Mon bios ne me permet pas de paramétrer le type d’interface du disque dur (sata, ata, ide …).
J’ai essayé le kernel 2.6.30-bpo.2-686_2 (donc 32 bits), même résultat. dpkg refuse d’installer un kernel 64 bits car il dit que ça correspond pas à ma distributions qui est 32 bits d’origine.
Après je vais tester une sid (j’ai déjà une lenny d’installée dont je ne me sert pas, je vais la faire passer en sid).
Ce que j’aurait du faire plus tôt, je met ici les lignes du dmesg qui me semblent suspectes :
[ 0.000000] ACPI: BIOS bug: multiple APIC/MADT found, using 0
[ 0.000000] ACPI: If "acpi_apic_instance=2" works better, notify linux-acpi@vger.kernel.org
[ 0.098860] ACPI: Core revision 20080321 /* 2.6.30 bpo : 20090320 */
[ 0.112007] ENABLING IO-APIC IRQs
[ 0.244015] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.244015] ACPI: bus type pci registered
[ 0.254879] ACPI: BIOS _OSI(Linux) query ignored via DMI
[ 0.256016] ACPI: Interpreter enabled
[ 0.256016] ACPI: (supports S0 S3 S4 S5)
[ 0.256664] ACPI: Using IOAPIC for interrupt routing
[ 0.256664] ACPI: EC: non-query interrupt received, switching to interrupt mode
[ 0.304019] ACPI: EC: driver started in interrupt mode
[ 0.304019] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.304019] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH6 ACPI/GPIO/TCO
[ 0.304019] pci 0000:00:1f.0: quirk: region 1180-11bf claimed by ICH6 GPIO
[ 0.306064] PCI: Transparent bridge - 0000:00:1e.0
[ 0.306294] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.306611] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEGP._PRT]
[ 0.332020] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 *5 6 7 10 12 14 15)
[ 0.332020] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.356655] ACPI: ACPI bus type pnp unregistered
[ 0.356655] PnPBIOS: Disabled by ACPI PNP
[ 0.356655] PCI: Using ACPI for IRQ routing
[ 0.367248] ACPI: RTC can wake from S4
[ 0.407323] PCI: region 0000:08:03.0/9 too large: 0x0000000000000000-0x0000000003ffffff
[ 0.407484] PCI: Failed to allocate mem resource #6:20000@e0000000 for 0000:01:00.0
[ 0.412605] PCI: Setting latency timer of device 0000:00:1e.0 to 64 /* pas de message de ce type pour 00:1f.0 */
[ 0.995908] SCSI subsystem initialized
[ 1.003905] libata version 3.00 loaded.
[ 1.005296] ahci 0000:00:1f.2: version 3.0
[ 1.005296] ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 19 (level, low) -> IRQ 19
[ 2.007207] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 3 ports 3 Gbps 0x3 impl SATA mode
[ 2.007363] ahci 0000:00:1f.2: flags: 64bit ncq sntf led clo pio slum part
[ 2.007506] PCI: Setting latency timer of device 0000:00:1f.2 to 64
[ 2.011170] scsi0 : ahci
[ 2.011170] scsi1 : ahci
[ 2.011170] scsi2 : ahci
[ 2.012175] ata1: SATA max UDMA/133 abar m2048@0xfc304000 port 0xfc304100 irq 219
[ 2.012175] ata2: SATA max UDMA/133 abar m2048@0xfc304000 port 0xfc304180 irq 219
[ 2.012175] ata3: DUMMY
[ 2.235731] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.235731] ACPI Error (psargs-0358): [SMS_] Namespace lookup failure, AE_NOT_FOUND
[ 2.328951] ACPI Error (psparse-0530): Method parse/execution failed [\_SB_.PCI0.SATA.PRT0._SDD] (Node f783ccfc), AE_NOT_FOUND
[ 2.329509] ata1.00: ACPI _SDD failed (AE 0x5)
[ 2.329649] ata1: failed to recover some devices, retrying in 5 secs
[ 7.564185] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 7.656801] ACPI Error (psargs-0358): [SMS_] Namespace lookup failure, AE_NOT_FOUND
[ 7.656801] ACPI Error (psparse-0530): Method parse/execution failed [\_SB_.PCI0.SATA.PRT0._SDD] (Node f783ccfc), AE_NOT_FOUND
[ 7.656801] ata1.00: ACPI _SDD failed (AE 0x5)
[ 7.656801] ata1.00: ACPI: failed the second time, disabled
[ 8.036195] ata1.00: configured for UDMA/100
[ 8.260184] ata2: SATA link down (SStatus 0 SControl 300)
[ 8.349098] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MK2035GS DK02 PQ: 0 ANSI: 5
[ 8.376183] ACPI: SSDT 7FEDBFCE, 0298 (r1 Sony VAIO 20070718 PTL 20050624)
[ 8.376183] ACPI: SSDT 7FEDBBE1, 035B (r1 Sony VAIO 20070718 PTL 20050624)
[ 11.620935] ACPI: Battery Slot [BAT0] (battery present)
[ 11.733119] ACPI: PCI Interrupt 0000:00:1a.1[B] -> GSI 21 (level, low) -> IRQ 21
[ 11.733408] PCI: Setting latency timer of device 0000:00:1a.1 to 64
[ 13.195844] ICH8M: IDE controller (0x8086:0x2850 rev 0x03) at PCI slot 0000:00:1f.1
[ 13.195844] ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 19 (level, low) -> IRQ 19
[ 13.195863] ICH8M: not 100% native mode: will probe irqs later
[ 13.196031] ide0: BM-DMA at 0x18a0-0x18a7
[ 13.196186] ide1: BM-DMA at 0x18a8-0x18af
[ 13.196334] Probing IDE interface ide0...
[ 14.851889] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 14.852559] ide1 at 0x170-0x177,0x376 on irq 15
Et voici quelques lignes qui changent dans le dmesg du kernel 2.6.30 bpo :
[ 7.142982] ata1.00: configured for UDMA/100
[ 7.143206] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MK2035GS DK02 PQ: 0 ANSI: 5
[ 7.167501] ACPI: Invalid passive threshold
[ 7.167695] ACPI: Invalid active0 threshold
[ 7.171110] ACPI: EC: GPE storm detected, transactions will use polling mode
[ 7.185303] ACPI: Invalid active0 threshold
[ 7.388338] Driver 'sd' needs updating - please use bus_type methods
EDIT: arf j’ai des problèmes de dépendances du coup j’arrive même pas à upgrader vers testing … je vais installer une sid neuve.
