Je m’évertue à faire fonctionner snort en suivant ces tutos :
http://virtuallyhyper.com/2014/04/snort-debian/
mais je bloque à la configuration de snort avant le make :
J’ai ajouté :
pour que snort retrouve ses petit mais cela ne suffit pas avec daq en version 2.0.4 ou 2.0.5 c’est pareil. Quelqu’un a-t-il déjà réussi à installer cette version de snort sur wheezy ?
La sortie standard du ./configure :
[code]./configure --enable-sourcefire --enable-reload --enable-reload-error-restart --enable-perfprofiling
checking for a BSD-compatible install… /usr/bin/install -c
checking whether build environment is sane… yes
checking for a thread-safe mkdir -p… /bin/mkdir -p
checking for gawk… no
checking for mawk… mawk
checking whether make sets $(MAKE)… yes
checking whether make supports nested variables… yes
checking whether to enable maintainer-specific portions of Makefiles… no
checking for style of include used by make… GNU
checking for gcc… gcc
checking whether the C compiler works… yes
checking for C compiler default output file name… a.out
checking for suffix of executables…
checking whether we are cross compiling… no
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ISO C89… none needed
checking whether gcc understands -c and -o together… yes
checking dependency style of gcc… gcc3
checking for gcc option to accept ISO C99… -std=gnu99
checking for gcc -std=gnu99 option to accept ISO Standard C… (cached) -std=gnu99
checking for gcc… (cached) gcc
checking whether we are using the GNU C compiler… (cached) yes
checking whether gcc accepts -g… (cached) yes
checking for gcc option to accept ISO C89… (cached) none needed
checking whether gcc understands -c and -o together… (cached) yes
checking dependency style of gcc… (cached) gcc3
checking build system type… x86_64-unknown-linux-gnu
checking host system type… x86_64-unknown-linux-gnu
checking how to print strings… printf
checking for a sed that does not truncate output… /bin/sed
checking for grep that handles long lines and -e… /bin/grep
checking for egrep… /bin/grep -E
checking for fgrep… /bin/grep -F
checking for ld used by gcc… /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld… yes
checking for BSD- or MS-compatible name lister (nm)… /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface… BSD nm
checking whether ln -s works… yes
checking the maximum length of command line arguments… 1572864
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format… func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format… func_convert_file_noop
checking for /usr/bin/ld option to reload object files… -r
checking for objdump… objdump
checking how to recognize dependent libraries… pass_all
checking for dlltool… no
checking how to associate runtime and link libraries… printf %s\n
checking for ar… ar
checking for archiver @FILE support… @
checking for strip… strip
checking for ranlib… ranlib
checking command to parse /usr/bin/nm -B output from gcc object… ok
checking for sysroot… no
checking for a working dd… /bin/dd
checking how to truncate binary pipes… /bin/dd bs=4096 count=1
checking for mt… mt
checking if mt is a manifest tool… no
checking how to run the C preprocessor… gcc -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking for dlfcn.h… yes
checking for objdir… .libs
checking if gcc supports -fno-rtti -fno-exceptions… no
checking for gcc option to produce PIC… -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works… yes
checking if gcc static flag -static works… yes
checking if gcc supports -c -o file.o… yes
checking if gcc supports -c -o file.o… (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries… yes
checking whether -lc should be explicitly linked in… no
checking dynamic linker characteristics… GNU/Linux ld.so
checking how to hardcode library paths into programs… immediate
checking whether stripping libraries is possible… yes
checking if libtool supports shared libraries… yes
checking whether to build shared libraries… yes
checking whether to build static libraries… yes
checking for ranlib… (cached) ranlib
checking whether byte ordering is bigendian… no
checking for inline… inline
checking for stdbool.h that conforms to C99… yes
checking for _Bool… yes
checking for bison… bison
checking for flex… flex
checking for inttypes.h… (cached) yes
