J’ai un beau bordel à ranger sur mes disques durs et partitions ; en gros j’ai surement plein de fichiers en double ou triple ; rsync saurait-il me faire le tri de tout cela ?
FSlint (d’ailleurs il ne fait pas que trouver les doublons, je te laisse regarder).
Merci, je vais l’essayer
Mériterait sa place dans l’appli du jour! ![]()
Cherchez l’erreur ? Quelle bêtise ais-je encore faite ?
gerard@glu:~$ sudo fslint-gui finded
[sudo] password for gerard:
No protocol specified
/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/__init__.py:57: GtkWarning: could not open display
warnings.warn(str(e), _gtk.Warning)
/usr/bin/fslint-gui:251: Warning: invalid (NULL) pointer instance
self.widgets = gtk.glade.XML(Filename, WindowName, gettext.textdomain())
/usr/bin/fslint-gui:251: Warning: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
/usr/bin/fslint-gui:251: GtkWarning: IA__gtk_settings_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
/usr/bin/fslint-gui:251: Warning: g_object_get: assertion `G_IS_OBJECT (object)' failed
/usr/bin/fslint-gui:251: Warning: value "TRUE" of type `gboolean' is invalid or out of range for property `visible' of type `gboolean'
/usr/bin/fslint-gui:251: GtkWarning: IA__gdk_pango_context_get_for_screen: assertion `GDK_IS_SCREEN (screen)' failed
/usr/bin/fslint-gui:251: PangoWarning: pango_context_set_font_description: assertion `context != NULL' failed
/usr/bin/fslint-gui:251: PangoWarning: pango_context_set_base_dir: assertion `context != NULL' failed
/usr/bin/fslint-gui:251: PangoWarning: pango_context_set_language: assertion `context != NULL' failed
/usr/bin/fslint-gui:251: PangoWarning: pango_context_get_language: assertion `context != NULL' failed
/usr/bin/fslint-gui:251: PangoWarning: pango_context_get_metrics: assertion `PANGO_IS_CONTEXT (context)' failed
/usr/bin/fslint-gui:251: PangoWarning: pango_font_metrics_get_ascent: assertion `metrics != NULL' failed
/usr/bin/fslint-gui:251: PangoWarning: pango_font_metrics_get_descent: assertion `metrics != NULL' failed
/usr/bin/fslint-gui:251: PangoWarning: pango_layout_new: assertion `context != NULL' failed
/usr/bin/fslint-gui:251: PangoWarning: pango_layout_set_attributes: assertion `layout != NULL' failed
/usr/bin/fslint-gui:251: PangoWarning: pango_layout_set_text: assertion `layout != NULL' failed
/usr/bin/fslint-gui:251: PangoWarning: pango_layout_get_unknown_glyphs_count: assertion `PANGO_IS_LAYOUT (layout)' failed
/usr/bin/fslint-gui:251: Warning: g_object_unref: assertion `G_IS_OBJECT (object)' failed
/usr/bin/fslint-gui:251: GtkWarning: IA__gdk_screen_get_display: assertion `GDK_IS_SCREEN (screen)' failed
/usr/bin/fslint-gui:251: GtkWarning: IA__gdk_keymap_get_for_display: assertion `GDK_IS_DISPLAY (display)' failed
python:
Installé : 2.7.3-4
Candidat : 2.7.3-4
Essaye de taper $ xhost + avant de lancer ton sudo.
Sinon pour ceux qui préfèrent le terminal, le paquet fdupes fait aussi le boulot.
[quote=“lroy”]Salut,
Sinon pour ceux qui préfèrent le terminal, le paquet fdupes fait aussi le boulot.[/quote]
Bravo ! La commande : kdesudo fslint-gui finded
Super l’appli ![]()
Bon, faut faire gaffe mais le boulot est parfaitement executer.
C’est çà que j’adore chez linux : une petite application qui fait un seul boulot mais qui le fait parfaitement ; rien à voir avec les usines à gaz !!
Merci encore
