Salut tout le monde, premier post sur ce forum a cause d’un probleme dont je veux comprendre la source.
Voici avant tout ma config
uname -a
#lspci
#lsusb
Linux nas 2.6.18-6-686 #1 SMP Sun Feb 10 22:11:31 UTC 2008 i686 GNU/Linux
00:00.0 Host bridge: Intel Corporation 945G/GZ/P/PL Express Memory Controller Hub (rev 02)
00:02.0 VGA compatible controller: Intel Corporation 945G/GZ Express Integrated Graphics Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 01)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #1 (rev 01)
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #2 (rev 01)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #3 (rev 01)
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #4 (rev 01)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1e.2 Multimedia audio controller: Intel Corporation 82801G (ICH7 Family) AC’97 Audio Controller (rev 01)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller IDE (rev 01)
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 01)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 01)
02:01.0 RAID bus controller: Silicon Image, Inc. SiI 3114 [SATALink/SATARaid] Serial ATA Controller (rev 02)
02:02.0 Mass storage controller: ALi Corporation ALi M5281 Serial ATA / RAID Host Controller (rev a1)
02:02.1 Mass storage controller: ALi Corporation M5228 ALi ATA/RAID Controller (rev c6)
Le probleme qui m’enerve le plus est le premier (et il n’est pas lie a ma config teste sur 3 cartes meres differentes);
A l’install tout se passe bien puis a un moment donne mon (seul) disque ide pata devient hde.
Donc pour pouvoir demarrer je dois a l’ecran ou on peut choisir son noyau editer la ligne ou figure “hda” et la remplacer par “hde” , ca boot c’est super je modifie mon menu.lst et voila.
So far so good mais le probleme est que suite a quelques bidouillages le probleme s’inverse de temps en temps.
Donc pas terrible pour un nas sans ecran ni souris.
Au jourd’hui je crois avoir isole la cause de mon probleme;
Le controleur sata avec un chipset ali que j’ai rajoute hier (2 dernieres lignes de ma config";
Mon nas tournait depuis 2-3 mois nikel suite a fresh install sur new carte mere ds son nouveau boitier “homemade” et la patatras je rajoute la carte que je comptais lui remettre depuis le debut et re probleme.
S’ensuit aussi l’erreur suivante “Could not stat device file” ctrl-d pour entrer ds un shell (ben pourquoi faire ma bonne dame)
Ou enter et hop ca boot normal.
Ca je connais j’ai deja eu donc pour info faut reinstaller initramfs-tools moi j’ai trouve ca sur le net ;
$ apt-get instal wajig
$ wajig reinstall initramfs-tools
Donc voila un post bien long et bien lourd meme pas un applel a l’aide car j’ai pu “reparer” mais si quelqun a un idee sur le pourquoi du comment ben je l’en remercie bien.
Edit; Desole apres ce lauis je me rend compte que tout simple ment ma carte integre egalement un controleur pata en plus du sata qui doit etre detecte avant le port pata integre a la carte mere (allez savoir pourquoi j’aurais cru le contraire).
Donc mon hda devient mon hde…
Meme si j’ai aucun disque connecte a cette carte?
Bizarre quand meme non?
pour qu’il retrouve son petit sda sur le disque scsi avec une propension impressionnante à l’attribuer d’abord au lecteur de cartes usb)
) jamais des 2.4 car je pense que je n’en utiliserai jamais. Et testé sur 3 machines différentes (du pIII au dual core)!