checking math.h usability… yes
checking math.h presence… yes
checking for math.h… yes
checking paths.h usability… yes
checking paths.h presence… yes
checking for paths.h… yes
checking for stdlib.h… (cached) yes
checking for string.h… (cached) yes
checking for strings.h… (cached) yes
checking for unistd.h… (cached) yes
checking wchar.h usability… yes
checking wchar.h presence… yes
checking for wchar.h… yes
checking sys/sockio.h usability… no
checking sys/sockio.h presence… no
checking for sys/sockio.h… no
checking for floor in -lm… yes
checking for ceil in -lm… yes
checking uuid/uuid.h usability… yes
checking uuid/uuid.h presence… yes
checking for uuid/uuid.h… yes
checking for uuid_parse in -luuid… yes
checking for inet_ntoa in -lnsl… yes
checking for socket in -lsocket… no
checking whether printf must be declared… no
checking whether fprintf must be declared… no
checking whether syslog must be declared… no
checking whether puts must be declared… no
checking whether fputs must be declared… no
checking whether fputc must be declared… no
checking whether fopen must be declared… no
checking whether fclose must be declared… no
checking whether fwrite must be declared… no
checking whether fflush must be declared… no
checking whether getopt must be declared… no
checking whether bzero must be declared… no
checking whether bcopy must be declared… no
checking whether memset must be declared… no
checking whether strtol must be declared… no
checking whether strcasecmp must be declared… no
checking whether strncasecmp must be declared… no
checking whether strerror must be declared… no
checking whether perror must be declared… no
checking whether socket must be declared… no
checking whether sendto must be declared… no
checking whether vsnprintf must be declared… no
checking whether snprintf must be declared… no
checking whether strtoul must be declared… no
checking for sigaction… yes
checking for strlcpy… no
checking for strlcat… no
checking for strerror… yes
checking for vswprintf… yes
checking for wprintf… yes
checking for memrchr… yes
checking for inet_ntop… yes
checking for snprintf… yes
checking for malloc_trim… yes
checking for mallinfo… yes
checking size of char… 1
checking size of short… 2
checking size of int… 4
checking size of long int… 8
checking size of long long int… 8
checking size of unsigned int… 4
checking size of unsigned long int… 8
checking size of unsigned long long int… 8
checking for u_int8_t… yes
checking for u_int16_t… yes
checking for u_int32_t… yes
checking for u_int64_t… yes
checking for uint8_t… yes
checking for uint16_t… yes
checking for uint32_t… yes
checking for uint64_t… yes
checking for int8_t… yes
checking for int16_t… yes
checking for int32_t… yes
checking for int64_t… yes
checking for boolean… no
checking for INADDR_NONE… yes
checking for FUNCTION… yes
checking for pcap_datalink in -lpcap… yes
checking for pcap_lex_destroy… no
checking for pcap_lib_version… yes
checking pcre.h usability… yes
checking pcre.h presence… yes
checking for pcre.h… yes
checking for pcre_compile in -lpcre… yes
checking for libpcre version 6.0 or greater… yes
checking for SHA256_Init in -lcrypto… yes
checking for MD5_Init in -lcrypto… yes
checking dnet.h usability… no
checking dnet.h presence… no
checking for dnet.h… no
checking dumbnet.h usability… yes
checking dumbnet.h presence… yes
checking for dumbnet.h… yes
checking for eth_set in -ldnet… yes
checking for eth_set in -ldumbnet… yes
checking for dlsym in -ldl… yes
checking for daq_load_modules in -ldaq_static… yes
checking for daq_hup_apply… yes
checking for daq_acquire_with_meta… yes
checking for daq_dp_add_dc… yes
checking for struct _DAQ_DP_key_t.sa.src_ip4… no
ERROR! daq library missing C99 patch, upgrade to >=2.0.4, go get it from
http://www.snort.org/.
Pour info j’ai compilé daq-2.0.5 et pas le 2.0.4 mais bon, de toute façon c’est le même message avec la 2.0.4…
Je n’ai pas réussi à trouver les anciennes sources pour pouvoir suivre un vieux tuto sinon j’aurai fait du pas à pas sur un des tutos du site de l’éditeur. Apparemment ils suppriment les archives pour que les admins soient à jour mais moi je fais ça pour m’amuser et progresser un peu pas pour une mise en prod chez google !
Sinon je le fais sous cent os mais j’ai mes habitudes.
Vincentsan
