Bonjour à tous.
J’ai un problème bizarre avec ma config qui est la suivante :
**Ordinateur**
Processeur Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
Mémoire 8035MB (1998MB utilisé)
Machine Type Low-profile Desktop
Systeme d'exploitation Debian GNU/Linux 11 (bullseye)
**Affichage**
Résolution 1920x1080 pixels
OpenGL Renderer Mesa DRI Intel(R) HD Graphics 4600 (HSW GT2)
X11 Vendor The X.Org Foundation
Audio Devices
Adapteur Audio CMI8738-MC8 - C-Media CMI8768
Adapteur Audio HDA-Intel - HDA Intel HDMI
Adapteur Audio HDA-Intel - HDA Intel PCH
**Systeme d'exploitation**
Version
Kernel Linux 5.10.0-9-amd64 (x86_64)
Version #1 SMP Debian 5.10.70-1 (2021-09-30)
C Library GNU C Library / (Debian GLIBC 2.31-13+deb11u2) 2.31
Distribution Debian GNU/Linux 11 (bullseye)
PCI Devices
Host bridge Intel Corporation 4th Gen Core Processor DRAM Controller (rev 06)
VGA compatible controller Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller (rev 06) (prog-if 00 [VGA controller])
Audio device Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
USB controller Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 04) (prog-if 30 [XHCI])
Communication controller Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
Serial controller Intel Corporation 8 Series/C220 Series Chipset Family KT Controller (rev 04) (prog-if 02 [16550])
Ethernet controller Intel Corporation Ethernet Connection I217-LM (rev 04)
USB controller Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 04) (prog-if 20 [EHCI])
Audio device Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 04)
PCI bridge Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d4) (prog-if 00 [Normal decode])
PCI bridge Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d4) (prog-if 00 [Normal decode])
USB controller Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 04) (prog-if 20 [EHCI])
ISA bridge Intel Corporation Q87 Express LPC Controller (rev 04)
SATA controller Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
SMBus Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 04)
PCI bridge ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge (rev 01) (prog-if 00 [Normal decode])
Multimedia audio controller C-Media Electronics Inc CMI8738/CMI8768 PCI Audio (rev 10)
j’ai 2 displayports avec 2 adaptateurs HDMI pour ma TV (display 0 en primaire) et mon videoprojecteur (display 1)
A noter, que la sortie TV passe par mon ampli DENON…
Les écrans sont clonés (unifiés)
Lorsque je lis une vidéo (KODI ou VLC) sur la TV , aucun problème.
Sur le videoprojecteur, ampli allumé mais TV éteinte, ca coupe la vidéo 1/2 seconde régulièrement durant la lecture . On apercoit le bureau durant cette 1/2 seconde…et la vidéo saccade évidemment…
Si la TV est allumée en même temps que le videoprojecteur, aucun problème, mais aucun intérêt non plus…
TV éteinte, mais cable HDMI de l’ampli débranché, la lecture sur le videoprojecteur n’a plus aucun problème…
J’ai l’impression que Debian cherche la TV lorsqu’elle est éteinte (le CEC ?)…et que ca fout le bordel…
Si vous avez une idée je vous en remercie d’avance…
