetic kernel: [ 5.305868] [drm] Initialized drm 1.1.0 20060810
Aug 19 10:21:29 medetic kernel: [ 5.315047] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (04f2:b213)
Aug 19 10:21:29 medetic kernel: [ 5.325677] input: USB 2.0 Camera as /devices/pci0000:00/0000:00:1d.7/usb2/2-6/2-6:1.0/input/input9
Aug 19 10:21:29 medetic kernel: [ 5.325852] usbcore: registered new interface driver uvcvideo
Aug 19 10:21:29 medetic kernel: [ 5.325861] USB Video Class driver (v0.1.0)
Aug 19 10:21:29 medetic kernel: [ 5.332538] Bluetooth: Generic Bluetooth USB driver ver 0.6
Aug 19 10:21:29 medetic kernel: [ 5.332832] usbcore: registered new interface driver btusb
Aug 19 10:21:29 medetic kernel: [ 5.418261] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Aug 19 10:21:29 medetic kernel: [ 5.437743] [drm] set up 7M of stolen space
Aug 19 10:21:29 medetic kernel: [ 5.513832] ath9k 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Aug 19 10:21:29 medetic kernel: [ 5.541624] [drm] initialized overlay support
Aug 19 10:21:29 medetic kernel: [ 5.679394] Registered led device: ath9k-phy0::radio
Aug 19 10:21:29 medetic kernel: [ 5.679435] Registered led device: ath9k-phy0::assoc
Aug 19 10:21:29 medetic kernel: [ 5.679481] Registered led device: ath9k-phy0::tx
Aug 19 10:21:29 medetic kernel: [ 5.679521] Registered led device: ath9k-phy0::rx
Aug 19 10:21:29 medetic kernel: [ 5.679545] phy0: Atheros AR9285 MAC/BB Rev:2 AR5133 RF Rev:e0: mem=0xf8880000, irq=16
Aug 19 10:21:29 medetic kernel: [ 6.012105] [drm] Big FIFO is enabled
Aug 19 10:21:29 medetic kernel: [ 6.012124] [drm] Big FIFO is enabled
Aug 19 10:21:29 medetic kernel: [ 6.201994] Console: switching to colour frame buffer device 170x48
Aug 19 10:21:29 medetic kernel: [ 6.214918] fb0: inteldrmfb frame buffer device
Aug 19 10:21:29 medetic kernel: [ 6.214923] registered panic notifier
Aug 19 10:21:29 medetic kernel: [ 6.226128] acpi device:40: registered as cooling_device2
Aug 19 10:21:29 medetic kernel: [ 6.227781] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10
Aug 19 10:21:29 medetic kernel: [ 6.227915] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
Aug 19 10:21:29 medetic kernel: [ 6.227971] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
Aug 19 10:21:29 medetic kernel: [ 6.228060] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
Aug 19 10:21:29 medetic kernel: [ 6.317487] hda_codec: ALC269: BIOS auto-probing.
Aug 19 10:21:29 medetic kernel: [ 6.317712] hda_codec: connection list not available for 0x24
Aug 19 10:21:29 medetic kernel: [ 6.317940] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input11
Aug 19 10:21:29 medetic kernel: [ 6.557123] Adding 363512k swap on /dev/sda6. Priority:-1 extents:1 across:363512k SS
Aug 19 10:21:29 medetic kernel: [ 6.618073] EXT3 FS on sda5, internal journal
