J’ai une erreur permanente pour créer un CD-R audio, qui est bien reconnu comme vierge, mais la gravure est interrompue. Le .log semble être correct jusqu’au moment où :
BraseroWodim stdout: Drive buf size : 542080 = 529 KB
BraseroWodim stdout: FIFO size : 16777216 = 16384 KB
BraseroWodim stderr: Speed set to 4234 KB/s
BraseroWodim called brasero_job_get_flags
BraseroWodim stdout: pregap1: -1
BraseroWodim stdout: Track 01: audio 29 MB (02:53.80) no preemp swab copy
BraseroWodim stdout: Track 02: audio 25 MB (02:33.89) no preemp swab copy
BraseroWodim stdout: Track 03: audio 22 MB (02:13.30) no preemp swab copy
BraseroWodim stdout: Track 04: audio 32 MB (03:10.22) no preemp swab copy
BraseroWodim stdout: Track 05: audio 43 MB (04:20.05) no preemp swab copy
BraseroWodim stdout: Track 06: audio 23 MB (02:19.89) no preemp swab copy
BraseroWodim stdout: Track 07: audio 19 MB (01:53.28) no preemp swab copy
BraseroWodim stdout: Track 08: audio 28 MB (02:51.97) no preemp swab copy
BraseroWodim stdout: Track 09: audio 18 MB (01:50.24) no preemp swab copy
BraseroWodim stdout: Track 10: audio 21 MB (02:08.37) no preemp swab copy
BraseroWodim stdout: Track 11: audio 24 MB (02:24.01) no preemp swab copy
BraseroWodim stdout: Track 12: audio 26 MB (02:37.81) no preemp swab copy
BraseroWodim stdout: Track 13: audio 21 MB (02:05.81) no preemp swab copy
BraseroWodim stdout: Track 14: audio 23 MB (02:18.94) no preemp swab copy
BraseroWodim stdout: Track 15: audio 22 MB (02:14.25) no preemp swab copy
BraseroWodim stdout: Track 16: audio 24 MB (02:28.38) no preemp swab copy
BraseroWodim stdout: Track 17: audio 24 MB (02:24.14) no preemp swab copy
BraseroWodim stdout: Track 18: audio 21 MB (02:10.64) no preemp swab copy
BraseroWodim stdout: Track 19: audio 26 MB (02:36.45) no preemp swab copy
BraseroWodim stdout: Track 20: audio 44 MB (04:24.78) no preemp swab copy
BraseroWodim stdout: Track 21: audio 20 MB (02:01.86) no preemp swab copy
BraseroWodim stdout: Track 22: audio 30 MB (02:59.16) no preemp swab copy
BraseroWodim stdout: Track 23: audio 23 MB (02:22.48) no preemp swab copy
BraseroWodim stdout: Track 24: audio 65 MB (06:26.49) no preemp swab copy
BraseroWodim stdout: Total size: 664 MB (65:50.29) = 296272 sectors
BraseroWodim stdout: Lout start: 664 MB (65:52/22) = 296272 sectors
BraseroWodim stdout: Current Secsize: 2048
BraseroWodim stdout: ATIP info from disk:
BraseroWodim stdout: Indicated writing power: 5
BraseroWodim stdout: Is not unrestricted
BraseroWodim stdout: Is not erasable
BraseroWodim stdout: Disk sub type: Medium Type A, high Beta category (A+) (3)
BraseroWodim stdout: ATIP start of lead in: -11634 (97:26/66)
BraseroWodim stdout: ATIP start of lead out: 359846 (79:59/71)
BraseroWodim stdout: Disk type: Short strategy type (Phthalocyanine or similar)
BraseroWodim stdout: Manuf. index: 3
BraseroWodim stdout: Manufacturer: CMC Magnetics Corporation
BraseroWodim stdout: Blocks total: 359846 Blocks current: 359846 Blocks remaining: 63574
BraseroWodim stdout: Forcespeed is OFF.
BraseroWodim stdout: Starting to write CD/DVD at speed 24.0 in real SAO mode for single session.
BraseroWodim stdout: Last chance to quit, starting real write in 4 seconds.
BraseroWodim called brasero_job_set_dangerous
BraseroWodim stdout: 3 seconds.
BraseroWodim stdout: 2 seconds.
BraseroWodim stdout: 1 seconds. 0 seconds. Operation starts.
BraseroWodim stdout: Waiting for reader process to fill input buffer ... input buffer ready.
BraseroWodim stdout: Performing OPC...
BraseroWodim stdout: Sending CUE sheet...
BraseroWodim called brasero_job_get_input_type
BraseroWodim called brasero_job_set_current_action
BraseroWodim stderr: Errno: 5 (Input/output error), write_g1 scsi sendcmd: no error
BraseroWodim stderr: CDB: 2A 00 FF FF D2 8E 00 02 94 00
BraseroWodim stderr: status: 0x2 (CHECK CONDITION)
BraseroWodim stderr: Sense Bytes: 71 00 03 00 00 00 00 0A 00 00 00 00 0C 00 00 00
BraseroWodim stderr: Sense Key: 0x3 Medium Error, deferred error, Segment 0
BraseroWodim stderr: Sense Code: 0x0C Qual 0x00 (write error) Fru 0x0
BraseroWodim stderr: Sense flags: Blk 0 (not valid)
BraseroWodim stderr: resid: 18416
BraseroWodim stderr: cmd finished after 21.134s timeout 200s
BraseroWodim stderr: wodim: Could not write Lead-in.
BraseroWodim called brasero_job_error
BraseroWodim finished with an error
BraseroWodim asked to stop because of an error
error = 15
message = "Une erreur est survenue lors de l’écriture sur le disque"
BraseroWodim stopping
BraseroWodim got killed
Session error : Une erreur est survenue lors de l’écriture sur le disque (brasero_burn_record brasero-burn.c:2854)
Comment interpréter cette erreur ? Merci !!
