Je continue à regarder…
En fait lors du boot, j’ai bien un problème de mémoire qui apparait dans kern.log, je ne sais pas si ca peut être lié :
[size=70]May 16 15:17:57 osiris kernel: [ 17.864051] Xorg invoked oom-killer: gfp_mask=0x0, order=0, oom_adj=0, oom_score_adj=0
May 16 15:17:57 osiris kernel: [ 17.864054] Xorg cpuset=/ mems_allowed=0
May 16 15:17:57 osiris kernel: [ 17.864058] Pid: 1268, comm: Xorg Tainted: P O 2.6.38-2-amd64 #1
May 16 15:17:57 osiris kernel: [ 17.864059] Call Trace:
May 16 15:17:57 osiris kernel: [ 17.864067] [<ffffffff810b7684>] ? T.586+0x6e/0x184
May 16 15:17:57 osiris kernel: [ 17.864070] [<ffffffff8100022f>] ? _stext+0x9f/0xe70
May 16 15:17:57 osiris kernel: [ 17.864073] [<ffffffff8100022f>] ? _stext+0x9f/0xe70
May 16 15:17:57 osiris kernel: [ 17.864076] [<ffffffff8100679f>] ? xen_restore_fl_direct_end+0x0/0x1
May 16 15:17:57 osiris kernel: [ 17.864081] [<ffffffff81326ea0>] ? _raw_spin_unlock_irqrestore+0x10/0x11
May 16 15:17:57 osiris kernel: [ 17.864084] [<ffffffff810b77e4>] ? T.585+0x4a/0x26c
May 16 15:17:57 osiris kernel: [ 17.864087] [<ffffffff810b7e06>] ? out_of_memory+0x400/0x470
May 16 15:17:57 osiris kernel: [ 17.864091] [<ffffffff8100538e>] ? pte_mfn_to_pfn+0x22/0x2b
May 16 15:17:57 osiris kernel: [ 17.864094] [<ffffffff810b7ef4>] ? pagefault_out_of_memory+0x7e/0xde
May 16 15:17:57 osiris kernel: [ 17.864098] [<ffffffff8132a07b>] ? do_page_fault+0x25e/0x34c
May 16 15:17:57 osiris kernel: [ 17.864240] [<ffffffffa07bc7c5>] ? nv_kern_unlocked_ioctl+0x1c/0x20 [nvidia]
May 16 15:17:57 osiris kernel: [ 17.864245] [<ffffffff81104b0b>] ? do_vfs_ioctl+0x467/0x4b4
May 16 15:17:57 osiris kernel: [ 17.864248] [<ffffffff81326e75>] ? _raw_spin_lock_irq+0x7/0x22
May 16 15:17:57 osiris kernel: [ 17.864252] [<ffffffff81054b20>] ? sigprocmask+0xbb/0xc6
May 16 15:17:57 osiris kernel: [ 17.864256] [<ffffffff813274d5>] ? page_fault+0x25/0x30
[/size]
Puis il se mets à tuer des processus pour régler le problème :
- rpcbind
- rpc.statd
- rpc.idmapd
- startpar
Et puis c’est fini. Je pense qu’on perd tout contact avec les périphérique quand il se met à tuer startpar (qui gère udev non ?). Ensuite pas plus d’info dans kern.log.