Aug 19 10:21:29 medetic kernel: [ 6.678102] ------------[ cut here ]------------
Aug 19 10:21:29 medetic kernel: [ 6.678121] WARNING: at /tmp/buildd/linux-2.6-2.6.32/debian/build/source_i386_none/fs/fs-writeback.c:1122 __mark_inode_dirty+0xbe/0x10b()
Aug 19 10:21:29 medetic kernel: [ 6.678131] Hardware name: M11JB
Aug 19 10:21:29 medetic kernel: [ 6.678136] Modules linked in: loop(+) snd_hda_codec_realtek arc4 ecb snd_hda_intel snd_hda_codec snd_hwdep snd_pcm ath9k snd_seq snd_timer mac80211 i915 snd_seq_device drm_kms_helper ath btusb uvcvideo drm snd bluetooth cfg80211 i2c_i801 i2c_algo_bit videodev rfkill v4l1_compat soundcore asus_laptop pcspkr video i2c_core joydev ac battery led_class snd_page_alloc evdev output button processor ext3 jbd mbcache sd_mod crc_t10dif usbhid hid ata_generic thermal ata_piix uhci_hcd libata scsi_mod ehci_hcd thermal_sys usbcore nls_base [last unloaded: scsi_wait_scan]
Aug 19 10:21:29 medetic kernel: [ 6.678264] Pid: 851, comm: udisks-part-id Not tainted 2.6.32-5-686 #1
Aug 19 10:21:29 medetic kernel: [ 6.678270] Call Trace:
Aug 19 10:21:29 medetic kernel: [ 6.678286] [<c1030725>] ? warn_slowpath_common+0x5e/0x8a
Aug 19 10:21:29 medetic kernel: [ 6.678297] [<c103075b>] ? warn_slowpath_null+0xa/0xc
Aug 19 10:21:29 medetic kernel: [ 6.678307] [<c10c93ba>] ? __mark_inode_dirty+0xbe/0x10b
Aug 19 10:21:29 medetic kernel: [ 6.678318] [<c10c1cff>] ? touch_atime+0xbe/0xd9
Aug 19 10:21:29 medetic kernel: [ 6.678331] [<c1088ec4>] ? generic_file_aio_read+0x500/0x57b
Aug 19 10:21:29 medetic kernel: [ 6.678344] [<c101f5e9>] ? kunmap_atomic+0x51/0x6d
Aug 19 10:21:29 medetic kernel: [ 6.678356] [<c10b3255>] ? do_sync_read+0xc0/0x107
Aug 19 10:21:29 medetic kernel: [ 6.678369] [<c104403a>] ? autoremove_wake_function+0x0/0x2d
Aug 19 10:21:29 medetic kernel: [ 6.678382] [<c126dcde>] ? mutex_lock+0xb/0x24
Aug 19 10:21:29 medetic kernel: [ 6.678393] [<c11027e0>] ? security_file_permission+0xc/0xd
Aug 19 10:21:29 medetic kernel: [ 6.678404] [<c10b3195>] ? do_sync_read+0x0/0x107
Aug 19 10:21:29 medetic kernel: [ 6.678415] [<c10b3bea>] ? vfs_read+0x7b/0xd3
Aug 19 10:21:29 medetic kernel: [ 6.678425] [<c10b3cda>] ? sys_read+0x3c/0x63
Aug 19 10:21:29 medetic kernel: [ 6.678436] [<c10030fb>] ? sysenter_do_call+0x12/0x28
Aug 19 10:21:29 medetic kernel: [ 6.678445] ---[ end trace e3141b1c5762a0cf ]---
Aug 19 10:21:29 medetic kernel: [ 6.695221] loop: module loaded
Aug 19 10:21:29 medetic kernel: [ 6.723765] Bluetooth: Atheros AR30xx firmware driver ver 1.0
Aug 19 10:21:29 medetic kernel: [ 6.723834] usbcore: registered new interface driver ath3k
Aug 19 10:21:29 medetic kernel: [ 7.117554] fuse init (API version 7.13)
Aug 19 10:21:30 medetic kernel: [ 8.445456] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input12
Aug 19 10:21:30 medetic kernel: [ 8.790148] apm: BIOS not found.
