Dans une vieille version de /var/log/messages ca donne ca à la fin
Nov 27 17:43:00 localhost kernel: ACPI: PCI interrupt 0000:01:08.0[A] -> GSI 16 (level, high) -> IRQ 16
Nov 27 17:43:00 localhost kernel: AEC6880R: IDE controller at PCI slot 0000:01:0a.0
Nov 27 17:43:00 localhost kernel: ACPI: PCI interrupt 0000:01:0a.0[A] -> GSI 18 (level, high) -> IRQ 18
Nov 27 17:43:00 localhost kernel: AEC6880R: chipset revision 7
Nov 27 17:43:00 localhost kernel: AEC6880R: 100%% native mode on irq 18
Nov 27 17:43:00 localhost kernel: ide6: BM-DMA at 0xc000-0xc007, BIOS settings: hdm:DMA, hdn:pio
Nov 27 17:43:00 localhost kernel: ide7: BM-DMA at 0xc008-0xc00f, BIOS settings: hdo:pio, hdp:pio
Nov 27 17:43:00 localhost kernel: hdm: Maxtor 6B200P0, ATA DISK drive
Nov 27 17:43:00 localhost kernel: ide6 at 0xb000-0xb007,0xb402 on irq 18
Nov 27 17:43:00 localhost kernel: hdm: max request size: 1024KiB
Nov 27 17:43:00 localhost kernel: hdm: 398297088 sectors (203928 MB) w/8192KiB Cache, CHS=24792/255/63, UDMA(133)
Nov 27 17:43:00 localhost kernel: /dev/ide/host6/bus0/target0/lun0: p1
Nov 27 17:43:00 localhost kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Nov 27 17:43:44 localhost kernel: apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16ac)
Nov 27 17:43:44 localhost kernel: apm: overridden by ACPI.
Et dans la nouvelle version ca donne cela
Dec 13 23:53:18 localhost kernel: ACPI: PCI interrupt 0000:01:08.0[A] -> GSI 16 (level, high) -> IRQ 16
Dec 13 23:53:18 localhost kernel: AEC6880R: IDE controller at PCI slot 0000:01:0a.0
Dec 13 23:53:18 localhost kernel: ACPI: PCI interrupt 0000:01:0a.0[A] -> GSI 18 (level, high) -> IRQ 18
Dec 13 23:53:18 localhost kernel: AEC6880R: chipset revision 7
Dec 13 23:53:18 localhost kernel: AEC6880R: 100%% native mode on irq 18
Dec 13 23:53:18 localhost kernel: ide6: BM-DMA at 0xc000-0xc007, BIOS settings: hdm:DMA, hdn:pio
Dec 13 23:53:18 localhost kernel: ide7: BM-DMA at 0xc008-0xc00f, BIOS settings: hdo:pio, hdp:pio
Dec 13 23:53:18 localhost kernel: hdm: Maxtor 6B200P0, ATA DISK drive
Dec 13 23:53:18 localhost kernel: ide6 at 0xb000-0xb007,0xb402 on irq 18
Dec 13 23:53:18 localhost kernel: hdm: max request size: 1024KiB
Dec 13 23:53:18 localhost kernel: hdm: 398297088 sectors (203928 MB) w/8192KiB Cache, CHS=24792/255/63, UDMA(133)
Dec 13 23:53:18 localhost kernel: /dev/ide/host6/bus0/target0/lun0: p1
Dec 13 23:53:18 localhost kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Et donc ce qui vient juste apres la carte reseau c’est… APM
Donc apperement t’as raison c’est lui qui bloque le boot et quand je regarde dans d’autres logs j’ai ca:
Dec 13 17:17:21 localhost modprobe: FATAL: Error inserting apm (/lib/modules/2.6.8/kernel/arch/i386/kernel/apm.ko): No such device
Dec 13 17:31:42 localhost modprobe: FATAL: Error inserting apm (/lib/modules/2.6.8/kernel/arch/i386/kernel/apm.ko): No such device
le truc c’est que le module est bien present à cet endroit meme.
Voila je fais fouiller un peu si une solution vous avez je suis preneur
Merci de l’aide ++
