Bug suite MAJ sécurité php5 Wheezy
J’ai mis à jour PHP5 suite a la note de sécurité hier sur ma machine sous Wheezy et maintenant j’ai des erreurs.
Il semble que ce soit un bug https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=770105
En effet la version de SED actuelle de Wheezy et la 4.2.1 alors qu’il faudrait la 4.2.2 pour le support de ce paramètre -z de SED
Y a t il une solution pour résoudre cela que je n’ai pas comprise?
[code][ -x /usr/lib/php5/maxlifetime ] && [ -x /usr/lib/php5/sessionclean ] && [ -d /var/lib/php5 ] && /usr/lib/php5/sessionclean /var/lib/php5 $(/usr/lib/php5/maxlifetime)
sed: invalid option – 'z’
Usage: sed [OPTION]… {script-only-if-no-other-script} [input-file]…
-n, --quiet, --silent
suppress automatic printing of pattern space
-e script, --expression=script
add the script to the commands to be executed
-f script-file, --file=script-file
add the contents of script-file to the commands to be executed
–follow-symlinks
follow symlinks when processing in place
-i[SUFFIX], --in-place[=SUFFIX]
edit files in place (makes backup if extension supplied)
-l N, --line-length=N
specify the desired line-wrap length for the `l’ command
–posix
disable all GNU extensions.
-r, --regexp-extended
use extended regular expressions in the script.
-s, --separate
consider files as separate rather than as a single continuous
long stream.
-u, --unbuffered
load minimal amounts of data from the input files and flush
the output buffers more often
–help display this help and exit
–version output version information and exit
If no -e, --expression, -f, or --file option is given, then the first
non-option argument is taken as the sed script to interpret. All
remaining arguments are names of input files; if no input files are
specified, then the standard input is read.
GNU sed home page: http://www.gnu.org/software/sed/.
General help using GNU software: http://www.gnu.org/gethelp/.
Bon j’ai pas vu hier qu’il y avait une nouvelle version de php5 suite a la régression.
J’ai fait un aptitude dist-upgrade et cela a résolu le problème.
