Brother MFC-660CN USB scanner non reconnu
Bonjour.
Je viens d’installer les pilotes pour une brother MFC-660CN sur une Debian 10 Mate.
L’imprimante est connectée en USB.
Les pilotes installés téléchargés depuis le site Brother : https://support.brother.com/g/b/downloadend.aspx?c=fr&lang=fr&prod=mfc660cn_eu&os=128&dlid=dlf006893_000&flang=4&type3=625&dlang=true
dpkg  -l  |  grep  Brother
ii  brscan-skey                             0.2.4-1                             amd64        Brother Linux scanner S-KEY tool
ii  brscan2                                 0.2.5-1                             amd64        Brother Scanner Driver
ii  mfc660cncupswrapper:i386                1.0.1-1                             i386         Brother CUPS Inkjet Printer Definitions
ii  mfc660cnlpr:i386                        1.0.1-1                             i386         Brother lpr Inkjet Printer Definitions
ii  printer-driver-brlaser                  4-1                                 amd64        printer driver for (some) Brother laser printers
ii  printer-driver-ptouch                   1.4.2-3                             amd64        printer driver Brother P-touch label printers
sane-find-scanner
  # sane-find-scanner will now attempt to detect your scanner. If the
  # result is different from what you expected, first make sure your
  # scanner is powered up and properly connected to your computer.
  # No SCSI scanners found. If you expected something different, make sure that
  # you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x04f9, product=0x01b0) at libusb:001:002
  # Your USB scanner was (probably) detected. It may or may not be supported by
  # SANE. Try scanimage -L and read the backend's manpage.
  # Not checking for parallel port scanners.
  # Most Scanners connected to the parallel port or other proprietary ports
  # can't be detected by this program.
scanimage -L
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
D’autre part
brsaneconfig3 -q | grep scanner
brsaneconfig3 : commande introuvable
Essaie en root ou avec sudo le scanimage -L pour voir si c’est un problème de permissions.
Il faut certainement avoir l’entrée brother (le backend) dans /etc/sane.d/dll.conf
Bizarre, je n’ai pas de /etc/sane.d/brother.conf :thinking:
https://help.ubuntu.com/community/sane
Brother propose des pilotes SANE propriétaires pour sa famille de scanners réseau et de périphériques multifonctions.
To install, visit [Brother support website] and download the proper driver for your scanner (brscan, brscan2, brscan3 or brscan4) and your computer (32 or 64 bit) to your desktop.
Le MFC-660CN est dans les modèles brscan2.
Le pilote brscan2 est déjà installé.
I Challenge Thee
Le manuel de scanimage décrit que fait -L . Dans le contexte d’un périphérique USB local, pour lequel un utilisateur simple dispose de la permission d’accès, la réponse positive indique que SANE dispose d’un backend pour prendre en charge le scanner.
Et sudo updatedb puis locate brsaneconfig3
C’est plutôt brsaneconfig2 qui est à utiliser.
NOTE : Un point qui déroute beaucoup d’utilisateurs est la différence entre brscan, brscan2, brscan3, brscan4 et brscan5. Chacun de ces outils prend en charge un ensemble différent de scanners, et vous devez télécharger le paquet approprié pour votre scanner. Comme il est possible d’installer de nombreux scanners différents, vous devez exécuter la version appropriée de l’outil brsaneconfig. Si votre scanner est pris en charge par le pilote brscan2, vous devrez exécuter le logiciel brsaneconfig2 pour le configurer.
Refait l’installation avec le script de demonipush :: http://doc.ubuntu-fr.org/utilisateurs/demonipuch/script_brother
Ce ne sont que des réflexions préalables et qui en fin de compte sont à ignorer dans ce cas de figure.
Brother proposant des pilotes SANE propriétaires.
