depuis upgrade de mon kernel au 2.6.18-2 ppc (mac powerpc) je n’arrive plus à booter.
[quote]… debut du boot bla bla
VFS: Cannot open root device “hda3” or unknow-block(0,0)
Please append a correct “root=” boot option
Kernel panic - not syncing: VFS: Unable to mount root fs on unknow-block(0,0)
<0>Rebooting in 180 seconds…
mon yaboot.conf: (pas grub ni lilo pour mac)
livecd hda3 # ls -l /mnt/hda3/boot
[quote]total 37080
-rw-r–r-- 1 root root 685422 Jul 29 13:24 System.map-2.6.17-1-powerpc
-rw-r–r-- 1 root root 725295 Oct 21 15:35 System.map-2.6.18-1-powerpc
-rw-r–r-- 1 root root 725324 Nov 8 17:51 System.map-2.6.18-2-powerpc
-rw-r–r-- 1 root root 53185 Jul 29 11:35 config-2.6.17-1-powerpc
-rw-r–r-- 1 root root 57732 Oct 21 14:12 config-2.6.18-1-powerpc
-rw-r–r-- 1 root root 57768 Nov 8 16:25 config-2.6.18-2-powerpc
-rw-r–r-- 1 root root 40003 Mar 20 2005 config-2.6.8-powerpc
-rw-r–r-- 1 root root 5252974 Nov 6 16:32 initrd.img-2.6.17-1-powerpc
-rw-r–r-- 1 root root 5253004 Nov 6 16:25 initrd.img-2.6.17-1-powerpc.bak
-rw-r–r-- 1 root root 5344695 Nov 10 16:46 initrd.img-2.6.18-1-powerpc
-rw-r–r-- 1 root root 5344616 Nov 10 16:40 initrd.img-2.6.18-2-powerpc
-rw-r–r-- 1 root root 1511424 Jan 15 2006 initrd.img-2.6.8-powerpc
lrwxrwxrwx 1 root root 27 Nov 10 16:40 initrd.img.11295 -> initrd.img-2.6.18-2-powerpc
lrwxrwxrwx 1 root root 27 Jul 24 06:47 initrd.img.15251 -> initrd.img-2.6.17-1-powerpc
lrwxrwxrwx 1 root root 24 Nov 10 16:40 vmlinux -> vmlinux-2.6.18-2-powerpc
-rw-r–r-- 1 root root 3997563 Jul 29 13:23 vmlinux-2.6.17-1-powerpc
-rw-r–r-- 1 root root 4393076 Oct 21 15:35 vmlinux-2.6.18-1-powerpc
-rw-r–r-- 1 root root 4392900 Nov 8 17:51 vmlinux-2.6.18-2-powerpc
lrwxrwxrwx 1 root root 24 Jul 24 06:47 vmlinux.old -> vmlinux-2.6.17-1-powerpc[/quote]
livecd hda3 # cat /proc/cpuinfo
[quote]processor : 0
cpu : 740/750
temperature : 46-48 C (uncalibrated)
clock : 233MHz
revision : 2.2 (pvr 0008 0202)
bogomips : 464.89
total bogomips : 464.89
machine : iMac,1
motherboard : iMac MacRISC Power Macintosh
detected as : 65 (iMac (first generation))
pmac flags : 00000000
L2 cache : 512K unified
memory : 160MB
pmac-generation : NewWorld[/quote]
livecd hda3 # mac-fdisk -l
[quote]/dev/hda
# type name length base ( size ) system
/dev/hda1 Apple_partition_map Apple 63 @ 1 ( 31.5k) Partition map
/dev/hda2 Apple_Bootstrap untitled 1954 @ 64 (977.0k) NewWorld bootblock
/dev/hda3 Apple_UNIX_SVR2 untitled 10710938 @ 2018 ( 5.1G) Linux native
/dev/hda4 Apple_UNIX_SVR2 swap 925782 @ 10712956 (452.0M) Linux swap
/dev/hda5 Apple_UNIX_SVR2 untitled 27463598 @ 11638738 ( 13.1G) Linux native
Block size=512, Number of Blocks=39102336
DeviceType=0x0, DeviceId=0x0
/dev/hdc
/dev/hdc1 Apple_partition_map Apple 2 @ 1 ( 1.0k) Partition map
/dev/hdc2 Apple_HFS Gentoo LiveCD 2005.0 ppc 633200 @ 16 (309.2M) HFS
Block size=512, Number of Blocks=633216
DeviceType=0x1, DeviceId=0x1
Rien dans dmesg evidement …
Une aide serait la bienvenue
