Bonjours à tous,
Voici ce que me produit ntop:
sudo ntop -w 3000 -W 3443
Tue Aug 26 13:25:48 2008 NOTE: Interface merge enabled by default
Tue Aug 26 13:25:48 2008 Initializing gdbm databases
Tue Aug 26 13:25:48 2008 ERROR …open of /var/lib/ntop/prefsCache.db failed: Can’t be writer
Tue Aug 26 13:25:48 2008 Possible solution: please use '-P '
Tue Aug 26 13:25:48 2008 FATAL_ERROR GDBM open failed, ntop shutting down…
Tue Aug 26 13:25:48 2008 CLEANUP[t47588454479904]: ntop caught signal 2
Tue Aug 26 13:25:48 2008 THREADMGMT[t47588454479904]: ntop RUNSTATE: SHUTDOWN(7)
Tue Aug 26 13:25:48 2008 CLEANUP[t47588454479904] catching thread is MAIN
Tue Aug 26 13:25:48 2008 CLEANUP: Running threads
Tue Aug 26 13:25:48 2008 CLEANUP: Locking purge mutex (may block for a little while)
Tue Aug 26 13:25:48 2008 CLEANUP: Locked purge mutex, continuing shutdown
Tue Aug 26 13:25:48 2008 CLEANUP: Continues
Tue Aug 26 13:25:48 2008 PLUGIN_TERM: Unloading plugins (if any)
Tue Aug 26 13:25:48 2008 CLEANUP: Clean up complete
Tue Aug 26 13:25:48 2008 THREADMGMT[t47588454479904]: ntop RUNSTATE: TERM(8)
Tue Aug 26 13:25:48 2008 ===================================
Tue Aug 26 13:25:48 2008 ntop is shutdown…
Etant encore debutant sur linux, j’avoue avoir du mal à comprendre le message d’erreur, si quelqu’un peu m’aider?
Je tourne sur la distributuin 64studio qui est dérivé de DEBIAN, voici ma version du kernel
2.6.21-1-multimedia-amd64
Cordialement
