Je souhaite créer un bonding ethernet+wifi et le mettre à disposition de machines virtuelles:
enp025 -|
|-- bond0 -- bridge0 -- | -- mv
wlp3s0 -|
Contexte: debian buster
Linux portable 4.19.0-6-amd64 … Debian 4.19.67-2+deb10u2 |
Configuration du bridge:
[connection]
id=bridge-bridge0
uuid=adc30868-451f-46b1-8bbd-0b47f02ec5f2
type=bridge
interface-name=bridge0
permissions=
[ipv4]
address1=192.168.1.134/24,192.168.1.1
dns=8.8.8.8;
dns-search=
method=manual
[ipv6]
addr-gen-mode=stable-privacy
dns-search=
ip6-privacy=0
method=ignore
Configuration du bond:
[connection]
id=bond-bond0
uuid=3826c87c-d892-4b5f-998b-3523aeaa01f7
type=bond
interface-name=bond0
master=bridge0
permissions=
slave-type=bridge
timestamp=1581345725
[bond]
downdelay=0
miimon=100
mode=active-backup
primary=enp0s25
updelay=0
Configuration des interfaces:
[connection]
id=bond-slave-enp0s25
uuid=5dc59c71-9077-41c7-a7a4-2a8cd50fd599
type=ethernet
interface-name=enp0s25
master=bond0
permissions=
slave-type=bond
[ethernet]
mac-address-blacklist=
[connection]
id=bond-slave-wlp3s0
uuid=31e01b25-cebb-473b-9fb0-d4bde6c29a8f
type=wifi
interface-name=wlp3s0
master=bond0
permissions=
slave-type=bond
[wifi]
mode=infrastructure
ssid=jpounet2
[wifi-security]
key-mgmt=wpa-psk
psk=*********
Le fichier /proc/net/bonding/bond0 montre que la connexion wifi ne se fait pas:
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: fault-tolerance (active-backup)
Primary Slave: enp0s25 (primary_reselect always)
Currently Active Slave: enp0s25
MII Status: up
MII Polling Interval (ms): 1
Up Delay (ms): 0
Down Delay (ms): 0
Slave Interface: enp0s25
MII Status: up
Speed: 100 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: 00:24:81:xx:yy:zz
Slave queue ID: 0
Slave Interface: wlp3s0
MII Status: down
Speed: Unknown
Duplex: Unknown
Permanent HW addr: 00:21:6a:xx:yy:zz
Slave queue ID: 0
Si je débranche ethernet il n’y a plus bien sûr d’accès à internet.
Correction: La connexion est aléatoire
Impossible de se connecter à partir d’une machine virtuelle
Je dispose d’autres données (/var/log/messages) mais pour l’instant voyez-vous une grosse erreur dans la configuration ?
Merci d’avance,
Note:
- j’ai disablé wpa_supplicant.service, networking.service
- je n’utilise que NetworkManager et nmcli
- l’accès au ssid se fait correctement sans bond
Édit de la modération : Conformément à la FAQ, merci de veiller à poster dans le bon forum…
Faites l’effort de mettre les choses au bon endroit, afin que nous puissions passer plus de temps à discuter et moins à ranger. Ainsi :
Ne commencez pas un sujet dans la mauvaise catégorie.
et, à mettre correctement en forme avec les boutons d’éditions adéquats, ce qui rendra plus lisible votre sujet. ![]()
Merci d’avance.
