Bug amsn sur ubuntu
bonsoir, j ai un bug sur amsn sur ubuntu 10.10 au lancement en root voila la reponse du terminal, quelqu un aurais une idée? une silution ?
[sudo] password for mikael:
Error in startup script: can’t read “styleCmd”: no such variable
while executing
"list $styleCmd configure $dest"
(procedure “::chameleon::copyStyle” line 6)
invoked from within
"::chameleon::copyStyle $widget_type $w [array get options]"
(procedure “combobox_parseConfArgs” line 37)
invoked from within
"combobox_parseConfArgs ::chameleon::combobox::combobox_proc_.main.loginscreen.user -editable true -relief solid -bd 1 -width 25 -command {.main.logins…“
invoked from within
"if 1 “${widget_type}_parseConfArgs $evalargs””
(procedure “::chameleon::combobox::combobox” line 13)
invoked from within
"::chameleon::combobox::combobox .main.loginscreen.user -editable true -relief solid -bd 1 -width 25 -command {.main.loginscreen UserSelected} -backgro…"
(“eval” body line 1)
invoked from within
"eval ::chameleon::combobox::combobox $newargs"
(procedure “combobox::combobox” line 1)
invoked from within
"combobox::combobox $self.user -editable true -relief solid -bd [::skin::getKey loginfieldbd 1] -width 25 -command “$self UserSelected” -background [::…"
(procedure “::loginscreen::Snit_constructor” line 44)
invoked from within
"::loginscreen::Snit_constructor ::loginscreen ::loginscreen::Snit_inst1 .main.loginscreen .main.loginscreen"
invoked from within
"eval [linsert $arglist 0 ${type}::Snit_constructor $type $selfns $instance $instance]"
(procedure “RT.ConstructInstance” line 9)
invoked from within
"RT.ConstructInstance $type $selfns $name $args"
(procedure “::snit::RT.widget.typemethod.create” line 13)
invoked from within
"loginscreen .main.loginscreen “
(procedure “::loginscreen::Snit_typemethodLoggingOut” line 7)
invoked from within
”::loginscreen LoggingOut show_login_screen"
invoked from within
"eval $listener [linsert $args 0 $eventName]"
(procedure “::Event::fireEvent” line 11)
invoked from within
"::Event::fireEvent show_login_screen gui"
(procedure “cmsn_draw_offline” line 3)
invoked from within
"cmsn_draw_offline"
(procedure “cmsn_draw_main” line 129)
invoked from within
"cmsn_draw_main"
(file “/usr/bin/amsn” line 377)
et lancer en user?Normalement root n’a pas accès aux interfaces graphiques.
manuellement j ai un message d ='erreur qui me dit “corrupted files” et en root d’habitude il me lançait l interface graphique de amsn
Essaye de repartir d’un profil tout neuf, pour voir si ca n’est pas lui qui est corrompu (mv ~/.amsn ~/.amsn_old et relance amsn) Si ca fonctionne après ca, c’est que ton profil a un problème et la, ca se complique pour réparer.
merci, j éssayes de ce pas :smiley:
voila la reponse: mv: impossible d’évaluer «/home/mikael/.amsn»: Aucun fichier ou dossier de ce type
:doh:
Peut-être que tu as désinstallé le fichier .amsn manuellement. Du coup amsn, quand il se lance, cherche son fichier .amsn et ne le trouve pas. Une réinstallation de Amsn devrait regler ton problème
Désinstalle amsn ainsi que son fichier de configuration (on ne sait jamais …) puis réinstalle le
#apt-get remove --purge amsn #apt-get install amsn
Si le teste échoue, si sa peut servir: amsn-project.net/forums/inde … 269.0;wap2
