je viens tout juste de finir une install de Lenny sur mon laptop et tout fonctionne bien sauf deux petites choses, dont l’une est cette ligne au boot, qui revient deux fois :
Je joins mon /var/log/boot complet, au cas-où :
Sat Jan 23 10:31:45 2010: .
Sat Jan 23 10:31:45 2010: Setting preliminary keymap...done.
Sat Jan 23 10:31:45 2010: Setting parameters of disc: (none).
Sat Jan 23 10:31:45 2010: Setting the system clock.
Sat Jan 23 10:31:45 2010: Activating swap...done.
Sat Jan 23 10:31:45 2010: Checking root file system...fsck 1.41.3 (12-Oct-2008)
Sat Jan 23 10:31:45 2010: /dev/hda1: clean, 46147/488640 files, 517423/1953897 blocks
Sat Jan 23 10:31:45 2010: done.
Sat Jan 23 10:31:46 2010: Cleaning up ifupdown....
Sat Jan 23 10:31:46 2010: Loading kernel modules...done.
Sat Jan 23 10:31:46 2010: Checking file systems...fsck 1.41.3 (12-Oct-2008)
Sat Jan 23 10:31:46 2010: /dev/hda3: recovering journal
Sat Jan 23 10:31:48 2010: /dev/hda3: clean, 4717/1925120 files, 1089434/7689110 blocks
Sat Jan 23 10:31:48 2010: done.
Sat Jan 23 10:31:48 2010: Setting kernel variables (/etc/sysctl.conf)...done.
Sat Jan 23 10:31:48 2010: Invalidating stale software suspend images... done.
Sat Jan 23 10:31:48 2010: Mounting local filesystems...done.
Sat Jan 23 10:31:48 2010: Activating swapfile swap...done.
Sat Jan 23 10:31:48 2010: Setting up networking....
Sat Jan 23 10:31:48 2010: Configuring network interfaces...done.
Sat Jan 23 10:31:48 2010: Starting NFS common utilities: statd failed!
Sat Jan 23 10:31:49 2010: Setting console screen modes and fonts.
Sat Jan 23 10:31:49 2010: Setting up console font and keymap...done.
Sat Jan 23 10:31:50 2010: Setting up ALSA...done.
Sat Jan 23 10:31:50 2010: INIT: Entering runlevel: 2
Sat Jan 23 10:31:51 2010: Saving VESA state....
Sat Jan 23 10:31:51 2010: Starting enhanced syslogd: rsyslogd.
Sat Jan 23 10:31:51 2010: Starting ACPI services....
Sat Jan 23 10:31:51 2010: Starting system message bus: dbus.
Sat Jan 23 10:31:52 2010: Starting firewall
Sat Jan 23 10:31:52 2010: Starting NFS common utilities: statd failed!
Sat Jan 23 10:31:52 2010: Not starting internet superserver: no services enabled.
Sat Jan 23 10:31:52 2010: Starting Hardware abstraction layer: hald.
Sat Jan 23 10:31:54 2010: Starting anac(h)ronistic cron: anacron.
Sat Jan 23 10:31:54 2010: Starting periodic command scheduler: crond.
Sat Jan 23 10:31:54 2010: Starting preload: preload.
Sat Jan 23 10:31:55 2010: Checking battery state...
Sat Jan 23 10:31:55 2010: /dev/hda:
Sat Jan 23 10:31:55 2010: setting Advanced Power Management level to 0xfe (254)
Sat Jan 23 10:31:55 2010: .
Donc mes questions sont :
Qu’est-ce que NFS ?
Pourquoi plante-t’il sur cette install alors qu’une précédente Lenny sur ce même laptop fonctionnait bien ?
Merci d’avance