Aug 19 10:21:30 medetic kernel: [ 8.900712] Bluetooth: L2CAP ver 2.14
Aug 19 10:21:30 medetic kernel: [ 8.900720] Bluetooth: L2CAP socket layer initialized
Aug 19 10:21:30 medetic kernel: [ 8.972567] Bluetooth: RFCOMM TTY layer initialized
Aug 19 10:21:30 medetic kernel: [ 8.972579] Bluetooth: RFCOMM socket layer initialized
Aug 19 10:21:30 medetic kernel: [ 8.972585] Bluetooth: RFCOMM ver 1.11
Aug 19 10:21:30 medetic kernel: [ 9.175425] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Aug 19 10:21:30 medetic kernel: [ 9.175434] Bluetooth: BNEP filters: protocol multicast
Aug 19 10:21:31 medetic kernel: [ 9.181098] lp: driver loaded but no devices found
Aug 19 10:21:31 medetic kernel: [ 9.192217] ppdev: user-space parallel port driver
Aug 19 10:21:31 medetic kernel: [ 9.322775] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Aug 19 10:21:31 medetic kernel: [ 9.453265] Bridge firewalling registered
Aug 19 10:21:31 medetic kernel: [ 9.719987] Bluetooth: SCO (Voice Link) ver 0.6
Aug 19 10:21:31 medetic kernel: [ 9.719995] Bluetooth: SCO socket layer initialized
Aug 19 10:21:33 medetic kernel: [ 11.938791] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Aug 19 10:21:33 medetic kernel: [ 11.948229] cfg80211: Calling CRDA for country: FR
Aug 19 10:21:34 medetic kernel: [ 12.623557] usbcore: deregistering interface driver btusb
Aug 19 10:21:34 medetic kernel: [ 12.634043] usbcore: deregistering interface driver ath3k
Aug 19 10:21:34 medetic kernel: [ 12.641885] Bluetooth: Atheros AR30xx firmware driver ver 1.0
Aug 19 10:21:34 medetic kernel: [ 12.641957] usbcore: registered new interface driver ath3k
Aug 19 10:21:34 medetic kernel: [ 12.642321] usb 6-1: firmware: requesting ath3k-1.fw
Aug 19 10:21:34 medetic kernel: [ 12.659028] ath3k: probe of 6-1:1.0 failed with error -5
Aug 19 10:21:34 medetic kernel: [ 12.680213] Bluetooth: Generic Bluetooth USB driver ver 0.6
Aug 19 10:21:34 medetic kernel: [ 12.681467] usbcore: registered new interface driver btusb
Aug 19 10:21:40 medetic kerneloops: Submitted 0 kernel oopses to www.kerneloops.org
Aug 19 10:22:54 medetic kernel: [ 92.598116] process `linux-x86-skype' is using obsolete setsockopt SO_BSDCOMPAT
Aug 19 10:24:35 medetic kernel: [ 193.372100] CE: hpet increasing min_delta_ns to 15000 nsec
Aug 19 10:24:57 medetic kernel: [ 216.160178] usb 5-2: USB disconnect, address 3
Aug 19 10:24:59 medetic kernel: [ 217.392594] usb 5-2: new low speed USB device using uhci_hcd and address 4
Aug 19 10:24:59 medetic kernel: [ 217.565526] usb 5-2: New USB device found, idVendor=0b38, idProduct=0003
Aug 19 10:24:59 medetic kernel: [ 217.565536] usb 5-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Aug 19 10:24:59 medetic kernel: [ 217.565544] usb 5-2: Product: USB-compliant keyboard
Aug 19 10:24:59 medetic kernel: [ 217.565776] usb 5-2: configuration #1 chosen from 1 choice
Aug 19 10:24:59 medetic kernel: [ 217.584705] input: USB-compliant keyboard as /devices/pci0000:00/0000:00:1d.0/usb5/5-2/5-2:1.0/input/input13
Aug 19 10:24:59 medetic kernel: [ 217.585385] generic-usb 0003:0B38:0003.0005: input,hidraw2: USB HID v1.10 Keyboard [USB-compliant keyboard] on usb-0000:00:1d.0-2/input0
Aug 19 10:24:59 medetic kernel: [ 217.612873] input: USB-compliant keyboard as /devices/pci0000:00/0000:00:1d.0/usb5/5-2/5-2:1.1/input/input14
Aug 19 10:24:59 medetic kernel: [ 217.613609] generic-usb 0003:0B38:0003.0006: input,hiddev1,hidraw3: USB HID v1.10 Mouse [USB-compliant keyboard] on usb-0000:00:1d.0-2/input1
Aug 19 10:25:00 medetic kernel: [ 219.136175] usb 5-1: USB disconnect, address 2
Aug 19 10:25:03 medetic kernel: [ 221.360085] usb 5-1: new low speed USB device using uhci_hcd and address 5
Aug 19 10:25:03 medetic kernel: [ 221.535389] usb 5-1: New USB device found, idVendor=046d, idProduct=c019
Aug 19 10:25:03 medetic kernel: [ 221.535403] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 19 10:25:03 medetic kernel: [ 221.535413] usb 5-1: Product: USB Optical Mouse
Aug 19 10:25:03 medetic kernel: [ 221.535420] usb 5-1: Manufacturer: Logitech
Aug 19 10:25:03 medetic kernel: [ 221.535720] usb 5-1: configuration #1 chosen from 1 choice
Aug 19 10:25:03 medetic kernel: [ 221.551896] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb5/5-1/5-1:1.0/input/input15
Aug 19 10:25:03 medetic kernel: [ 221.552521] generic-usb 0003:046D:C019.0007: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.0-1/input0
Merci pour ton aide.
PS : Je poste le /var/log/messages dans une autre réponse (trop de caractères).
