ca ne fonctionne pas
le DHCP ne trouve rien du tout.
Il y’a un DHCP du coté Wifi, mais pas du coté filaire.
[code]neptune:~# dhclient br0
There is already a pid file /var/run/dhclient.pid with pid 3748
killed old client process, removed PID file
Internet Systems Consortium DHCP Client V3.1.1
Copyright 2004-2008 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
Listening on LPF/br0/00:00:XX:00:00:5c
Sending on LPF/br0/00:00:XX:00:00:5c
Sending on Socket/fallback
DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 4
DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on br0 to 255.255.255.255 port 67 interval 17
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
alors que :
[code]neptune:~# iwconfig wlan0
wlan0 802.11b/g linked ESSID:"XXXXXXXXXX"
Mode:Managed Channel=4 Access Point: FF:ff:XX:ff:XX:ff
Bit Rate=5 Mb/s Tx-Power=5 dBm
Retry:on Fragment thr:off
Encryption key:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Security mode:open
Link Quality=81/100 Signal level=49 dBm Noise level=19 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
neptune:~# dhclient wlan0
There is already a pid file /var/run/dhclient.pid with pid 4427
Listening on LPF/wlan0/00:00:XX:00:00:bb
Sending on LPF/wlan0/00:00:XX:00:00:bb
DHCPREQUEST on wlan0 to 255.255.255.255 port 67
DHCPACK from 192.168.1.1
bound to 192.168.1.8 – renewal in 35578 seconds.
y’a t-il un ordre dans les commandes pour faire le pont?
